Forum » Pomoč in nasveti » Ne morem posnet IE7
Ne morem posnet IE7
kilobajt ::
Pozdravljeni.
Zanima me, ce bi kdo vedel zakaj se mi IE7 noce instalirat normalno. Vse lepo posneme, potem pa ga nne morem najti.... Ce v run napisem iexplore, mi odpre 6-ko, na racunalniku pa ga tudi ni mozno najt...
Hvala za odgovor...
PS: Windowsi niso piratski!
Hvala za odgovor...
bluefish ::
si resetiral comp po install-u?
Drugače pa jih odstrani in še enkrat namesti, pa resetiraj Win, ter jih nato zaženi preko bližnjice v Start meniju.
kilobajt ::
Comp sem seveda resetiral sam ni blo nic... Nikjer mi ne naredi nobene bljiznice, niti nic... Kot da nisem instaliral.. Tudi v dodaj odstrani programe ga ni, tako, da ga ne morem niti zbrisat...
BC3 ::
tudi jaz ga ne morem namestiti
oz.
v ie7.log pa piše:
[ie7.log]
0.265: ================================================================================
0.265: 2006/11/09 01:22:41.187 (local)
0.265: C:\Documents and Settings\Drek\Desktop\IE7-WindowsXP-x86-enu\update\update.exe (version 6.2.29.0)
0.312: Hotfix started with following command line:
0.328: IECUSTOM: To install this program, please run iesetup.exe instead
2.421: CreateUserInterface: DefineInstallCustomUI returned 0x32
2.421: CreateUserInterface: DefineInstallCustomUI Failed: 0x32
2.421: DoInstallation:CreateProgressDialog failed
2.421: Internet Explorer 7 Setup canceled.
3.640: Message displayed to the user: Internet Explorer 7 Setup canceled.
3.640: User Input: OK
3.640: Update.exe extended error code = 0xf00d
3.640: Update.exe return code was masked to 0x643 for MSI custom action compliance.
kak nasvet?
oz.
v ie7.log pa piše:
[ie7.log]
kak nasvet?
-:| athlon x2 5000->phenom fx-5000@3G, vapor-x 4890, aeneon xtune |:-
BC3 ::
sem že probal to pa pravi ,,This software has expired" ko zaženem registry diagnostic tool...
probal sem tudi v safe mode-u in v novo narejenem administratorskem računu...
| » | AdriaRoute 4.10 za Garmin navigacijoOddelek: Pomoč in nasveti | 9319 (309) | Joe1 |
| » | Windows XP težave...Oddelek: Operacijski sistemi | 2347 (2213) | edey |
| » | trojanski konj help!!!Oddelek: Operacijski sistemi | 3034 (2707) | Izi |
| » | WMP11 problemOddelek: Programska oprema | 1338 (1302) | Jenej01 |
| » | update.exeOddelek: Operacijski sistemi | 1574 (1378) | krneki |
