Forum » Programiranje » [Naloga][Java] Ulomki
bijonda ::
Ciao!
Simple nalogica, a meni dela tezave.
Imam glavni razred Ulomek. Razred se mi lepo prevede. Zraven sem se napisala, testni razred TestUlomek, da vidim, ce mi glavni razred dela kakor treba. Vendar se mi ne prevede.
Glavni razred.
Testni razred:
ter napake ko zazenem testni program
TestUlomek.java:7: unreported exception java.lang.Exception; must be caught or declared to be thrown
Ulomek a = new Ulomek(2,5);
\TestUlomek.java:8: unreported exception java.lang.Exception; must be caught or declared to be thrown
Ulomek b = new Ulomek(3,4);
\TestUlomek.java:28: unreported exception java.lang.Exception; must be caught or declared to be thrown
System.out.println(a + " = " + c + " ? " +a.compareTo(c));
\TestUlomek.java:33: unreported exception java.lang.Exception; must be caught or declared to be thrown
System.out.println("Vsota ulomka: "+ a.vsota(b)+ " pri cemer je a = "+a+ " in b = " +b+ ".");
\TestUlomek.java:46: unreported exception java.lang.Exception; must be caught or declared to be thrown
System.out.println(a + " - " + b + " = " + a.razlika(b));
\TestUlomek.java:59: unreported exception java.lang.Exception; must be caught or declared to be thrown
System.out.println(a + " * " + b + " = " +a.zmnozek(b));
\TestUlomek.java:71: unreported exception java.lang.Exception; must be caught or declared to be thrown
System.out.println(a.kvocient(b));
A kdo ve kako bi lahko odpravla te napake.
Hvala vsem!
Ciao ciao
Glavni razred.
public class Ulomek {
// komponente
private int st; // komponenta za stevec
private int im; // komponenta za imenovalec
// konstruktorji
// konstruktor, ki sprejme vrednost stevca in imenovalca ter nastavi vrednost komponent st in im
public Ulomek(int a, int b) throws Exception{
if(b != 0){
this.st = a;
this.im = b;
else{
throw new Exception("To ni ulomek. Imenovalec ne sme biti enak 0!");
// konstruktor, ki sprejme celo stevilo a in naredi ulomek a/1
public Ulomek(int a) {
this.st = a;
this.im = 1;
// prazni konstruktor
public Ulomek(){
this.st = 1;
this.im = 1;
// Metode
// primerjava ulomkov
// ce je ulomek x enak ulomku this
public boolean equals(Ulomek x) {
return x.st * this.im == this.st * x.im;
// vrne niz znakov, ki predstavlja ulomek (npr. new Ulomek(6,8), predstavimo z nizim "6/8")
public String toString(){
if(this.im == 1) {
return Integer.toString(this.st);
return this.st + "/" + this.im;
/* primerja ulomka x in this in vrne:
negativnos tevilo, ce je this < a
stevilo 0, ce je this = a
pozitivno stevilo, ce je this > a
public int compareTo(Ulomek x)throws java.lang.Exception {
Ulomek razlika = this.razlika(x);
razlika.okrajsaj();
return razlika.st;
// pokrajsamo ulomek
public void okrajsaj() {
int d = gcd(this.st, this.im);
this.st = this.st / d;
this.im = this.im / d;
if(this.im < 0) {
this.im = -this.im;
this.st = -this.st;
// izracunamo najvecji skupni delitelj dveh celih stevil
public static int gcd(int x, int y) {
x = Math.abs(x);
y = Math.abs(y);
if (y == 0) {
return x;
else {
return gcd(y, x%y);
// Vsota
/* metodi vsota in pristejUlomek imata enako funkcijo, sestejeta dva ulomka
razlikujeta pa se v tem, da metoda vsota, objekta, na katerm jo klicemo,
ne spremeni
public Ulomek vsota (Ulomek x) throws java.lang.Exception{
return new Ulomek(x.st * this.im + x.im * this.st, x.im * this.im);
// tu dobi stevec novo vrednost, ki je enaka vsoti
public void pristejUlomek(Ulomek y) {
this.st = this.st * y.im + this.im * y.st;
this.im = this.im * y.im;
// Razlika
/* metodi razlika in odstej imata enako funkcijo, odstevanje dveh ulomkov
razlikujeta pa se v tem, da metoda razlika, objekta, na katerm jo klicemo,
ne spremeni
public Ulomek razlika(Ulomek x) throws java.lang.Exception {
return new Ulomek(this.st * x.im - this.im * x.st, this.im * x.im);
// tu dobi stevec novo vrednost, ki je enaka razliki
public void odstej(Ulomek x) {
this.st = this.st * x.im - this.im * x.st;
this.im = this.im * x.im;
// Produkt
/* metodi zmnozek in zmnozi imata enako funkcijo, zmnozita dva ulomka
razlikujeta pa se v tem, da metoda zmnozek, objekta, na katerm jo klicemo,
ne spremeni
// tu imenovalec in stevec ostaneta enaka
public Ulomek zmnozek(Ulomek x) throws java.lang.Exception{
return new Ulomek(this.st * x.st, x.im * this.im);
// tu stevec dobi novo vrednost, ki je enaka produktu
public void zmnozi(Ulomek x) {
this.st = this.st * x.st;
// Kvocient
/*metodi kvocient in deli imata enako funkcijo, delita dva ulomka
razlikujeta pa se v tem, da metoda kvocient, objekta, na katerm jo klicemo,
ne spremeni
//Delenje ulomkov
public Ulomek kvocient(Ulomek x)throws Exception {
if (st != 0 && im != 0){
return new Ulomek(this.st * x.im, x.st * this.im);
else{
throw new Exception("To ni ulomek.");
// tu dobi stevec novo vrednost, ki je enaka kvocientu
public void deli(Ulomek x) {
this.st = this.st * x.im;
this.im = this.im * x.st;
Testni razred:
// testni program
public class TestUlomek {
public static void main(String[] args){
// naredimo nekaj ulomkov
Ulomek c = new Ulomek(3);
// preizkusanje metod
// metodo equals
// primerjava dveh ulomkov, v nasem primeru ulomka a in b
if (a.equals(b) == true)
System.out.println("Ulomka a = " + a +" in b = " + b +" sta enaka.");
else
System.out.println("Ulomka a = " + a +" in b = " + b +" sta razlicna.");
System.out.println();
// objektna metoda comareTo
// ce je ulomek a < c nam metoda vrne negativno stevilo
// ce je ulomek a = c nam metoda vrne stevilo nic
// ce je ulomek a > c nam metoda vrne pozitivno stevilo stevilo
// Vsota
// izracunamo vsota dveh ulomkov
//ulomku a pristej ulomek b in od tu naprej ima ulomek a novo vrednost
System.out.println("a = " +a);
a.pristejUlomek(b);
System.out.println("Nova vrednsot ulomka a = " + a);
//Razlika
// od novega ulomka a odstejemo staro vrednost ulomka b
System.out.println("Od ulomka a odstejemo ulomek b.");
// od novega a odstejemo b in a dobi novo vrednost
System.out.println("Od ulomka a = " +a+ " odstejemo ulomek b.");
a.odstej(b);
System.out.println("Nova vrednost ulomka a = " + a + ", po opravljeni operaciji.");
// Produkt
//Objektni metodi za mnozenje
// zmnozimo ulomka skupaj
System.out.println("Produkt ulomkov a in b.");
// Ulomek a mnozimo z ulomkom b, ter ulomek a dobi novo vrednost
a.zmnozi(b);
System.out.println("Nova vrednost ulomka a = "+ a + ", po opravljeni operaciji.");
//Kvocient
// Delenje ulomkov
System.out.println("Ulomek a delimo z ulomkom b.");
// delimo ulomka in v ulomek a shranimo novo vrednost
a.deli(b);
Hvala vsem!
Ciao ciao
- spremenilo: CCfly ()
nietka ::
Nisem niti pod razno programer, ampak sklepala bi, da ti manjka throws Exception v glavni funkciji.
Great warrior? Wars not make one great.
BigFoot ::
Povsod kjer imaš throw exception moraš dati še catch.
LG 77CX OLED TV; Marantz SR6010 7.2: 5x Focal Sib, 2x Focal Cub, 2x Focal
Little Bird; PS5 Pro, Xbox Series X, PS4 Pro, Xbox One, PS3, Vero 4K, Samsung
UBD K8500 4K UHD, Philips BDP2180/12
bijonda ::
To mislis try - catch! Neki sem ze pobala, pa ni glih slo!
Najprej sem imela nalogo brez exception, razen pri konstruktorju. Pa mi je javlal napako pri metodah, kjer imam zdaj Exception-e.
Kako predlog kaj naj naredim?
bad_dog ::
Evo. K testnemu programu dodaš za try{ ... } catch(Exception e) {} . To potem izgleda takole:
Sem probal in dela.
try {
...telo programa...
a.deli(b);
} catch (Exception e) {}
Sem probal in dela.
SkIDiver ::
Ali pa bi sam takole napisala glavo metode pa bi tud delalo, da se ne matraš s try-catch bloki, ki se mi zdi, da niso še predmet tvojega učenja?
public static void main(String[] args) throws Exception {
| » | [JAVA] HTTPS clientOddelek: Programiranje | 3692 (2422) | peterv6i |
| » | Naloga iz Putka - UPMOddelek: Programiranje | 2710 (2046) | NejcSSD |
| » | Obratna vrednostOddelek: Programiranje | 1658 (1590) | mgermo |
| » | [Naloga] Eulerjevo številoOddelek: Programiranje | 3595 (2947) | gani-med |
| » | [JAVA] zaustavitev niti (threadov)Oddelek: Programiranje | 3698 (3698) | morbo |
