Forum » Izdelava spletišč » Dump MaCoFaCove kode za hash
BluPhenix ::
Pomen:
Algoritem:
00 .................................. rezervirano (1 B) 0f95 ................................ video traja 3989 sekund (2 B) 00002bbcc000 ........................ datoteka je dolga 733.790.208 B (6 B) 18d5d8c1747b005aaa2800a18e81de97 .... MD5 hash (16 B) 11 .................................. kontrolni bajt (1 B)
Algoritem:
/// <summary>
/// C# algorithm which computes hash of video file. Computed hash is then used to find matching subtitles.
/// </summary>
/// <param name="filePath">Absolute path to video file.</param>
/// <returns>Computed hash value formated as hexadecimal string (52 characters). Returns null on failure.</returns>
public static string Compute(string filePath)
try
if (!System.IO.File.Exists(filePath))
return null;
List<byte> hash = new List<byte>(26);
//0: reserved
hash.Insert(0, 0x0);
//1-2: video length in seconds
short runTime = new VideoInfo(filePath).RunTime;
if (BitConverter.IsLittleEndian)
hash.InsertRange(1, Invert(BitConverter.GetBytes(runTime)));
else
hash.InsertRange(1, BitConverter.GetBytes(runTime));
//3-8: file length in bytes
long fileLength = new FileInfo(filePath).Length;
hash.InsertRange(3, GetLastBytes(Invert(BitConverter.GetBytes(fileLength)), 6));
else
hash.InsertRange(3, GetLastBytes(BitConverter.GetBytes(fileLength), 6));
//9-24: MD5 hash for first 5 MB of file
hash.InsertRange(9, ComputeMD5FromFile(filePath, 5 * 1024 * 1024));
//25: control byte
int sum = 0;
for (int i = 0; i < 25; i++)
sum += hash[i];
hash.Insert(25, Convert.ToByte(sum % 256));
//convert to hex string
StringBuilder sbResult = new StringBuilder();
for (int i = 0; i < hash.Count; i++)
sbResult.AppendFormat("{0:x2}", hash[i]);
return sbResult.ToString();
catch
return null;
Podpisa ni več, ker so me poskušali asimilirati.
- zaklenil: BluPhenix ()
| » | [c#] shrani text, tabele, slikeOddelek: Programiranje | 1961 (1567) | Kemalito |
| » | [java] Kako v memoriji pretvoriti String objekt v File objekt ? - neka metoda ga zahtOddelek: Programiranje | 2700 (2700) | infiniteLoop |
| » | [asp.net] simpl image editorOddelek: Programiranje | 1883 (1688) | darkolord |
| » | branje byte[] iz MS access-ove bazeOddelek: Programiranje | 2312 (2222) | BHawk |
| » | Odpiranje dat.exe v VBOddelek: Programiranje | 3792 (3585) | webblod |
