Boot Win XP Home problem
Gogo ::
Živjo
Rabim pomoč slo-tehovcev.
Namreč ob zagonu Win XP Home mi pred Win logom napiše:
system 32\ntoskrnel.exe is corrupt reinstall or copy file
Kaj sedaj? Pomoč bo več kot dobrodošla.
gogo
Gigabyte Aorus B550 Elite|Ryzen 3 3100|Gainward RTX 2060 Ghost, 6 GB GDDR|
TG Delta RGB 16GB CL 16|ADATA XPG SX8200 PRO 512GB NVMe SSD M.2|
Chieftec Photon Series 650W RGB ATX| Antec PerformanceOne P7 Silent Black|
Bootaj z Windows CDja pa daj repair.
Gogo ::
Hja, to že. Vendar prideš v konzolo. Kaj pa potem? Tu se sploh ne znajdem?
Ker je na PC en sistem, dam št. 1 kjer je c: in potem dobim le ukazno vrstico. Naprej pa nimam pojma.
Step by step lepo prosim, če se le da.
Thx by gogo.
This is the command you need to run from the Recovery Console...
expand E:\i386\ntoskrnl.ex_ C:\Windows\system32
... with the XP CD still in the drive. The above command expands (extracts) a copy of the ntoskrnl.exe file from the CD, and copies it to the %systemroot%\system32 directory. When asked if you'd like to overwrite the file, hit the Y key.
Gogo ::
He, he za par sekund si me prehitel kar sem spraševal strica Googla. :D
Hvala vseeno.
Tule sta še dva linka, do pomoči:
ntoskrnel.exe Help #1 in ntoskrnel.exe Help #1
gogo
Windows XP Black screen
124779 (4519) Twix
Win 7 blue screen in restart
Oddelek: Operacijski sistemi
132913 (2652) Duhec
sygate firewall:kaj je datoteka ntoskrnl ??
6914 (865) Matey_kp
ntoskrnl.exe problem
51517 (1450) ERGY
Racunalnik ne vidi vec particije
91787 (1633) Kunte
