Napaka pri sortirni metodi?
ta_pravi ::
Lep pozdrav
Imam nalogo predelat sortirno metodo(mergesort), katera je prej delala na tabeli objektov tako da bo zdaj delala na vektorju objektov.
Javlja mi napako
java.lang.ArrayIndexOutOfBoundsException: Array index out of range: 0
pa nevem kaj bi lahko blo narobe...
//NAVADEN MERGE SORT KI DELA S TABELO
public static void mergesort(Element[] a)
msort(a,0,a.length);
public static void msort(Element[] a, int k, int n)
System.out.println("MSort("+k+","+n+")");
if (n>1)
msort(a,k,n/2);
msort(a,k+n/2,n-n/2);
merge(a,k,n);
a[0].izpisiTabelo(a);
public static void merge(Element[] a, int k, int n)
System.out.println("Merge("+k+","+n+")");
Element[] temp = new Element[n];
int i=0, lo=k, hi=k+n/2;
while(loMANJSEk+n/2 && hiMANJSEk+n)
temp[i++] = (a[lo].manjsi(a[hi]) ? a[lo++] : a[hi++]);
while(loMANJSEk+n/2)
temp[i++] = a[lo++];
while(hiMANJSEk+n)
temp[i++] = a[hi++];
for(i=0; iMANJSEn; i++)
a[k+i]=temp[i];
//MERGE SORT --- SORTIRANJE Z ZLIVANJEM (VEKTOR)
public static void mergesort(Vector|NepOglas| a)
msort(a,0,a.size());
public static void msort(Vector|NepOglas| a, int k, int n)
if (n>1)
msort(a,k,n/2);
merge(a,k,n);
public static void merge(Vector|NepOglas| a, int k, int n)
Vector|NepOglas| temp = new Vector|NepOglas|(n);
temp.set(i++, (a.get(lo).compareTo(a.get(hi))MANJSE0 ? a.get(lo++) : a.get(hi++)));
temp.set(i++, a.get(lo++));
while(hiMANJSEk+n)
temp.set(i++, a.get(hi++));
a.set(k+i, temp.get(i));
ve kdo kaj bi blo narobe??
ta_pravi
Gundolf ::
Lahko bi bilo, da poskušaš sortirat prazen vektor. Vsaj na to bi jaz pomislil, če bi mi javilo index out of bounds: 0
ta_pravi ::
ma ne ni prazen vektor...sam so pa kr neki napake....
sploh mi ni več nč jasno
ta_pravi
Kenpachi ::
temp mora biti tabela.
Zaraki Kenpachi.
Java
Oddelek: Programiranje
91690 (1058) 123mg
[java] Osnovna vprašanja
373236 (2243) killa bee
Program v C
52357 (2196) darkkk
c++ in linux/windows
122096 (1972) rapvirus
Vmesnik v Javi
142830 (2613) Camel
