Forum » Pomoč in nasveti » wmp 11
wmp 11
crazy kure ::
mene zanima kako si izbrišem windows media player 11, saj vemo zakaj
Hvala že vnaprej.
Hvala že vnaprej.
harvey ::
En način:
Control panel > Add/Remove Software - klikneš na Show Updates in odstraniš vse kar se nanaša na WMP11 (narediš neke vrste roll back)
Navodilo >>>
Drugi - gotovo zanesljivo
Vendar se nekaterim vztrajno še vedno prikazuje. IMHO rajši pusti vse skupi pri miru boš imel manj težav.
Več napotkov in izkušenj pa tule.
Navodilo >>>
On my own I found out the best way to do this is to go to safe mode. Once you are in safe mode you can go to my computer and then to C drive. Once there click programs and find windows media and delete it. You might also go to search and type in windows media and then delete what ever comes up there. People this really works just try it. If you have questions just write me and maybe I can help you through this
- spremenil: harvey ()
crazy kure ::
o tnx mi je ratalo na add/remove sm odstranil update-2kom sta bila,zaenkrat dela bp.
Še 1x hvala.
Še 1x hvala.
| » | Windows Media Player 11 je zuniOddelek: Programska oprema | 4402 (3687) | Tilen |
| » | 100%Cpe + ostaloOddelek: Pomoč in nasveti | 2772 (2442) | postar_si |
| » | CATALYST 3.6Oddelek: Programska oprema | 8938 (8423) | freejack |
| » | Kako popolnoma zbrisat stare driverjeOddelek: Pomoč in nasveti | 1378 (1231) | kita103 |
| » | RA2 preko dveh modemov?!Oddelek: Igre | 1770 (1665) | bastadu |
