Forum » Programiranje » predvajanje zvoka v VBasic 6
DJroky ::
Pod Components si izberi Microsoft Multimedia Control 6.0, potem pa je naprej vse mala malica, boš videl.
StratOS ::
' Declarations and such needed for the example:
' (Copy them to the (declarations) section of a module.)
Public Declare Function mciSendString Lib "winmm.dll" Alias "mciSendStringA" (ByVal _
lpszCommand As String, ByVal lpszReturnString As String, ByVal cchReturnLength _
As Long, ByVal hwndCallback As Long) As Long
Public Declare Function mciGetErrorString Lib "winmm.dll" Alias "mciGetErrorStringA" (ByVal _
fdwError As Long, ByVal lpszErrorText As String, ByVal cchErrorText As Long) As Long
' Use the MCI to play or stop playback of a MIDI file. The file C:\Music\canyon.mid
' is opened when the form opens. The Play and Stop buttons behave as you'd expect. The
' only potential surprise is that the current position is not reset when playback stops; it
' behaves just as pausing playback would. The file closes when the form unloads.
' If anything goes wrong in the example, display a message box with
' the MCI error message text.
Private Sub Form_Load()
' Open the file "C:\Music\canyon.mid" for later use in the example.
' Give it an alias of "canyon" so we don't need to refer to the filename again.
Dim errcode As Long ' MCI error code
errcode = mciSendString("open C:\Music\canyon.mid alias canyon", "", 0, 0)
If errcode <> 0 Then DisplayError errcode
End Sub
Private Sub cmdPlay_Click()
' Begin playback of the MIDI file when this button is pressed.
errcode = mciSendString("play canyon", "", 0, 0)
End Sub
Private Sub cmdStop_Click()
' Stop playback of the MIDI file when this button is pressed.
' The position within the file does not move back to the beginning.
errcode = mciSendString("stop canyon", "", 0, 0)
End Sub
Private Sub Form_Unload(Cancel As Integer)
' Close the MIDI file when the form unloads. This is important, because the
' MIDI driver can only work with one file at a time. There's no need to check
' for an error here, since we're just closing the file.
errcode = mciSendString("close canyon", "", 0, 0)
End Sub
Private Sub DisplayError(ByVal errcode As Long)
' This subroutine displays a dialog box with the text of the MCI error. There's
' no reason to use the MessageBox API function; VB's MsgBox function will suffice.
Dim errstr As String ' MCI error message text
Dim retval As Long ' return value
' Get a string explaining the MCI error.
errstr = Space(128)
retval = mciGetErrorString(errcode, errstr, Len(errstr))
' Remove the terminating null and empty space at the end.
errstr = Left(errstr, InStr(errstr, vbNullChar) - 1)
' Display a simple error message box.
retval = MsgBox(errstr, vbOKOnly Or vbCritical)
End Sub
End Sub
End Sub
End Sub
End Sub
errstr = Space(128)
End Sub
| » | video v c#Oddelek: Programiranje | 1858 (1398) | boss-tech |
| » | Vb6Oddelek: Programiranje | 1804 (1667) | StratOS |
| » | VB in kk dobit Ip od račnalnikaOddelek: Programiranje | 1540 (1374) | alesrosina |
| » | API+VBOddelek: Programiranje | 2559 (2263) | webblod |
| » | Odpiranje dat.exe v VBOddelek: Programiranje | 3834 (3627) | webblod |
