Forum » Omrežja in internet » 3COM US ROBOTICS ISDN PRO TA
gugi ::
Pozdravljeni!
Imam zgoraj omenjeni modem in ker sem ga po pomoti resetiral, mi sedaj ne dela analogna linija, kjer imam priklopljen faks.
Prosil bi vas katere parametre je potrebno nastaviti in kako, da bo analogna linija delovala. Spodaj imam parametre katere sem že nastavljal vendar mi ne dela.
Modem sem nastavljal s programom Hiper Terminalom in controlcenter.
Nastavitve "switch-ov"
Command:ATI12
3Com U.S. Robotics ISDN Pro TA Switch Settings...
Switch Protocol *W =0 EuroISDN
Phone Numbers (DN):
Area Code *P0=07
MSN1 *P1=XXXX130
MSN2 *P2=XXXX131
MSN3 *P3=
Multipoint *M =1 Multi-point
TEI *T1=255 Automatic
AO/DI *A =0 Disabled
Packet MSN *PD=
Packet TEI *TD=021 Fixed
Carrier *C0= Long Distance Packet Carrier
Rev. Charge *Y =0 Disabled
Device Status: Ready
*ATZ! Required* : Settings Have Changed
OK
Command:ATI15
3Com U.S. Robotics ISDN Pro TA Phone Port Settings...
Outgoing Voice Bearer Capabilities
Phone Port 1 #B1=0 3.1 Khz
Phone Port 2 #B2=0 3.1 Khz
Call Routing
Phone Port 1 #R1=2 XXXX131
Phone Port 2 #R2=2 XXXX131
Data Port *R =2 XXXX131
Volume Control
Phone Port 1 Receive #VR1=9 Transmit #VT1=3
Phone Port 2 Receive #VR2=9 Transmit #VT2=3
Supplementary Services
Phone Port 1 #S1=1
Voice coding #M =0 A-law
CallerID CLIR
Phone Port 1 #I1=1 #P1=1
Phone Port 2 #I2=1 #P2=1
Data Port #P3=1
OK
Command:ATI16
3Com U.S. Robotics ISDN Pro TA Data Protocol Settings...
Incoming Protocol *VI =5 PPP
Outgoing Protocol *VO =5 PPP
PPP mode *PPP=1 Transparent Async/Sync PPP
AO/DI with DBA *A0 =2 2B+D maximum
BACP *B =1 Enabled
Dial-out prefix for BACP callback *C1 =
Long Distance Dial-out prefix *C2 =1
Callback for AO/DI calls *C3 =0 Disabled
Dynamic Bandwidth Allocation Settings B1(AO/DI) B2(MLPPP)
Sample time to add B-channel *A1=10 *D1=5 Seconds
Sample time to drop B-channel *A2=360 *D2=180 Seconds
Threshold level to add B-channel *A3=80 *D3=75 %
Threshold level to drop B-channel *A4=10 *D4=50 %
Dynamic Voice Override *E=0 Disabled
Compression Mode *K=1 Auto Compression
MLPPP Endpoint Discriminator Class *U=0 Automatic
OK
Hvala in lp
Boštjan
Command:ATI12
Phone Numbers (DN):
Area Code *P0=07
MSN1 *P1=XXXX130
MSN2 *P2=XXXX131
MSN3 *P3=
Packet MSN *PD=
OK
Command:ATI15
Call Routing
Volume Control
Phone Port 1 #S1=1
CallerID CLIR
Data Port #P3=1
OK
Command:ATI16
BACP *B =1 Enabled
OK
Hvala in lp
Boštjan
gugi ::
No kje ste uporabniki "3com US Robotics ISDN pro ta" modemov. Kaj ste se že vsi posodobili.
Prosil bi tiste ki imate ta modem, da primerjate parametre.
lp Boštjan
lp Boštjan
Tole temo si si mogoče že ogledal?
| » | Problemi pri dobivanju Fax-aOddelek: Pomoč in nasveti | 1725 (1628) | Catcher |
| » | ISDN. 101 + FAXOddelek: Omrežja in internet | 1718 (1618) | nero |
| » | iz ISDN v ANALOGNO linijo - kako NAJCENEJE ?Oddelek: Elektrotehnika in elektronika | 2035 (1873) | cekr |
| » | Linux rookieOddelek: Operacijski sistemi | 2448 (2026) | dr.J |
| » | ISDN modemOddelek: Kaj kupiti | 960 (850) | Joze_K |
