Forum » Strojna oprema » Procesor
Procesor
kekec135 ::
Imam procesor AMD Athlon 64 3500+ . Odlocil sem se, da si bom formatiral racunalnik in me zanima , ce rabim kaksne drivere za procesor al ne?
- premaknilo iz Pomoč in nasveti: bastadu ()
bluefish ::
AMD Athlon™ 64/FX Processor Driver for Windows XP and Windows Server 2003 Version (x86 and x64 exe) 1.3.2.16 - Allows the system to automatically adjust the CPU speed, voltage and power combination that match the instantaneous user performance need. Download this Setup Installation program (EXE) to automatically update all the files necessary for installation. This package is recommended for users whom desire a graphical user interface for installation. This .EXE driver is a user friendly localized software installation of the driver designed for end-users. This driver supports AMD Athlon 64/FX processors on Windows XP SP2, Windows 2003 SP1 x84 and x64 Editions.
lanicorec ::
driveri za procesor?haha.bios ti sam zazna procesor.sam boš pa windowse na novo mogo naložit.lp
ricola78 ::
Ta driver rabiš, če hočeš uporabljat funkcijo cool&quiet. Recimo ko ne delaš nič procesorsko zahtevnega, pade frekvenca recimo na 1200MHz. Ter napetost se zniža na 1.1.
- spremenil: ricola78 ()
| » | AMD Cool'n'QuietOddelek: Hlajenje in modifikacije | 1909 (1872) | Kron |
| » | Novi RacuanlnikOddelek: Pomoč in nasveti | 1246 (1100) | jishiri |
| » | Dolgo nalaganje WindowsovOddelek: Operacijski sistemi | 3244 (2649) | Tonći |
| » | vklop Cool'n'Quiet tehnologijeOddelek: Strojna oprema | 3393 (2554) | Azrael |
| » | Cool `n` Quiet Control in AMD 64Oddelek: Pomoč in nasveti | 3464 (2215) | Racunalnik |
