Forum » Omrežja in internet » [SAMBA] ERRDOS - ERRnosuchshare (You specified an invalid share name)
Andruxa ::
Po reinstalaciji sistema ne morem vec do svojega share-a na drugem racunalniku ki ima Samba Version 3.0.14a-Ubuntu. Do share-a lahko pridem z smbclient in iz Windowsev, medtem ko mount -t smbfs vrne :
4186: tree connect failed: ERRDOS - ERRnosuchshare (You specified an invalid share name)
SMB connection failed
Nekaj komand :
>uname -r
2.6.17-gentoo-r8
> ping misko
dobim tole :
PING misko.andrix (192.168.0.22) 56(84) bytes of data.
64 bytes from misko.andrix (192.168.0.22): icmp_seq=1 ttl=64 time=0.211 ms
64 bytes from misko.andrix (192.168.0.22): icmp_seq=2 ttl=64 time=0.181 ms
64 bytes from misko.andrix (192.168.0.22): icmp_seq=3 ttl=64 time=0.172 ms
> smbtree
dobim tole :
\\MISKO Misko Skl
\\MISKO\ADMIN$ IPC Service (Misko Skl)
\\MISKO\IPC$ IPC Service (Misko Skl)
\\MISKO\LOG Misko Logs
\\MISKO\PARANGAL Mula Odl
> smbclient //192.168.0.22/PARANGAL -U root
dobim tole :
Domain=[MISKO] OS=[Unix] Server=[Samba 3.0.14a-Ubuntu]
smb: \>ls
. D 0 Mon May 15 20:14:55 2006
.. D 0 Tue Nov 28 21:08:51 2006
Shrd D 0 Fri Aug 18 15:20:43 2006
Temp D 0 Tue Nov 28 20:14:50 2006
Dine D 0 Tue Nov 28 21:22:14 2006
57525 blocks of size 2097152. 22832 blocks available
In koncno PROBLEM :
> sudo mount -t smbfs //192.168.0.22/PARANGAL /mnt/Misko -o username=root
ALI
> sudo mount -t smbfs //MISKO/PARANGAL /mnt/Misko -o username=root
dobim tole :
Password:
... lahko pa odprem share tudi z WinXP masine takole : \\192.168.0.22\PARANGAL.
Ce ima kdo kaksno idejo ...
Nekaj komand :
>uname -r
2.6.17-gentoo-r8
> ping misko
dobim tole :
> smbtree
dobim tole :
\\MISKO Misko Skl
dobim tole :
smb: \>ls
In koncno PROBLEM :
ALI
dobim tole :
Password:
Lp, A
Andruxa ::
Vmes sem se enkrat reinstaliral servercek, ker sem domneval da je problem v razliki v verziji sambe na serverju in clientu in problem je ostal. No, na koncu sem ob spremljanju logov pogruntal nekaksen workaround ceprav mi vzrok se vedno ni jasen. premalo poznam sambo. Fora je vtem, da ce uporabim smbclient ali smbtree dobi samba server hostname od klienta in ker imam jaz share definiran na podlagi hostname-a je to delovalo. Ce pa sem poskusal share mount-ati pa je samba server dobil ip namesto hostname-a in samba je v skladu s konfiguracijo skrila share. Torej sem za workaround moral skopirati smb.conf.HOSTNAME v smb.conf.IP, kjer .HOSTNAME velja za smbclient in.IP velja za mount. Sedaj deluje.
Lp, A
| » | Lan over elektrikaOddelek: Zvok in slika | 1584 (1060) | Zvezdica27 |
| » | Odzivni čas v nanosekundahOddelek: Omrežja in internet | 1729 (1455) | Spc |
| » | Router zviša ping???Oddelek: Omrežja in internet | 2926 (2037) | bzp |
| » | Najmanjši ping v 100Mbit in 1000Mbit omrežjih.Oddelek: Omrežja in internet | 3066 (2557) | gumby |
| » | Ubuntu & Windows XP deljenje pvoezaveOddelek: Operacijski sistemi | 2082 (1969) | Poldi112 |
