Forum » Navijanje » Pomoc glede rama ter maticne !!!
ALes20 ::
Pozdravljeni rad bi navil svojo matično Intel i845PE z procesorjem P4 2.4 Mhz tako da bi lahko iztocasno povecal fsb na maticni zato ker imam ramDDR-SDRAMPC3200(200 MHz)[DDR-400] problem je v tem ker imam trenutno procesor navit na 2.6 (146 fsb) in mam bus fsb na maticni 181.5 mhz rad bi pa imel 200 da bi bolj izkoristil Ram. Samo kar navijem vec kot 2.6 mhz sistem ni vec stabilen in se sesuva rac. Temparetura pa ni vzrok ker se giblje med 28 in max 42 povprecna je 33. Tko da prosam ce mi pomagate ker sam nimam dovolj izkusenj spodaj je se nekaj podatkov o moji skatli hehe :) aja pa sory za slovnicne napake dont be mad !!! Hvala Ales
Maticna
General Information :
NorthBridge : Intel i845PE
SouthBridge : 82801DB/DBL (ICH4/ICH4-L) LPC Interface Bridge
NorthBridge Information :
Architecture : HUB
Manufacturer : Intel (Epox Computer Co Ltd)
Codename : Brookdale-G
Revision : B0
FSB Frequency : 145.2 MHz
Bus Speed : 580.9 MHz (QDR)
Memory Frequency (max.) 166.67 MHz
Memory Information :
Type : DDR-SDRAM PC2900
Frequency : 181.5 MHz
FSB/RAM Multiplier : 4/5x
Activated Channels : Single
ECC Diagnostic : Ne
CAS Latency (tCL) : 2.5 clocks
RAS to CAS (tRCD) : 3 clocks
RAS Precharge (tRP) : 3 clocks
Cycle Time (tRAS) : 7 clocks
DRAM Idle Timer : 16 clocks
Ram:
Manufacturer Kingston
Part Number K
Serial Number 6F25705A
Type : DDR-SDRAM PC3200 (200 MHz) - [DDR-400]
Size : 512 MB (2 rows, 4 banks)
Module Buffered : No
Module Registered : No
Width : 64-bit
Error Correction Capability : No
Max. Burst Length : 8
Refresh : Reduced (.5x)7.8 µs, Self Refresh
Voltage : SSTL 2.5v
Manufacture : Week 37 of 2001
Supported Frequencies : 166 MHz, 200 MHz
CAS Latency (tCL) : 2 clocks @166 MHz, 2.5 clocks @200mhz
RAS to CAS (tRCD) : 3 clocks @166 MHz, 3 clocks @200 MHz
RAS Precharge (tRP) : 3 clocks @166 MHz, 3 clocks @200 MHz
Cycle Time (tRAS) : 7 clocks @166 MHz, 8 clocks @200 MHz
Procesor
Real Frequency : 2614.04 MHz
Multiplier : 18x
Low/High Multiplier : 18x / 18x
Multiplier Locked : Yes
Marketing Frequency : 2394 MHz
Front Side Bus Information :
Initial Frequencies :
Frequency : 2400 MHz
FSB Frequency : 133 MHz
Multiplier : 18x
Upam da je vse kar zelite vedeti. Hvala Ales
Maticna
Architecture : HUB
Revision : B0
ECC Diagnostic : Ne
Ram:
Part Number K
Width : 64-bit
Voltage : SSTL 2.5v
Procesor
Multiplier : 18x
Multiplier : 18x
PEK- ::
Najprej probaj zvisat nekoliko Voltazo proca, pa probaj na 200mhz.
Drugace pa mas v biosu nekje... FSB/DDR ali pa HOST/DRAM clock ratio. Recimo ce bi mel nenavito bi mel FSB/DDR = 1/3.
Sicer pa nevem ce te plosce podpirajo DDR400.
ALes20 ::
ja prov zaprov sm spravu ze maticno na 385 sam pol racunalnik ni bil vec stabilen. Ker je bil iz 2,4 na 2,8 mhz. In ce hocm met 400drr morm met na 2,8 zdej pa kolk nej jz povecam voltazo !
| » | Nadgradnja DDR400 RAM-aOddelek: Strojna oprema | 1819 (1658) | ignis |
| » | Mticna plosca i845PeOddelek: Strojna oprema | 1928 (1711) | mtosev |
| » | A se da navit RAM!!!!!Oddelek: Navijanje | 1517 (1352) | JIM22 |
| » | AMD 2500+ & Abit NF7Oddelek: Navijanje | 2820 (2066) | Wad@ |
| » | ram PC3200 deluje kot PC2700Oddelek: Strojna oprema | 1791 (1698) | drejcmb |
