Pentium 3 L2 cache
Pentium 3 L2 cache
r5r ::
Ali je možno, da imam na računalniku onemogočen L2 cache (265 kB)? Je mogoče BIOS ali/in jumper na matični plošči narobe nastavljen? Je mogoče L2 odpovedal na samem procesorju?
dmesg:
Initializing CPU#0
Detected 800.038 MHz processor.
Calibrating delay loop... 1595.80 BogoMIPS
Memory: 516048k/524224k available (1247k kernel code, 7788k reserved ...
CPU: L1 I cache: 16K, L1 D cache: 16K
CPU serial number disabled.
Intel machine check reporting enabled on CPU#0.
CPU: After generic, caps: 0383f9ff 00000000 00000000 00000000
CPU: Common caps: 0383f9ff 00000000 00000000 00000000
CPU: Intel Pentium III (Coppermine) stepping 06
Enabling fast FPU save and restore... done.
Enabling unmasked SIMD FPU exception support... done.
cpuinfo:
vendor_id : GenuineIntel
cpu family : 6
model : 8
model name : Pentium III (Coppermine)
stepping : 6
cpu MHz : 800.038
cache size : 32 KB
And it makes me wonder.
Carmack ::
Naloži si CPU-Z in boš vedel.... LINK
Edit: pa preveri še nastavitve v BIOS-u
BRIJAM, ŠIŠAM, ZUBE VADIM...
  • spremenil: Carmack ()
r5r ::
Nimam ravno fizičnega dostopa do računalnika ... bom v ponedeljek pogledal v BIOS ...
Vendor ID: "GenuineIntel"; CPUID level 2
Intel-specific functions:
Version 00000686:
Type 0 - Original OEM
Family 6 - Pentium Pro
Model 8 - Pentium III/Pentium III Xeon - internal L2 cache
Stepping 6
Reserved 0
Brand index: 2 [Pentium III processor]
TLB and cache info:
01: Instruction TLB: 4KB pages, 4-way set assoc, 32 entries
02: Instruction TLB: 4MB pages, 4-way set assoc, 2 entries
03: Data TLB: 4KB pages, 4-way set assoc, 64 entries
40: No 2nd-level cache, or if 2nd-level cache exists, no 3rd-level cache
08: 1st-level instruction cache: 16KB, 4-way set assoc, 32 byte line size
04: Data TLB: 4MB pages, 4-way set assoc, 8 entries
0c: 1st-level data cache: 16KB, 4-way set assoc, 32 byte line size
Tomay ::
In kaj je narobe če imaš 256K l2?
Koliko pa bi ga moral imeti?
Slot1 p2 in p3 so imele 512k l2, medtem ko so socket 370 p3 imele samo 256. Tako da to ni napaka ampak funkcija. >:D
Lahko pa preveriš tu
Voodoo 4Ever
  • spremenil: Tomay ()
r5r ::
Prepričan sem, da je onemogočen ...
Tomay ::
Preveri po SL kodi, pa boš videl.
Aja sem že jaz. Glede na to da je intel naredil samo eno p3 800 mhz ki ima 512 l2 in je na socket 479 pin (kar tvoja skoraj gotovo ni) se boš moral zadovoljiti z 256. Razen če znaš zelo dobro lotat. >:D
Voodoo 4Ever
navijanje della
Oddelek: Navijanje
61571 (1463) MecH
Navijanje celerona D
Oddelek: Navijanje
71724 (1634) SavoKovac
Predolgo nalaganje kernela
Oddelek: Operacijski sistemi
141831 (1707) BigWhale
180x5??? WCPUID se meša / C600@900
Oddelek: Navijanje
96760 (6616) TESKAn
HELP!!! Celeron 600 SL4NX (prava verzija za OC) problem
262152 (1982) Znida
