Kako razbrati minidump fajl ?
plavi85 ::
Imam sledeč problem , vsake toliko časa se mi dogaja BSOD ponavadi takoj ko zacnem z igro , ponavadi ko igram kaksno uro ,2 ,3...Zdej pa kaj bi pomenil tale log ?
* Bugcheck Analysis *
PAGE_FAULT_IN_NONPAGED_AREA (50)
Invalid system memory was referenced. This cannot be protected by try-except,
it must be protected by a Probe. Typically the address is just plain bad or it
is pointing at freed memory.
Arguments:
Arg1: 991d1640, memory referenced.
Arg2: 00000001, value 0 = read operation, 1 = write operation.
Arg3: 81decb3f, If non-zero, the instruction address which referenced the bad memory
address.
Arg4: 00000000, (reserved)
Debugging Details:
WRITE_ADDRESS: GetPointerFromAddress: unable to read from 81d315ac
Unable to read MiSystemVaType memory at 81d11780
991d1640
FAULTING_IP:
nt!ObReferenceObjectByHandle+24
81decb3f 893b mov dword ptr [ebx],edi
MM_INTERNAL_CODE: 0
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: VISTA_RC
BUGCHECK_STR: 0x50
PROCESS_NAME: Steam.exe
CURRENT_IRQL: 0
TRAP_FRAME: 991dabcc -- (.trap ffffffff991dabcc)
ErrCode = 00000002
eax=89637d90 ebx=991d1640 ecx=00000001 edx=00000001 esi=88ad8900 edi=00000000
eip=81decb3f esp=991dac40 ebp=991dac6c iopl=0 nv up ei pl nz na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00010206
nt!ObReferenceObjectByHandle+0x24:
81decb3f 893b mov dword ptr [ebx],edi ds:0023:991d1640=????????
.trap
Resetting default scope
LAST_CONTROL_TRANSFER: from 81c8fa74 to 81ca9ef2
STACK_TEXT:
991dabb4 81c8fa74 00000001 991d1640 00000000 nt!MmAccessFault+0x106
991dabb4 81decb3f 00000001 991d1640 00000000 nt!KiTrap0E+0xdc
991dac6c 81d89989 00001b48 00000002 83f87040 nt!ObReferenceObjectByHandle+0x24
991dad00 81d8eec9 00000354 00001b48 00000000 nt!IopXxxControlFile+0x13c
991dad34 81c8c96a 00000354 00001b48 00000000 nt!NtFsControlFile+0x2a
991dad34 76f00f34 00000354 00001b48 00000000 nt!KiFastCallEntry+0x12a
WARNING: Frame IP not in any known module. Following frames may be wrong.
041dfdbc 00000000 00000000 00000000 00000000 0x76f00f34
STACK_COMMAND: kb
FOLLOWUP_IP:
nt!KiTrap0E+dc
81c8fa74 85c0 test eax,eax
SYMBOL_STACK_INDEX: 1
SYMBOL_NAME: nt!KiTrap0E+dc
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: nt
IMAGE_NAME: ntkrpamp.exe
DEBUG_FLR_IMAGE_TIMESTAMP: 4549ae00
FAILURE_BUCKET_ID: 0x50_W_nt!KiTrap0E+dc
Followup: MachineOwner
eax=81cf483c ebx=00000001 ecx=0000058d edx=81d293dc esi=81cf4820 edi=00000000
eip=81ca9ef2 esp=991dab40 ebp=991dabb4 iopl=0 nv up ei ng nz na pe nc
cs=0008 ss=0010 ds=0023 es=0023 fs=0030 gs=0000 efl=00000286
nt!MmAccessFault+0x106:
81ca9ef2 8b07 mov eax,dword ptr [edi] ds:0023:00000000=????????
ChildEBP RetAddr Args to Child
991dabb4 81decb3f 00000001 991d1640 00000000 nt!KiTrap0E+0xdc (FPO: [0,0] TrapFrame @ 991dabcc)
991dad34 76f00f34 00000354 00001b48 00000000 nt!KiFastCallEntry+0x12a (FPO: [0,3] TrapFrame @ 991dad64)
start end module name
80202000 80227000 pci pci.sys Thu Nov 02 09:35:13 2006 (4549ADC1)
80227000 80236000 volmgr volmgr.sys Thu Nov 02 09:51:44 2006 (4549B1A0)
80236000 8023e000 msisadrv msisadrv.sys Thu Nov 02 09:35:08 2006 (4549ADBC)
8023e000 80264000 SCSIPORT SCSIPORT.SYS Thu Nov 02 09:51:38 2006 (4549B19A)
80264000 8026d000 WMILIB WMILIB.SYS Thu Nov 02 09:54:53 2006 (4549B25D)
8026d000 8027a000 WDFLDR WDFLDR.SYS Thu Nov 02 09:54:05 2006 (4549B22D)
8027a000 802b5000 CLFS CLFS.SYS Thu Nov 02 09:30:52 2006 (4549ACBC)
802b5000 802bd000 BOOTVID BOOTVID.dll Thu Nov 02 10:39:29 2006 (4549BCD1)
802bd000 802c6000 PSHED PSHED.dll Thu Nov 02 10:42:51 2006 (4549BD9B)
802c6000 802ce000 kdcom kdcom.dll Thu Nov 02 10:42:20 2006 (4549BD7C)
80400000 80401700 USBD USBD.SYS Thu Nov 02 09:55:00 2006 (4549B264)
80402000 8040a000 atapi atapi.sys Thu Nov 02 09:51:34 2006 (4549B196)
8040a000 80418000 sfsync03 sfsync03.sys Tue Jul 11 09:30:20 2006 (44B3538C)
80418000 80426000 PCIIDEX PCIIDEX.SYS Thu Nov 02 09:51:34 2006 (4549B196)
80426000 8042d000 pciide pciide.sys Thu Nov 02 09:51:35 2006 (4549B197)
8042d000 8043d000 mountmgr mountmgr.sys Thu Nov 02 09:51:06 2006 (4549B17A)
8043d000 8044f000 ps6ah4nc ps6ah4nc.sys Fri May 18 21:52:29 2007 (464E03FD)
8044f000 80461000 ps6ah4nb ps6ah4nb.sys Mon Jun 11 13:10:46 2007 (466D2DB6)
80461000 804a4000 acpi acpi.sys Thu Nov 02 09:35:03 2006 (4549ADB7)
804a4000 8051f000 Wdf01000 Wdf01000.sys Thu Nov 02 09:54:18 2006 (4549B23A)
8051f000 80600000 CI CI.dll Thu Nov 02 10:42:45 2006 (4549BD95)
80603000 80612000 partmgr partmgr.sys Thu Nov 02 09:51:47 2006 (4549B1A3)
80612000 8061a000 sfhlp02 sfhlp02.sys Wed Jun 14 16:56:53 2006 (449023B5)
8061a000 80622000 spldr spldr.sys Thu Oct 26 00:40:44 2006 (453FE7EC)
80622000 80632000 fileinfo fileinfo.sys Thu Nov 02 09:36:47 2006 (4549AE1F)
80632000 80663000 fltmgr fltmgr.sys Thu Nov 02 09:30:58 2006 (4549ACC2)
80663000 806a3000 storport storport.sys Thu Nov 02 09:51:45 2006 (4549B1A1)
806a3000 806b0000 nvstor nvstor.sys Wed Oct 04 02:25:15 2006 (4522FF6B)
806b0000 806ce000 ataport ataport.SYS Thu Nov 02 09:51:34 2006 (4549B196)
806ce000 80718000 volmgrx volmgrx.sys Thu Nov 02 09:51:54 2006 (4549B1AA)
80718000 80800000 sptd sptd.sys Tue Apr 03 14:12:11 2007 (4612449B)
81a08000 81a1b000 pe3ah4nc pe3ah4nc.sys Fri May 18 21:52:59 2007 (464E041B)
81a1b000 81a2e000 sfdrv01 sfdrv01.sys Wed Jul 05 14:39:25 2006 (44ABB2FD)
81a2e000 81a98000 ksecdd ksecdd.sys Thu Nov 02 09:43:45 2006 (4549AFC1)
81a98000 81ad1000 NETIO NETIO.SYS Thu Nov 02 09:58:01 2006 (4549B319)
81ad1000 81afc000 msrpc msrpc.sys unavailable (00000000)
81afc000 81c00000 ndis ndis.sys Thu Nov 02 09:57:33 2006 (4549B2FD)
81c00000 81fa1000 nt ntkrpamp.exe Thu Nov 02 09:36:16 2006 (4549AE00)
81fa1000 81fd5000 hal halmacpi.dll Thu Nov 02 09:30:18 2006 (4549AC9A)
8a01d000 8a026000 crcdisk crcdisk.sys Thu Nov 02 09:52:27 2006 (4549B1CB)
8a026000 8a047000 CLASSPNP CLASSPNP.SYS Thu Nov 02 09:51:34 2006 (4549B196)
8a047000 8a058000 disk disk.sys Thu Nov 02 09:51:40 2006 (4549B19C)
8a058000 8a07b000 fvevol fvevol.sys Thu Nov 02 09:30:07 2006 (4549AC8F)
8a07b000 8a0a0000 ecache ecache.sys Thu Nov 02 09:52:42 2006 (4549B1DA)
8a0a0000 8a0af000 mup mup.sys Thu Nov 02 09:31:04 2006 (4549ACC8)
8a0af000 8a0c2000 pe3ah4nb pe3ah4nb.sys Mon Jun 11 13:11:11 2007 (466D2DCF)
8a0c2000 8a0f8000 volsnap volsnap.sys Thu Nov 02 09:52:11 2006 (4549B1BB)
8a0f8000 8a200000 Ntfs Ntfs.sys Thu Nov 02 09:31:39 2006 (4549ACEB)
8aa74000 8aa83000 monitor monitor.sys Thu Nov 02 09:54:05 2006 (4549B22D)
8ae5d000 8ae63000 30707 30707.sys Fri Dec 22 23:44:41 2006 (458C5FD9)
8aed0000 8aed2880 pfc pfc.sys Sat Sep 20 01:47:22 2003 (3F6B958A)
8af90000 8af98000 RDPCDD RDPCDD.sys Thu Nov 02 10:02:01 2006 (4549B409)
8af98000 8afa0000 rdpencdd rdpencdd.sys Thu Nov 02 10:02:01 2006 (4549B409)
8afe8000 8aff0000 mouhid mouhid.sys Thu Nov 02 09:51:12 2006 (4549B180)
8aff8000 8b000000 PnkBstrK PnkBstrK.sys Thu May 10 22:56:54 2007 (46438716)
8c216000 8c21d000 parvdm parvdm.sys unavailable (00000000)
8c224000 8c22a380 HIDPARSE HIDPARSE.SYS Thu Nov 02 09:55:00 2006 (4549B264)
8c22b000 8c231a00 LHidKE LHidKE.Sys Wed Jul 19 21:29:06 2006 (44BE8802)
8c24e000 8c255000 Null Null.SYS unavailable (00000000)
8c255000 8c25c000 Beep Beep.SYS Thu Nov 02 09:51:03 2006 (4549B177)
8c278000 8c281000 Fs_Rec Fs_Rec.SYS unavailable (00000000)
8c281000 8c28a000 rasacd rasacd.sys Thu Nov 02 09:58:13 2006 (4549B325)
8c28a000 8c293000 hidusb hidusb.sys Thu Nov 02 09:55:01 2006 (4549B265)
8c2f6000 8c2fe360 aswTdi aswTdi.SYS Mon Apr 30 17:38:46 2007 (46360D86)
8c2ff000 8c308000 tunmp tunmp.sys Thu Nov 02 09:57:23 2006 (4549B2F3)
8c322000 8c323380 swenum swenum.sys Thu Nov 02 09:51:15 2006 (4549B183)
8c82b000 8c82eb20 aswRdr aswRdr.SYS Mon Apr 30 17:39:37 2007 (46360DB9)
8c85b000 8c85e500 MTiCtwl MTiCtwl.sys Mon Apr 23 22:18:26 2007 (462D1492)
8c893000 8c896500 L8042Kbd L8042Kbd.sys Wed Jul 19 21:27:25 2006 (44BE879D)
8c8a9000 8c8ad880 hamachi hamachi.sys Mon May 14 22:02:20 2007 (4648C04C)
8c8cd000 8c8de900 LMouKE LMouKE.Sys Wed Jul 19 21:28:54 2006 (44BE87F6)
8c8e9000 8c8f5000 vga vga.sys Thu Nov 02 09:53:56 2006 (4549B224)
8c930000 8c940000 HIDCLASS HIDCLASS.SYS Thu Nov 02 09:55:00 2006 (4549B264)
8c950000 8c960000 lltdio lltdio.sys Thu Nov 02 09:56:48 2006 (4549B2D0)
8c9f0000 8ca00000 NDProxy NDProxy.SYS Thu Nov 02 09:58:08 2006 (4549B320)
8d803000 8d840000 USBPORT USBPORT.SYS Thu Nov 02 09:55:09 2006 (4549B26D)
8d840000 8d84f000 amdk8 amdk8.sys Thu Nov 02 09:30:18 2006 (4549AC9A)
8d84f000 8d85e000 raspppoe raspppoe.sys Thu Nov 02 09:58:12 2006 (4549B324)
8d85e000 8d86d000 termdd termdd.sys Thu Nov 02 10:02:00 2006 (4549B408)
8d93d000 8d94a000 watchdog watchdog.sys Thu Nov 02 09:37:44 2006 (4549AE58)
8d957000 8d964000 umbus umbus.sys Thu Nov 02 09:55:24 2006 (4549B27C)
8d98b000 8d998000 crashdmp crashdmp.sys Thu Nov 02 09:51:36 2006 (4549B198)
8d998000 8d9a5000 dump_nvstor dump_nvstor.sys Wed Oct 04 02:25:15 2006 (4522FF6B)
8dc06000 8dc2b000 drmk drmk.sys Thu Nov 02 10:20:49 2006 (4549B871)
8dc2b000 8dc58000 portcls portcls.sys Thu Nov 02 09:55:02 2006 (4549B266)
8dc58000 8dc70000 cdrom cdrom.sys Thu Nov 02 09:51:44 2006 (4549B1A0)
8dc7e000 8dc8c000 usbehci usbehci.sys Thu Nov 02 09:55:04 2006 (4549B268)
8dc8c000 8dc9a000 Npfs Npfs.SYS Thu Nov 02 09:30:57 2006 (4549ACC1)
8dc9a000 8dca8000 netbios netbios.sys Thu Nov 02 09:57:26 2006 (4549B2F6)
8dd5b000 8dd66000 tunnel tunnel.sys Thu Nov 02 09:57:29 2006 (4549B2F9)
8dd66000 8dd71000 kbdclass kbdclass.sys Thu Nov 02 09:51:09 2006 (4549B17D)
8dd71000 8dd7c000 TDI TDI.SYS Thu Nov 02 09:58:46 2006 (4549B346)
8dd7c000 8dd87000 ndistapi ndistapi.sys Thu Nov 02 09:58:07 2006 (4549B31F)
8dd92000 8dd9d000 mouclass mouclass.sys Thu Nov 02 09:51:09 2006 (4549B17D)
8dd9d000 8dda8000 Msfs Msfs.SYS unavailable (00000000)
8ddb3000 8ddbe000 tcpipreg tcpipreg.sys Thu Nov 02 09:57:46 2006 (4549B30A)
8de02000 8de1a000 parport parport.sys Thu Nov 02 09:51:29 2006 (4549B191)
8de1a000 8de34000 serial serial.sys Thu Nov 02 09:51:29 2006 (4549B191)
8de34000 8de9a000 ajm3xg9m ajm3xg9m.SYS Wed Apr 11 19:59:50 2007 (461D2216)
8de9a000 8dec4000 ks ks.sys Thu Nov 02 09:51:18 2006 (4549B186)
8dec4000 8df60000 dxgkrnl dxgkrnl.sys Thu Nov 02 09:38:46 2006 (4549AE96)
8df60000 8df6a000 usbohci usbohci.sys Thu Nov 02 09:55:05 2006 (4549B269)
8df6a000 8df74000 serenum serenum.sys Thu Nov 02 09:51:25 2006 (4549B18D)
8df74000 8df7e000 mssmbios mssmbios.sys Thu Nov 02 09:35:13 2006 (4549ADC1)
8df92000 8df9c000 nsiproxy nsiproxy.sys Thu Nov 02 09:57:30 2006 (4549B2FA)
8df9c000 8dfa6000 dump_diskdump dump_diskdump.sys Thu Nov 02 09:51:36 2006 (4549B198)
8dfba000 8dfc4000 Dxapi Dxapi.sys Thu Nov 02 09:38:17 2006 (4549AE79)
8dfe2000 8dfec000 secdrv secdrv.SYS Wed Sep 13 15:18:32 2006 (45080528)
8e020000 8e054000 usbhub usbhub.sys Thu Nov 02 09:55:20 2006 (4549B278)
8e054000 8e067000 raspptp raspptp.sys Thu Nov 02 09:58:14 2006 (4549B326)
8e067000 8e08a000 ndiswan ndiswan.sys Thu Nov 02 09:58:13 2006 (4549B325)
8e08a000 8e0a1000 rasl2tp rasl2tp.sys Thu Nov 02 09:58:13 2006 (4549B325)
8e0a1000 8e0cc000 msiscsi msiscsi.sys Thu Nov 02 09:52:40 2006 (4549B1D8)
8e0cc000 8e0df000 i8042prt i8042prt.sys Thu Nov 02 09:51:12 2006 (4549B180)
8e0df000 8e7fff80 nvlddmkm nvlddmkm.sys Fri Apr 27 03:00:34 2007 (46314B32)
8ee01000 8ee12000 dump_dumpfve dump_dumpfve.sys Thu Nov 02 09:30:04 2006 (4549AC8C)
8ee27000 8eeae000 rdpdr rdpdr.sys Thu Nov 02 10:02:58 2006 (4549B442)
8eeae000 8f000000 P17 P17.sys Mon Feb 05 10:10:32 2007 (45C6F488)
8f002000 8f01b000 fwpkclnt fwpkclnt.sys Thu Nov 02 09:57:26 2006 (4549B2F6)
8f105000 8f1ff480 nvmfdx32 nvmfdx32.sys Tue Jan 16 01:50:38 2007 (45AC215E)
8f20e000 8f223000 ISODrive ISODrive.sys Fri Apr 13 11:42:14 2007 (461F5076)
8f223000 8f236000 wanarp wanarp.sys Thu Nov 02 09:58:13 2006 (4549B325)
8f236000 8f24c000 pacer pacer.sys Thu Nov 02 09:57:33 2006 (4549B2FD)
8f24c000 8f27e000 netbt netbt.sys Thu Nov 02 09:57:18 2006 (4549B2EE)
8f27e000 8f2c5000 afd afd.sys Thu Nov 02 09:58:41 2006 (4549B341)
8f2c5000 8f2d9000 smb smb.sys Thu Nov 02 09:57:10 2006 (4549B2E6)
8f2d9000 8f2ee000 tdx tdx.sys Thu Nov 02 09:57:34 2006 (4549B2FE)
8f2ee000 8f3bf000 tcpip tcpip.sys Thu Nov 02 09:58:31 2006 (4549B337)
8f3df000 8f400000 VIDEOPRT VIDEOPRT.SYS Thu Nov 02 09:54:07 2006 (4549B22F)
8f504000 8f51b000 usbccgp usbccgp.sys Thu Nov 02 09:55:11 2006 (4549B26F)
8f51b000 8f532000 dfsc dfsc.sys Thu Nov 02 09:31:04 2006 (4549ACC8)
8f532000 8f585000 csc csc.sys Thu Nov 02 09:31:36 2006 (4549ACE8)
8f5c5000 8f600000 rdbss rdbss.sys Thu Nov 02 09:31:24 2006 (4549ACDC)
92c00000 92dff000 win32k win32k.sys Thu Feb 15 03:57:33 2007 (45D3CC1D)
93a00000 93a09000 TSDDD TSDDD.dll unavailable (00000000)
93a10000 93a1e000 cdd cdd.dll Thu Nov 02 10:39:20 2006 (4549BCC8)
93a20000 93a6c000 ATMFD ATMFD.DLL Thu Nov 02 09:38:18 2006 (4549AE7A)
9786c000 9787f000 rspndr rspndr.sys Thu Nov 02 09:56:48 2006 (4549B2D0)
978ff000 97915000 aswMonFlt aswMonFlt.sys Fri Apr 27 23:26:34 2007 (46326A8A)
97915000 97930000 luafv luafv.sys Thu Nov 02 09:33:07 2006 (4549AD43)
990b7000 99145000 spsys spsys.sys Thu Oct 26 00:43:28 2006 (453FE890)
9914d000 99163000 cdfs cdfs.sys Thu Nov 02 09:30:50 2006 (4549ACBA)
9aa1c000 9aa35000 bowser bowser.sys Thu Nov 02 09:31:11 2006 (4549ACCF)
9aa35000 9aa50000 srvnet srvnet.sys Thu Nov 02 09:31:43 2006 (4549ACEF)
9aa57000 9aa76000 mrxdav mrxdav.sys Thu Nov 02 09:31:24 2006 (4549ACDC)
9aa76000 9aa8a000 mpsdrv mpsdrv.sys Thu Nov 02 09:56:32 2006 (4549B2C0)
9aaca000 9ab30000 HTTP HTTP.sys Thu Nov 02 09:57:06 2006 (4549B2E2)
9b026000 9b072000 srv srv.sys Thu Nov 02 09:31:55 2006 (4549ACFB)
9b173000 9b197000 srv2 srv2.sys Thu Nov 02 09:31:46 2006 (4549ACF2)
9b197000 9b1a9000 mrxsmb20 mrxsmb20.sys Thu Nov 02 09:31:16 2006 (4549ACD4)
9b1a9000 9b1e2000 mrxsmb10 mrxsmb10.sys Thu Nov 02 09:31:25 2006 (4549ACDD)
9b1e2000 9b200000 mrxsmb mrxsmb.sys Thu Nov 02 09:31:20 2006 (4549ACD8)
9bd22000 9be00000 peauth peauth.sys Mon Oct 23 10:55:32 2006 (453C8384)
afbc5000 afc00000 udfs udfs.sys Thu Nov 02 09:30:57 2006 (4549ACC1)
Unloaded modules:
a2376000 a237e000 PnkBstrK.sys
Timestamp: unavailable (00000000)
Checksum: 00000000
98b58000 98b60000 PnkBstrK.sys
Checksum: 00000000
8af80000 8af88000 PnkBstrK.sys
Checksum: 00000000
a238e000 a2396000 PnkBstrK.sys
Checksum: 00000000
8d921000 8d930000 monitor.sys
Checksum: 00000000
8d86d000 8d87c000 monitor.sys
Checksum: 00000000
8afb0000 8afb8000 drmkaud.sys
Checksum: 00000000
8c812000 8c81f000 crashdmp.sys
Checksum: 00000000
8ae0b000 8ae15000 dump_storpor
Checksum: 00000000
8d930000 8d93d000 dump_nvstor.
Checksum: 00000000
8c8ce000 8c8df000 dump_dumpfve
Checksum: 00000000
Closing open log file c:\debuglog.txt
darkolord ::
A lahko ta minidump fajl kam uploadas?
marsovcek ::
A resno misliš, da bo kdo bral to solato? :D Si že stestiral RAM z memtest-om? Se ti kaj pregreva?
BaRtMaN ::
Dvomim, da ma tukaj RAM kaj veze. Gre za hrošč programa, ki želi pisati na naslov pomnilnika, ki mu ne pripada.
  • spremenil: BaRtMaN ()
plavi85 ::
Ja zdej nvem sm spucu zadevo , prej sm meu 70C8-O na CPU-ju zdej jih mam pa max do 55C pod obremenitvijo, zgleda je treba pac ventilator od racunalnika pucat na vsake 2 tedna , sploh pa če maš računalnik odprt..:\
amigo_no1 ::
Jst ::
address.
Napaka v programu, ali pa hardware napaka: RAM. Lahko je RAM osebno, ali pa plata.
plavi85 ::
A je možn da mi j*** sistem ker imam 2x512MB 4-4-3-8 + 2x1GB 5-5-5-12 , firmi sta obe SuperTalent , skupno jih pa furam na 5-5-5-15 400fsb, je pa res da 512ke so SingleSided ,Gigiči pa DoubleSided rami ???
Jst ::
Dual Channel ima skoraj zagotovo probleme s tem, če je aktiviran.
Blue Screen (ntoskrnl.exe)
253077 (1928) fulgur
BSOD problem
92227 (1885) Oktan
Windows XP Black screen
124739 (4479) Twix
Podatki iz Memory-Dump-a?
202562 (2116) R33D3M33R
Kdo bo ...
172292 (1864) Thomas
