Težave z zagonom
Težave z zagonom
erik21 ::
Pozdravljeni. Pravkar sem na prazen disk inštaliral Windows XP SP2. Inštaliral sem še matično ploščo ter ostale driverje. Do tukaj vse ok. Potem sem pa inštaliral Daemon tools. Napisalo mi je da se bo inštalacija nadaljevala po ponovnem zagonu. Računalnik se je resetiral, ko pa je prišlo do do zagonske slike xp-jev je stvar zamrznila. V winse lahko pridem le v safe modu. Kaj naj storim?
5er--> ::
V safe mode-u odstrani daemon tools-e in njihov image drive.
erik21 ::
Probal. Še vedno isti problem.
5er--> ::
Finta je, da uninstall ne zbriše SPDT-ja.
NOTE: DAEMON Tools V4 also uses SPTD (SCSI Pass Through Direct) driver to access cdroms and it is also automatically installed during DT setup. But SPTD is not removed during uninstallation because it may be used not only by DAEMON Tools but by other applications as well and its removal may disrupt these applications.
Nevertheless, if you suppose your problems are SPTD releated you can remove it as specified in this thread.
Link do navodil za rešitev.
Odkrit nov trdovraten botnet TDL-4
3810809 (7766) Isotropic
A je to virus?
92807 (2460) fulgur
DAEMON Tools
Oddelek: Programska oprema
164729 (4303) BaRtMaN
Win Vista HP in Daemon Tools - konflikt
142250 (1924) El Nino
Daemon Tools in SPTD
51599 (1467) para!
