Forum » Omrežja in internet » ASUS RX3041 firewall
leon_boy ::
Nabavil sem router ASUS RX3041, kateri ima vgrajen tudi firewall. Sam priklop in povezava z internetom mi ni delala težav. Mi je pa sumljivo glede firewall-a. V nastavitvah piše, da je firewall "enabled" in vendar... ob zagonu programov kot sta uTorrent, DC++ in še nekaj drugih, vse lepo deluje. Kolikor je meni znano nebi smeli loudati dokler jim ne odprem porta. Mi lahko kdo svetuje, ki ima ta router in ima izkušnje z njim.
whatever ::
Mam ta router in mi dela enako - emule dela kar po defaultu, pa nisem šel posebej forwardat portov. Torrentov pa ne uporabljam. Nastavitve so pa skoraj vse na default, tudi jaz nimam UPnP enablan.
Veliko jih je notri, še več jih je pa zunaj.
Bilijarde v šole! - Ivan Kramberger
Abnormal behaviour of abnormal brain makes me normal.
- spremenilo: whatever ()
flier ::
Sicer torrent dela tudi ce ne odpiras portov a potem se poveze samo s peeri ki imajo odprt firewall. Pa sta prepricana da je firewall vklopljen (obstajajo online testi, mislim da je eden na Sygate-ovi strani) ?
whatever ::
Po temle linku sodeč, naj bi firewall na routerju deloval normalno...
Traffic Sent
Packets were successfully sent to your computer. The server was unable to obtain a connection or any traffic from your computer. This generally indicates that your firewall blocked the traffic successfully.
If you did not see an event warning it may indicate that the traffic did not reach your computer at all.
This could be due to any of the following reasons:
* You are connecting to the Internet through a proxy server. When we attempted to connect back to the IP address your web traffic came from we actually were connecting to the proxy server, not your computer.
* You are behind a corporate firewall which is redirecting traffic in an unexpected manner.
* You are connecting to the Internet through a NAT (network address translator). When we attempted to connect back to the IP address your web traffic came from we actually were connecting to the proxy server, not your computer.
In any of these cases you will not see an event notification on your computer because our connection attempt did not reach your computer. In any case, your computer is secure.
Traffic Sent
| » | VarnostOddelek: Informacijska varnost | 24943 (6644) | techfreak :) |
| » | Security AlertOddelek: Omrežja in internet | 1293 (1194) | bluefish |
| » | Iptables in C&C GeneralsOddelek: Igre | 2485 (2254) | Tito |
| » | ZoneAlarm in ApacheOddelek: Omrežja in internet | 1623 (1528) | govno |
| » | Kateri Firewall priporocate in zakaj?Oddelek: Pomoč in nasveti | 4802 (4273) | ferjan |
