BLUE SCREEN
BLUE SCREEN
pobcc ::
No kot prvo se opravičujem, če sem dal tole pod napačno "izbo".
Problem pa je sledeč, ob izklopu prenosnika mi pogosto tik predno se izklopi, vrže ven BLUE SCREEN (včasih ga vrže tudi med samim delovanjem) .
Vse kar sem spraskal vn je, da sem šel pod Event Viewer>System:
Kjer piše tole
The computer has rebooted from a bugcheck. The bugcheck was: 0x1000008e (0xc0000005, 0xb8551c94, 0xbae15b48, 0x00000000). A dump was saved in: C:\WINDOWS\Minidump\Mini051007-01.dmp.
potem pa sem z dumpchk preveru še tale dokument :dumpchk.exe Mini051007-01.dmp
Kjer pa je vrho vn tole (če sploh kj pomaga pr vsem tem):
Loading dump file Mini051007-01.dmp
----- 32 bit Kernel Mini Dump Analysis
DUMP_HEADER32:
MajorVersion 0000000f
MinorVersion 00000a28
DirectoryTableBase 10f5f000
PfnDataBase 81051000
PsLoadedModuleList 8055a820
PsActiveProcessHead 80560938
MachineImageType 0000014c
NumberProcessors 00000001
BugCheckCode 1000008e
BugCheckParameter1 c0000005
BugCheckParameter2 b8551c94
BugCheckParameter3 bae15b48
BugCheckParameter4 00000000
PaeEnabled 00000000
KdDebuggerDataBlock 8054c460
MiniDumpFields 00000dff
TRIAGE_DUMP32:
ServicePackBuild 00000200
SizeOfDump 00010000
ValidOffset 0000fffc
ContextOffset 00000320
ExceptionOffset 000007d0
MmOffset 00001068
UnloadedDriversOffset 000010a0
PrcbOffset 00001878
ProcessOffset 000024c8
ThreadOffset 00002728
CallStackOffset 00002980
SizeOfCallStack 000004a8
DriverListOffset 000030b8
DriverCount 0000007f
StringPoolOffset 00005670
StringPoolSize 00001188
BrokenDriverOffset 00000000
TriageOptions 00000041
TopOfStack bae15b58
DebuggerDataOffset 00002e28
DebuggerDataSize 00000290
DataBlocksOffset 000067f8
DataBlocksCount 00000004
Windows XP Kernel Version 2600 (Service Pack 2) UP Free x86 compatible
Kernel base = 0x804d7000 PsLoadedModuleList = 0x8055a820
Debug session time: Thu May 10 19:40:44 2007
System Uptime: 0 days 0:46:57
start end module name
804d7000 806ebc00 nt Checksum: 002223D9 Timestamp: Wed Feb 28 10:54:58 2007 (45E55172)
Unloaded modules:
b7f98000 b7fc3000 kmixer.sys Timestamp: unavailable (00000000)
f8b4d000 f8b4e000 drmkaud.sys Timestamp: unavailable (00000000)
b857c000 b85a7000 kmixer.sys Timestamp: unavailable (00000000)
b870f000 b871c000 DMusic.sys Timestamp: unavailable (00000000)
b871f000 b872d000 swmidi.sys Timestamp: unavailable (00000000)
b8647000 b866a000 aec.sys Timestamp: unavailable (00000000)
f8ae7000 f8ae9000 splitter.sys Timestamp: unavailable (00000000)
b8b1e000 b8b2e000 Serial.SYS Timestamp: unavailable (00000000)
b898d000 b89a1000 Parport.SYS Timestamp: unavailable (00000000)
f88f5000 f88fa000 Cdaudio.SYS Timestamp: unavailable (00000000)
f8a31000 f8a34000 Sfloppy.SYS Timestamp: unavailable (00000000)
f88ed000 f88f2000 Flpydisk.SYS Timestamp: unavailable (00000000)
f88e5000 f88ec000 Fdc.SYS Timestamp: unavailable (00000000)
Finished dump check
Kako naj sedaj odkrijem vzrok problema?
Hvala lepa za odgovore.
Maximus ::
V google vpiši 0x1000008e in boš videl, kaj ti najde.
Sicer pa lahko vprašaš na http://www.windowsbbs.com/
nonenone ::
a imaš realtek zvočno?
slowie ::
Mislim, da je Zdrago precej blizu pravilnemu odgovoru. Iz osebnih izkušenj bi rekel, da se to zgodi, če je v strojni opremi omogočena kakšna v plato integrirana komponenta, pa se ne uporablja, ali pa se tepe s kakšno drugo komponento.
Jaz sem recimo že pred leti imel problem, ko sem kupil plato z AGP-slotom za grafiko, pa sem kljub temu dal grafično kartico v PCI slot, AGP pa je bil takrat prazen. Pri ugašanju računalnika sem redno na koncu dobival blue screen, dokler nisem v Device Manager onemogočil AGP. Točnih podrobnosti se sicer ne spomnim, ampak nekako tako je bilo, no.
Lp,
Slowie
"... So let's give our children a chance, okay?" [Douglas Adams]
BSOD problem
92239 (1897) Oktan
Windows XP Black screen
124789 (4529) Twix
Bluescreen
102421 (2123) slickerSLO
Podatki iz Memory-Dump-a?
202581 (2135) R33D3M33R
Kako razbrati minidump fajl ?
82339 (2146) Jst
