Iskanje-pomoč!
Iskanje-pomoč!
n1-gik ::
V meniju start izberem iskanje, vendar mi napiše da datoteke ki je potrebna za zagon spremljevalca pri iskanju, ni mogoče najti.Morda boste morali zagnati namestitev.
Res potrebujem vašo pomoč!
StratOS ::
To reinstall the search assistant :
NOTE: You must be logged on as Administrator or as a member of the Administrators group in order to perform this procedure.
Click Start , click Run , and then type the following command:
%systemroot%\inf
NOTE : There are no spaces at all in the preceding command line.
Click OK to open the INF folder.
Locate the file Srchasst.inf .
Right-click the file, and then click Install . This will reinstall the files that Search needs to proceed normally.
You will be asked to place your windows XP cd rom in the drive.
vir : Tukaj
"Multitasking - ability to f##k up several things at once."
"It works better if you plug it in."
"The one who is digging the hole for the other to fall in is allready in it."
n1-gik ::
StratOS res ti hvala!
atikmdag.sys - rabim pomoč
257332 (5815) The Player
Wireless kartica ne deluje na win 7
Oddelek: Omrežja in internet
152350 (2192) kratos
Šifrirana mapa
Oddelek: Operacijski sistemi
92832 (2303) amigo_no1
Windows 7 Installer (64-bit) - težave
Oddelek: Programska oprema
153706 (3096) fr!Xy
Ne predvaja novega audio CD
52606 (2562) Tea Time
