Forum » Programiranje » [Visual basic] Open file dialog in preklic
roli ::
Torej po tem vodiču se učim programiranje in sem naletel na en problem. Namreč vse OK glede prikazovanja dialoga in to problem je kaj se zgodi, ko pritisnem na cancel v dialogu.V vodiču (link zgoraj) je napisano kaj bi moral naredit vendar to nekako ne deluje. Visual basic mi v primeru, da naredim to javi tale warning:
Napaka se nanaša na: DialogResult.Cancel
Še koda vsega skupaj:
Warning Access of shared member, constant member, enum member or nested type through an instance; qualifying expression will not be evaluated. C:\Users\Roli\Documents\Visual Studio 2005\Projects\menus\menus\Form1.vb
Private Sub OpenToolStripMenuItem_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles OpenToolStripMenuItem.Click
Dim filename As String
Dim DidWork As Integer = OpenFD.ShowDialog()
OpenFD.InitialDirectory = "C:\"
OpenFD.Title = "Open file"
OpenFD.Filter = "Text Files (*.txt)|*.txt"
filename = OpenFD.FileName
If DidWork = DialogResult.Cancel Then
MsgBox("Cancel Button Clicked")
Else
MsgBox(filename)
End If
MessageBox.Show(filename)
End Sub
http://www.r00li.com
- spremenil: roli ()
| » | Visual BasicOddelek: Programiranje | 4232 (3258) | cekr |
| » | VB.net Excel v TifOddelek: Programiranje | 1498 (1397) | saule |
| » | [VB2005Pro]Zapiranje in še Eno uprasanjeOddelek: Programiranje | 1433 (1366) | UltraTX |
| » | [VB] Komunikacija s serijskimi napravamiOddelek: Programiranje | 2722 (1996) | mNeRo |
| » | [VB] OpenOddelek: Programiranje | 1936 (1775) | Monster |
