HW raid 0 in SW raid 1
dualband ::
Namen imam tole kupit:
2x WD 500GB SATA2, 16Mb, 7200rpm, (WD5000AAKS)
- Šifra izdelka: WD5000AAKS
94,90 € (22.741,84 SIT)
189,80 € (45.483,67 SIT)
Club 3D grafična kartica NVIDIA GF 8800GT, 512MB GDDR3, PCI-E, DVI, TV-Out, HDTV
- Šifra izdelka: CGNX-G882DD
218,90 € (52.457,20 SIT)
OCZ DDR2 4GB Kit (2x2GB), PC2-6400, 800MHZ, XTC hladilnik
- Šifra izdelka: OCZ2G8004GK
87,90 € (21.064,36 SIT)
INTEL PROCESOR CORE 2 DUO E8200, 2.66 GHz, 6MB, LGA775, BOX
- Šifra izdelka: BX80570E8200
156,90 € (37.599,52 SIT)
Asus osnovna plošča P5KC, P4, LGA775, I35P
- Šifra izdelka: P5KC
112,50 € (26.959,50 SIT)
LC NAPAJALNIK 550W LC6550GP 140mm FAN,v2.0(24pin)
- Šifra izdelka: LC6550GP
40,50 € (9.705,42 SIT)
Rad bi vezal diska v polje RAID 0 s raid kontrolorjem na osnovni plošči. Doma pa imam zdaj en disk ATA 250GB, zanima me ali obstaja kakšen software da bi si na četrtini teh dveh diskov (2x500g) nastavil RAID 1 in se bi mi miror delal na ta ATA 250GB disk?
Pri naročanju preko strani solo.si je na koncu neka možnost "Vnesi kupon:" Kje se dobi ta kupon pa kakšen je pomen kupona (popust najbrš?)
Hvala
Lep pozdrav
Loki ::
Software implementations, especially LVM-like, can allow RAID arrays to be created from partitions rather than entire physical drives. For instance, Novell NetWare allows you to divide an odd number of disks into two partitions per disk, mirror partitions across disks and stripe a volume across the mirrored partitions to emulate a RAID 1E configuration. Using partitions in this way also allows mixing reliability levels on the same set of disks. For example, one could have a very robust RAID-1 partition for important files, and a less robust RAID-5 or RAID-0 partition for less important data. (Intel calls this Intel Matrix RAID.) Using two partitions on the same drive in the same RAID array is, however, dangerous. If, for example, a RAID 5 array is composed of four drives 250 + 250 + 250 + 500 GB, with a 500 GB drive split into two 250 GB partitions, a failure of this drive will remove two partitions from the array, causing all of the data held on it to be lost.
Because these controllers often try to give the impression of being hardware RAID controllers, they can be known as Fake RAID. They do actually implement genuine RAID; the only faking is that they do it in software.
sicer pa lahko za backup uporabis kar navaden windows backup in bekapas vse na tisto particijo. ali periodicno bekapas s kaksnim norton ghost, ker ti onaj verjetno ne bo hotel sistema.
windows ima tudi neko moznost raida, poglej se na ms support (dynamic disks). ni pa to najpametneje.
Dynamic disk @ Wikipedia
I left my wallet in El Segundo
  • spremenil: Loki ()
RAID1, bistvena vprasanja
294072 (2831) element
RAID 0 in 1
61741 (1700) OmegaM
Disk, kateri, kupiti, ?
141760 (1546) urke710
Kako narediti particije za...
Oddelek: Operacijski sistemi
51463 (1420) Spajky
Kaj za vraga je to RAID?
142838 (2503) krucymucy
