WMP11 problem
WMP11 problem
Jenej01 ::
Nalozil wmp11 na win2k3 server ampak se pojavi napaka. Priložen problem. Zasledil sem, da bi naj pobrisal en register, vendar le tega ne najdem. Delal sem po teh navodilih.
Tole pa je problem:
Ima kdo kaksno idejo. Pa tudi 10.ka ne gre nalozit. Tudi unistal 11.ke ne gre naredit.
LP jenej
P5Q PRO, E7300@3400Mhz, 4GB@... itd :D
bluefish ::
in ob kliku na yes?
si delal po teh navodilih?
I found a fairly easy way to install WMP11 on 2003 w/SP2.
1. Extract the download executable (e.g., wmp11-windowsxp-x86-enu.exe) with WinZip or the equivalent.
2. Open the extracted folder and extract wmfdist11.exe and wmp11.exe to separate folders.
3. Run the compatibility wizard (start/Help and Support, search for "compatibility", select "Getting older programs to run on the Windows Server 2003 family of products : Windows"
4. Click "Program Compatibility Wizard"
5. Choose locate the program manually
6. Browse to the update.exe in the extracted wmfdist11.exe folder (e.g., c:\wmp11-windowsxp-x86-enu\wmfdist11\update\update.exe)
7. Choose XP compatibility and defaults for the rest of the screen.
8. Uncheck the restart now box.
9. Repeat steps 3 through 7 for the wmp11.
This worked on a machine that I just installed 2003 SP2 on via Windows Update, which cause my WMP10 to be uninstalled.
  • spremenil: bluefish ()
Spc ::
wmp11 je tak podn od playerja.
Jenej01 ::
Ja sem delal po navodilih. Ob kliku na yes, me pac vrze na MS stran, kjer mi prijazno pove, da si naj namestim WMP10. Seveda ga ne morem.
Spc, nekako sem se navadil sedaj na njega. Katerega pa ti priporočaš, al kr Winamp.
bluefish ::
če ti ga ne bo uspelo uposobiti lahko poskusiš WinAmp ali foobar in KMPlayer (video).
Jenej01 ::
Nad WMP sem obupal, baza ze narejena v Winampu, Foobar2000 sem imel ze prej za FLAC albume. hvala vsem
edit: type
  • spremenil: Jenej01 ()
IE 7 ali FF ne predvaja nekaterih video vsebin (strani: 1 2 )
539771 (8852) HitriPepe
Windows Media Player
Oddelek: Programska oprema
142553 (2312) ;-)
Ne morem posnet IE7
91385 (1165) BC3
Kako odstranit Windows Media Player???
81456 (1407) neres
Windows Media Player 11 je zuni
234419 (3704) Tilen
