Forum » Strojna oprema » Intel vs. AMD - mobilni procesorji
neoto ::
Ali kdo od vas sploh ve za kakšne AMD Turion 64 X2 vs. Intel Core 2 Duo primerjave oz. teste?
Nikjer namreč ne najdem kaj uporabnega napisano glede realne hitrosti, predvsem porabe in izkušenj...
ps: se splača na Santa Rose čakat?
- spremenil: neoto ()
neoto ::
Si bom sam odgovoril... Pri Tom-u so bili pridni in letos spisali članek na to temo: Tom's hardware
zee ::
Intel je na področju mobilnih procesorjev še vedno bistveno boljši.
zee
ronaldo ::
Ni cudno da vedno vec ljudi nezaupa TH, kar se dobro vidi tudi po tem reviewu ki so ga naredili. Ampak zal obstaja se vedno dosti ljudi ki sploh ne vidi da so primerjali dva totalno drugacna sistema, mogoce bo vam tole dalo misliti:
You can basically ignore this review; if you read on, you will find that Tom’s Hardware (which used to be a reputable review site) has not compared these processors in remotely similar systems; the Intel is running on a custom built desktop MoBo with a dedicated Video Card (x800), dedicated graphics RAM, and mains power (i.e. for all purposes a desktop, not laptop, system). The AMD is running on a stock notebook system, with NO video card at all (integrated), no dedicated VRAM, etc. (i.e. a notebook, what the other one SHOULD have been also). This is the epitome of an apples/oranges comparison… let’s compare an Intel laptop to an AMD desktop and see who wins! Also, the comparison includes the high-end core 2 duo chips (up to 2ghz) but NOT the high-end Turion 60 chip, which is 2.0 ghz and therefore much more comparable to the core 2 duo’s that they chose. Instead they compared the high-end Core 2 Duos (2.0ghz+, 4m cache, expensive) to the low-end Turions (1.6/1.8, 256/512k cache, cheap) instead of comparing similar chips. There are also no comparisons on other specs, like power usage, graphics performance, access times, games (how’d that one get left out?), battery life, overclocking performance, multitasking performance (dual core’s main advantage), price, etc. Wait for a better review, that reviews comparable-speed processors on identical systems, without any of this apples/oranges BS.
Tole je post na njihovem forumu, ki opise situacijo katera se dogaja na tem nekdaj zelo popularnem TH.
dolenc ::
Za Toms hardware že od nekdaj velja, da je treba nekatere njihove opise zelo z rezervo jemat.
mmaestro ::
Kje konkretno je boljši? Pri igranju igric, pri hitrosti zaganjanja oz izvajanja programov, pri grafičnem oblikovanju,...?
Tudi sam nameravam kupiti v kratkem prenosnika tako da bi rad vedel kje konkretno je intel boljši ter v kakšni meri je boljši. Glede na to da bom mel prenosnika za multimedijo, internet ter programiranje me zanima v kakšni meri bi bil inter v tem primeru boljši od AMDja?
Hvala in LP
neoto ::
mmaestro, ravno zato sem to temo odprl. Vsi pravijo, da je Intel boljši, nihče pa nima nobenih konkretnih testov...
ronaldo, če bi prebral uvod v test, bi videl zakaj je temu tako... V čem bi se pa naj razlikovala desktop matična od prenosnikove, če imaš vezno čipovje istega ranga, iste RAM-e? Z grafičnimi je malo zgrešeno mogoče, ampak niso nikjer grafičnih aplikacij testirali...
Daedalus ::
Področje uporabe, ki ne gleda na porabo štroma, ampak na čimboljši izkoristek hardwera. Pri laptopih pa lih obratno. Čipset istega ranga ne pomeni, da je zmogljivost podobna/enaka. Pač, nekredibilen test, move on.
[J.P.Sartre]
[J.P.Sartre]
neoto ::
Daedalus, move on to WHAT? Če veš za kakšen drug opravljen test mobilnih CPU, povej prosim...
zcetrt ::
Če iskreno pogledamo na celotno zadevo... 98% časa bo procesor v prenosniku downclockan na manj kot polovico svoje zmogljivosti. Se torej res splača obremenjevati s procesorjem, ki dandanašnji zadosti vsem zahtevam normalne uprabe? Ali je sploh opazna in neprespanih noči vredna minimalna potencialna razlika v hitrosti?
Konec koncev, tam kjer pri enojedrnikih človek opazi šibkost procesorja, je pri poganjanju več aplikacij hkrati. Pri dvojedrnikih je še ta problem mnogo manjši.
Seveda je to pogled na omenjeno dilemo glede na moje potrebe. Kaj pa na tvoje, Neoto?
4.
neoto ::
Hja, zcetrt. Saj poznaš moje potrebe...
Downclockam, ko nucam baterijo, in dam na full, ko potrebujem full power... Torej potrebujem procesor, ki je varčen, ko 'biva' na nizkih frekvencah in voltažah in sposoben, ko mu daš juica... Trenutno sem pa res na 600MHz@0.7V ...
mmaestro ::
Zanima me kakšna je razlika med core duo in core 2 duo. V čem je en in drugi boljši, će je core duo sploh v čem boljši?
Good Guy ::
core 2 duo je bolšji v vsem
http://goo.gl/7ItKpU
Naj računalnik dela za vas^^
Liker ::
Mobilne procesorje je skoraj nemogoce primerjat, v stilu AMD vs Intel, saj je zmogljivost prenosnika v veliki meri odvisna od chipseta.
Po izkusnjah sodec pa vecina ljudi priporoca intel procesorje ravno zato ker temeljijo na intel veznih naborih, ki so v primerjavi s konkurenco skoraj cisto zlato.
Kot sem ze povedal se mi zdi da so po surovi moci Turioni povsem primerljivi s Core 2, a jih ostale komponente redno puscajo na cedilu.
Samo par primerov iz firme:
Vecina nas ima se prenosnike na 855 ali 915 z Dothani (400/533 FSB).
Ene par odpadnikov ima tudi ze nove Core 2 na 945 in pa seveda nekaj ljudi ima AMD based prenosnike.
Recimo cisto navadna primerjava (compile enega nasega programa, na povsem enakih linux distribucijah z enakimi nastavitvami):
P-M Dothan 1.7 (400FSB) + 855 chipset ~ 75 sekund (povprecje v bistvu bolj rine proti 80 ampak sem zaokrozil navzdol
P-M Dothan 1.86 (533FSB) + 915 chpiset ~ 60 sekund
Core 2 Duo T7400 2x 2,16 (667FSB) + 945 chipset ~ 40 sekund
Turion TL-56 2x 1.8 + Ati Xpress ??? chipset ~ 70 sekund
Turion TL-50 2x 1.6 + SiS ??? chipset ~ 60 sekund
Poleg tega se na prenosniku z Ati chipsetom zgodi naslednje: vsakic ko se v PCMCIA slot vtakne kartico (recimo TV tuner ali pa dodatna FireWire kartica), in se zadevo polno obremeni, gre CPU usage na 100% in masina POVSEM zablokira. Ce se medtem predvaja mp3 glasba se zacne zatikati in potem utihne, dokler se PCMCIA ne razbremeni... (problem je prisoten tako v Linux kot v Windows OS)
Recimo ce privzamem da je rezultat od TL-50 se kar realen, potem bi moral najmocnejsi TL-60 (ki ima tudi 2x vec cachea kot TL-50) na solidnem chipsetu komot konkurirat C2D T7x00 seriji.
In ravno zaradi taksnih in drugacnih problemov vecina ljudi odsvetuje low budget prenosnike (kamor je v bistvu AMD od nekdaj rinil). Pa kolikor je meni znano se podobni problemi pojavljajo tudi na sistemih ki imajo intel procesor in kaksen Ati (ali podobno kramo) chipset.
Ce bo AMD naslednje leto dejansko splavil povsem svoj chipset za prenosnike (kot se govori) bi znalo to precej izenacit pogoje.
Evo je pa tale neobstoj primerjave med Intel in AMD na prenosnem trgu lepa priloznost za kak nov S-T test?
Recimo si sposodite ene 20 razlicnih prenosnikov z enako kolicino rama, podobnimi (ce ne enakimi) diski, in se stestira :)
Pa testirat NUJNO enake procesorje na razlicnih chipsetih. Da se tudi to odvisnost pokaze. :)
neoto ::
Liker, ko bi te le kdo uslišal...
Hvala za tole razlago. Takšnih komentarjev, podkrepljenih z realnimi dejstvi, nasploh manjka na področju prenosnikov. Hvala!
zcetrt ::
Kompajlanje pri dvojedrnikih je verjetno obremenilo le eno jedro, kajne? Sicer pa, Liker, super post.
4.
Zheegec ::
Kolikor sem gledal (redke) teste na netu je AMD 690 čipset velik korak naprej, in po performancah, kakor tudi po porabi energije.
Janez Janša, 29.04.2014
Liker ::
Ja, seveda, compile obremeni le eno jedro :)
Tako in tako tole ni bilo misljeno kot primerjava single core vs dual core, ampak pac splosna hitrost arhitekture...
Jep, M690 je korak v pravo smer, sicer zal ne poznam nikogar s tem chipsetom v prenosniku, a po ocenah in ostalem hypu po netu je zadeva kar soliden konkuret intelu :)
zcetrt ::
Ja, glede single in dual core ni bilo mišljeno kot neka opazka o zgrešenosti testa, daleč od tega, ampak le, da ne moremo reči, da je vseeno za hitrost, če je Pentium M ali pa Turion TL-50 z dvema jedroma. Da ne bi kdo dobil napačnega občutka...
4.
| » | Kater procesor v prenosniku do 700€Oddelek: Kaj kupiti | 2454 (2036) | brera |
| » | ProcesorjiOddelek: Pomoč in nasveti | 1239 (1189) | Shifty |
| » | nakup prenosnikaOddelek: Kaj kupiti | 1375 (1308) | Good Guy |
| » | Acer Aspire 5671 AWLMiOddelek: Kaj kupiti | 4181 (3808) | -PIC- |
| » | Razlika med Tehnologijo Dual Core in Core DuoOddelek: Pomoč in nasveti | 3829 (3532) | fras |
