Medal of Honor in open GL error
Hardstyle ::
Ko zaženem MOHAA mi v konzoli javi to napako:
--- Common Initialization --- Medal of Honor Allied Assault 1.11 win-x86 Mar 5 2002 ----- FS_Startup ----- Current search path: C:\PROGRA~1\EAGAME~1\MOHAA/main C:\PROGRA~1\EAGAME~1\MOHAA\main\pak6.pk3 (104 files) C:\PROGRA~1\EAGAME~1\MOHAA\main\Pak5.pk3 (259 files) C:\PROGRA~1\EAGAME~1\MOHAA\main\Pak4.pk3 (593 files) C:\PROGRA~1\EAGAME~1\MOHAA\main\Pak3.pk3 (669 files) C:\PROGRA~1\EAGAME~1\MOHAA\main\Pak2.pk3 (4722 files) C:\PROGRA~1\EAGAME~1\MOHAA\main\Pak1.pk3 (772 files) C:\PROGRA~1\EAGAME~1\MOHAA\main\Pak0.pk3 (11175 files) ---------------------- 18294 files in pk3 files execing default.cfg execing menu.cfg execing newconfig.cfg Config: unnamedsoldier.cfg couldn't exec configs/unnamedsoldier.cfg execing safemode.cfg couldn't exec localized.cfg execing autoexec.cfg Unknown command "fov" couldn't exec custom.cfg ...detecting CPU, found AMD w/ 3DNow! ------- Input Initialization ------- Initializing DirectInput... Couldn't set DI coop level Falling back to Win32 mouse support... ------- Input Initialization Complete ------- 166 You are now setup for easy mode. ----- Client Initialization ----- Called FadeSound with: 0.000000 ----- Initializing Renderer ---- ----- R_Init ----- Initializing OpenGL subsystem ...initializing QGL ...calling LoadLibrary( 'C:\Windows\system32\opengl32.dll' ): succeeded ...setting mode 3: 640 480 FS ...using colorsbits of 16 ...calling CDS: ok ...registered window class ...created window@0,0 (640x480) Initializing OpenGL driver ...getting DC: succeeded ...GLW_ChoosePFD( 16, 16, 0 ) ...35 PFDs found ...GLW_ChoosePFD failed ...GLW_ChoosePFD( 16, 16, 0 ) ...35 PFDs found ...GLW_ChoosePFD failed ...failed to find an appropriate PIXELFORMAT ...restoring display settings ...WARNING: could not set the given mode (3) ...shutting down QGL ...unloading OpenGL DLL ...assuming '3dfxvgl' is a standalone driver ...initializing QGL ...WARNING: missing Glide installation, assuming no 3Dfx available ...shutting down QGL GLW_StartOpenGL() - could not load OpenGL subsystem
Sem že googlal pa sem našel rešitev samo za Windows XP jaz pa imam Windows Visto.
SasoS ::
Katero grafično imaš? V visti nekako še ni solidnih opengl driverjev :P
Senitel ::
Vista in OpenGL ni glih še za sprobavat...
No sound (Wolfenstein...)
Oddelek: Igre
152584 (2420) Slo-One
Problem z nvidio
171894 (1642) lanicorec
Medal of honor - patch!!!
Oddelek: Igre
273966 (3236) Deathlike M Tito
Problem z zagonom iger RTCW in MOHAA
Oddelek: Igre
153104 (2788) Flay
Wolfenstein in XP???! :o(
61480 (1382) zrebec
