Diablo III
Diablo III
Izi ::
Slo-Tech Diablo 3 lestvica z dne 30. april 2015 - Sezona 3
Paragon lestvica
_1. Paragon: 541 | __0 __ kkemikk
_2. Paragon: 469 | __0 __ Tribal
_3. Paragon: 462 | __0 __ tursca
_4. Paragon: 460 | __0 __ KaiV6
_5. Paragon: 437 | __0 __ kita103
_6. Paragon: 379 | __0 __ Insan3Lik3
_7. Paragon: 336 | __0 __ Kenpachi
_8. Paragon: 328 | __0 __ MrX
_9. Paragon: 312 | __0 __ Matev
10. Paragon: __0 | 304 __ krneki
11. Paragon: 285 | __0 __ Vajenc
12. Paragon: 266 | __0 __ guybrush
13. Paragon: 260 | __0 __ MariX
14. Paragon: 247 | __0 __ Zmajc
15. Paragon: 238 | __0 __ Izi
16. Paragon: __0 | 176 __ Andreos1
17. Paragon: 172 | __0 __ Shadow666
18. Paragon: 151 | __0 __ Tezaab
19. Paragon: 104 | __0 __ miskoslo
20. Paragon: _83 | __0 __ kentrix
Solo Greater Rift lestvica
_1. Solo GRift: 51 __ Tribal - Barbarian
_2. Solo GRift: 47 __ kita103 - Monk
_3. Solo GRift: 47 __ kkemikk - Witch Doctor
_4. Solo GRift: 46 __ Kenpachi - Barbarian
_5. Solo GRift: 45 __ KaiV6 - Barbarian
_6. Solo GRift: 42 __ Insan3Lik3 - Wizard
_7. Solo GRift: 41 __ tursca - Demon Hunter
_8. Solo GRift: 41 __ Vajenc - Wizard
_9. Solo GRift: 40 __ krneki - Demon Hunter
10. Solo GRift: 35 __ MrX - Barbarian
11. Solo GRift: 34 __ Izi - Wizard
12. Solo GRift: 34 __ Zmajc - Demon Hunter
13. Solo GRift: 31 __ guybrush - Barbarian
14. Solo GRift: 27 __ Shadow666 - Barbarian
15. Solo GRift: 23 __ Matev - Wizard
16. Solo GRift: 23 __ Andreos1 - Barbarian
17. Solo GRift: 19 __ kentrix - Demon Hunter
18. Solo GRift: 18 __ Tezaab - Barbarian
__. Solo GRift: _0 __ MariX - Barbarian
__. Solo GRift: _0 __ miskoslo - Barbarian
Gold lestvica
_1. Gold: _2.328.920.953 __ Tribal
_2. Gold: _2.224.358.916 __ kkemikk
_3. Gold: _1.333.463.812 __ tursca
_4. Gold: _1.085.209.971 __ kita103
_5. Gold: __.969.134.395 __ KaiV6
_6. Gold: __.880.872.130 __ Vajenc
_7. Gold: __.708.280.956 __ Izi
_8. Gold: __.698.854.131 __ Kenpachi
_9. Gold: __.651.769.487 __ Insan3Lik3
10. Gold: __.541.857.917 __ MrX
11. Gold: __.373.954.928 __ Matev
12. Gold: __.343.996.450 __ MariX
13. Gold: __.340.400.692 __ krneki
14. Gold: __.246.353.888 __ Zmajc
15. Gold: __.244.454.758 __ guybrush
16. Gold: __.160.643.969 __ Andreos1
17. Gold: __.148.844.142 __ Shadow666
18. Gold: __._92.959.643 __ Tezaab
19. Gold: __._31.164.654 __ kentrix
20. Gold: __._29.113.412 __ miskoslo
Polovica vseh sezoncev je sedaj Barbarov. Kaj so res tako dobri?
Tribal s svojim Barbarom raztura. Neverjetno, GRift 51 :O
KaiV6 ::
Za t6 speed rifte so barbari the best :)
pri gr pa se niti ne trudim, ker mi gredo triali na zivce :) da moras za vak gem na lvl 40 opravit ~20 trialov + griftov je tole 60 riftov, ki jih moras porabit za uprgrejdanje gemov in ne za visji grift stone... pol pa se ce se odlocis menjat kak gem ... skratka .. samo izgovori :) hehe
<insert>podpis.html</insert>
Tribal ::
Izi welcome back, boš kej igral?
kita103 ::
Tudi meni so triali najbolj mukotrpna zadeva pri Diablu. Občasno, ko s kom (kkemik, Tribal,...) igram grifte 40-45, upgrade-am key in mam potem za solo, da bi pa načrtno delal triale za solo push-e mi pa na kraj pameti ne pride (solo pomoje itak ne naredim 50 keya).
Drugače pa Tribal še 1x čestitke za 51. Jaz ob trenutni opremi in pri tem paragonu verjetno ne pridem čez 50. En key sem imel 50, pa sem bil dobro minuto in pol prepočasen (s kakim pylonom pri bosu bi verjetno šlo). 47 je šlo vsakič bp, pri 50 me pa guardian onehit-a in sem potem zaradi umiranja prepočasen.
Tribal ::
Meni pa je 51 ratal v prvo, brez težav, umru samo 1 krat na trashu, tako da obstaja upanje za višje. Samo čas rabim. Vse je pa odvisno od RNG, ampak glede na to, da sm 51 naredu brez pilona na guardianu mi daje upanje na višje. Mi je pa kar smešno ko z barbom GR 48 farmaš brez umiranja in vsakič končaš brez problemov.
Insan3Lik3 ::
jst sm pa najvišji grift rank od wizardov tukaj
hahah hecam se, ej dober tal rasha amulet je pa tudi nemogoce dobit ;((;((;(
NZXT s340 White | Gigabyte GA-B85-HD3 | Intel i5-4690K | Corsair Vengeance 8GB
1600MHz DDR3 | Gigabyte GTX 970 G1 Gaming | Transcend SSD SSD370, 256 GB |
Western Digital Black 1TB | Corsair CS750M 750W
kkemikk ::
Insan3Lik3 je izjavil:
Jaz pa od WD. Aja čakaj..... sem menda edini ki igram WD to sezono sploh :)
  • spremenil: kkemikk ()
Insan3Lik3 ::
kkemikk je izjavil:
Shadow666 ::
WD-ji so obupni, vsaj napram wizom,barbam in monkom,
ko se na T6 nabere ekipa 3 barbarov in enega WDja, basically pobira ostanke in zapre rift
Barbe so to sezono imo ajvečji demolisherji in sesujeo vse v tako hitrem tempu da za quick T6 farming ni boljšega :)
IntelXeon1241v3 3.5Ghz|GTX 1060 Strix 6GB| 16Gb 1600Mhz CrucialBallistics|
|AsusH97Pro|XFXPro650WBronze|
|1TbWDBlue|Crucial M500 SSD 240GB|Samsung EVO 256GB|ThermalRightRev.A
MrX ::
spin2win
t6 je kot da bi špilu normal...
Tezaab ::
Eno vprašanje imam glede RoRG: ali mi lahko dropne nov ring, če imam že enega (sicer v skrinji), ali ga moram dat altu na prst? Pač, trenutni je bolj kot ne crap po statsih, ampak vseeno je RoRG.
sisemen: "Inženirstvo je v nenehni tekmi z vesoljem. Trudi se izdelati
tehnologijo, ki je odporna na idiote, vesolje pa se trudi izdelati vedno
hujše idiote. In vesolje zmaguje."
Kenpachi ::
Dropa.
Zaraki Kenpachi.
Shadow666 ::
Seveda dropne =)
@MrX, jep ,T6 je fakin poop train, odrolam do konca v 2 minutah poberem lege in jovo na novo =)
Insan3Lik3 ::
do paragon 100 3x furnace drop, od 100 do 400 pa nobeden več. wow rng, could you not
Nummy ::
Eh bogi... men tud noče dropat tistega, kar rabim. Nujno bi rabil ramaladni gift, pa mi nobenga neče dropat, do sedaj vidu 2 dropa in nič več. To bi moral bit crafted item, pa magari če bi stal par miljonov golda ali pa par % drop od kakega bossa ali pa farming style ala hellfire ring, mi je čist vseen ampak samo da bi bila opcija da se da 100% pridet do njega. Tak pa ta jebeni RNG ubija celo voljo do igre...
Tezaab ::
Se strinjam. Farmam drugi meč iz seta (Bul-Kathos's Warrior Blood), pa sem dobil 3x prvega (Bul-Kathos's Solemn Vow). K sreči je bil prvi ancient, pa še dober roll. Med grifti pa poskušam dobit še en RoRG, pa sem v zadnjih petih paketih dobil 4x shoulders in 1x amulet. ;(
Edit: RoRG farmam na T6.
  • spremenilo: Tezaab ()
Insan3Lik3 ::
Nummy je izjavil:
ker paragon pa si, v season 3 kot v season 2 sm opazil da po paragonu 300 začnejo veliko pogosteje dropat gifti, jst sm vidu enega ali dva do 300, od 300 do 400 pa mi jih je dropalo 6 če se ne motim.
sun keeperjov in serpent sparkerjov (to kar rabim) sm jih tudi ene 10 dropal pa noben ancient ;(
kkemikk ::
Meni je prvi gift dropal pri 534, 40 paragonov kasneje jih imam v stashu že 5
Shadow666 ::
Jaz sem med paragoni 1 in 220 dobil 5 ramladnijev .... bolano, prejšno sezono do 305 niti enega.
Insan3Lik3 ::
Shadow666 je izjavil:
haxxxx :P
MrX ::
a gift pade v grater riftih? ker če ne, je to res qurac...
Kenpachi ::
Pade tudi v GR. Jaz sem tako enega dobil. V S3 sem dobil vse skupaj dva.
Zaraki Kenpachi.
kkemikk ::
pade pade ja. Jaz sem celo dva enkrat dobil od istega bossa
Shadow666 ::
pade povsod :)
klasicni ::
Jaz pri paragon 490 v season 3 se nisem dobil niti enega gifta, v prejsnji sezoni sem jih imel v obliju...
Matev ::
jaz imam trenutno dva na zalogi
dva sem pa že porabil to sezono
flisak ::
http://eu.battle.net/d3/en/profile/Flis...
Grift:50
paragon: 479
wizard
Nummy ::
Nummy je izjavil:
Paragorn 440+ že,... pa sej tud drugih itemov ne dropa, ampak tale gift je res item, ki ga vsak rabi, pa tud če imaš bolj beden weapon je fajn, če dobiš en dodaten stat gor.
krneki ::
Mensezdi da je za gift ista verjetnost kot za potion.
detroit ::
ne vem jst sm dobil 2 ramaldinija v parih levelih, its RNG:)
Skero
Izi ::
detroit je izjavil:
Ramaladni, ne Ramaldini :P
Drugače pa, jaz mislim, da pada manj pogosto kot specialni Potioni.
V približno 10 mesecih kolikor obstajajo sem dobil okoli 15 Ramaladnijev v istem času pa okoli 30 Potionov. Tako da po moji oceni je drop rate za Ramaladnije približno pol manjši kot za Potione.
Kenpachi ::
Pa relic za followerja je tud cel zur za najt...
Zaraki Kenpachi.
Matev ::
jaz mislim da je consumable ravno prav pogost
Jerry000 ::
evo, naročil Diablo 3 za 28€ z poštnino vred...zdaj pa da vidmo :). Ma kdo kake tipe al pa robe za začetnika :)?
Kenpachi ::
Upam, da si narocil tudi RoS drugace ne bo kaj dosti zabave :)
Zaraki Kenpachi.
Jerry000 ::
Kenpachi je izjavil:
Ne, nisem, Diablo 3 je bil v popustu pa sem vzel (box verzija). Ko pa RoS pride na tak popust pa še to vzamem :). Zakaj ne bo dosti zabave?
Smurf ::
Jerry000 je izjavil:
RoS je dosti bolj izpiljen (predvsem endgame). Ce bos igral zelo casual, solo in samo cez campaign bo ok. Ce bos hotel primerjati opremo, igrati s kolegi in uporabljati ves content pa bos potreboval RoS.
Matev ::
diablo sam po sebi je single player game - vsaj po vsem kar se je dogajalo z razvojem v zadnjih eltih
ros je pa multiplayer in pravzaprav edini pravi živi diablo
Jerry000 ::
Aja? A ni diablo3 tudi MP? A je vsaj coop? Nisem tega vedel. Ampak ja, tudi zaradi Sp sem vzel, bom naslednjič še RoS vzel :). Se da to kje dobiti po ugodni ceni? Box verzija
Shadow666 ::
Je MP , samo vso tisto najbolj fino opremo,multi rifting in ostale sladice so v ROS-u.
P
Jerry000 ::
Aja, ok za nekaj časa bo, ob naslednjem salu ko bo RoS za kake 30€ bom pa še to vzel :). Sej pomoje bo še dolgo popularno to
Smurf ::
Se to (sej verjetno to zate nic ne spremeni) oprema, ki jo bos dobil v vanilla verziji, postane neuporabna ko preides na ROS (tam so itemi bistveno mocnejsi). Prav tako bos v ROSu bistveno hitreje pridobival lvle.
KaiV6 ::
prek g2a.com je diablo RoS itak ene 20€
Jerry000 ::
rad bi box verzijo :)
Shadow666 ::
Uff ravno sem naredil Grift 42, 17 sekund do konca :D
Hudo je ^^ sam nekako mi ne rata najdit geara za naprej.... ancient orožja so must!
detroit ::
Izi je izjavil:
detroit je izjavil:
jst sm dobil vse skup ene 4-5 ramamamamamaladnijev in my time:)
Skero
kkemikk ::
Uspel gr 49 z wd :)
Shadow666 ::
lepa za 49! jez više kot 42 ne morem :) čeprav mi je glede na gear malo čudno, ker nimam ravno crap
killer86 ::
Meni je pa ratal 53 naredit z barbom :)
  • spremenil: killer86 ()
Tezaab ::
Uf, čestitam!
Jaz sem šele na 31 (ravno včeraj sem prišel tja). Mislim, da potrebujem ne toliko boljšo opremo (vse je legendary/set, nekateri itemi so ancient) kot bolj primerno opremo (zaradi set bonusov).
95 / 157
