Kako prenesti video iz spletne strani?
rontajzel ::
Pozdravljeni!
Mene pa zanima, če obstaja kakšen program s katerim bi lahko recimo iz spletnega portala 24ur.com prenesel recimo novice na disk in si jih kasneje ogledal.
Hvala za odgovore!
PS: Če tema obstaja bi prosil za link, kajti sam sem se mučil z iskalnikom, vendar nisem našel teme :S
~rontajzel~
AMD A64 3800+ X2; ASUS A8N-E ULTRA; ATI RX1600pro;LC600W; DDR 3GB; SATAII 820GB
StratOS ::
Če misliš na stream vsebino :
preglej si tale post.
bistvo ti je, da pogledaš ( tam, kjer je pač video clip ) source :
<script language="JavaScript" type="text/javascript">
var url_rm  = '/bin/gen_smil.smil?media_id=16163736&time=1170716400&section_id=2&in_archive=0';
var url_wmv = '/bin/gen_asx.asx?media_id=16163736&time=1170716400&section_id=2&in_archive=0';
video_show();
</script>
pregledaš asx na http://24ur.com/bin/gen_asx.asx?media_id=16163736&time=1170716400&section_id=2&in_archive=0'
ter dobiš :
<asx version="3.0">
    <PARAM NAME="Prebuffer" VALUE="true" />
    <PARAM NAME="CanSeek" VALUE="no" />
    <PARAM NAME="ShowWhileBuffering" VALUE="true" />
    <title>24ur.com Video</title>
   <entry>
        <ref href="mms://streamv.24ur.com/24ur.com/2007-02/16163736-1.wmv" />
    </entry>
</asx>
Uporabi program za download streamov, najdeš jih na googlu.
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
  • spremenila: StratOS ()
rontajzel ::
Točno to sem želel, hvala za odgovor.
~rontajzel~
cabac ::
Zdravo,
sem našel to temo, pa bom vprašal kar tukaj.
Kako si lahko prenesem video s te strani: http://euscreen.eu/ ? Razni online grabberji ne delujejo... ima kdo kakšno idejo?
Hvala!
smacker ::
Tile so se pa zaščitli malo:
EUscreen offers thousands of items of film and television clips, photos and texts provided by audiovisual archives from all over Europe.
Are you interested in using a clip from our collection? Please go to the item page and click on the copyright symbol ((C)) under the video player and then click "contact the provider" and you can fill a form wherein you can ask for the rights to reuse it.
Excavator ::
Screen recorder...
cabac ::
Kateri screen record pa je ok in free? Ker je vedno neka finta - ali je omejen na čas ali pa ne snema zraven zvoka.
grašek ::
- Nvidia shadowplay (če imaš Nvidia grafično)
- OBS (zastojn)
klinker ::
Ce mas dostop do kakega Maca je se najbolj enostavno z Quick Time. Lahko tudi oznacis le del zaslona, ki hoces da snema.
konspirator ::
firefox + netvideo hunter.
catch, ko ga hočeš dl z browserjem:
Forbidden
The server understood the request, but is refusing to fulfill it
You can get technical details {here}.
Please continue your visit at our {home page}.
ali če poženeš network inspector iz browserja, ko imaš odprto stran in refreshaš, type: "media"
Opening of the Nuremberg trials
Request URL:
http://stream12.noterik.com/progressive/stream12/domain/euscreen/user/eu_ina/video/863/rawvideo/1/raw.mp4?ticket=26018686
konspirator ::
Če se video do konca predvaja v enem kosu, potem ga lahko skopiraš iz browser cacha.
Recimo.
cabac ::
konspirator je izjavil:
Recimo.
Kako to nardim, se ti da napisati bolj podrobno?
kako film, ki se predvaja v brskalnuki prenesti na disk (strani: 1 2 )
6720030 (13047) SLO_Matej
24 ur prispevek - ?spremenjeno?
82116 (1758) mjk
Windows Media Player 11
Oddelek: Programska oprema
343122 (2735) joker16_7
IE 7 ali FF ne predvaja nekaterih video vsebin (strani: 1 2 )
539768 (8849) HitriPepe
Program za video (flash) vodiče
Oddelek: Izdelava spletišč
182409 (2161) dejc2
