Forum » Omrežja in internet » Active DHCP Client
Active DHCP Client
Zeratrem ::
Router mi ne kaze Active DHCP Clients, v system log pa se ponavlja:
Jan 1 00:01:55 pppd[1679]: RP-PPPoE plugin version 3.3 compiled against pppd 2.4.4b1
Jan 1 00:01:55 pppd[1679]: pppd 2.4.4b1 started by root, uid 0
Jan 1 00:01:55 pppd[1679]: PPP session is 125
Jan 1 00:01:55 pppd[1679]: Using interface ppp0
Jan 1 00:01:55 pppd[1679]: Connect: ppp0 --- eth1
Jan 1 00:01:55 pppd[1679]: Couldn't increase MRU to 1500
Jan 1 00:01:56 pppd[1679]: CHAP authentication succeeded
Jan 1 00:01:56 pppd[1679]: peer from calling number 00:90:1A:41:45:B8 authorized
Jan 1 00:01:56 pppd[1679]: local IP address 86.61.73.246
Jan 1 00:01:56 pppd[1679]: remote IP address 213.250.19.90
Jan 1 00:01:57 pppd[1679]: primary DNS address 193.189.160.13
Jan 1 00:01:57 pppd[1679]: secondary DNS address 193.189.160.23
Aug 26 13:01:24 udhcpd: Received a SIGUSR1
Aug 26 13:01:32 udhcpd: Received a SIGUSR1
Aug 26 13:01:54 udhcpd: Received a SIGUSR1
Aug 26 13:03:11 udhcpd: Received a SIGUSR1
Aug 26 13:03:12 udhcpd: Received a SIGUSR1
Aug 26 13:03:48 udhcpd: Received a SIGUSR1
Aug 26 13:05:21 udhcpd: Received a SIGUSR1
Aug 26 13:05:37 udhcpd: Received a SIGUSR1
Aug 26 13:06:33 udhcpd: Received a SIGUSR1
Internetna povezava na obeh racunalnikih, ki sta povezana na router deluje, vendar pa se ne moreta med seboj pingati. Ne glede na to, da router nima zabelezenega IPja, imata oba racunlnika svoj ip, ki jima ga je dodelil router.
Kako lahko popravim to zadevo?
Hvala za pomoc.
Hvala za pomoc.
- spremenilo: Zeratrem ()
jeso ::
Se pravi, da te zanima ip, katerega dodeli router?
Na računalniku, za katerega hočeš ip naredi tole:
start->run->cmd->ipconfig
pa ti ga bo izpisalo.
Še boljše pa bi bilo da jima sam nastaviš neke fiksne ip-je.
- spremenil: jeso ()
Zeratrem ::
Ne, problem ni v tem, da bi me zanimali ipji, ampak v tem, da glede na za izpis
itn.
nekaj ni v redu z routerjevim zaznavanjem ipjev.
itn.
Zeratrem ::
Skratka, to je na routerju prazno:
This table shows the assigned IP address, MAC address and time expired for each DHCP leased client.
IP Address MAC Address Time Expired(s)
None
None
| » | OpenWRT in OpenVPN (strani: 1 2 )Oddelek: Omrežja in internet | 13194 (11054) | BivšiUser2 |
| » | Mobitel InternetOddelek: Omrežja in internet | 2199 (1923) | popster |
| » | PPP: Input/output errorOddelek: Omrežja in internet | 1939 (1777) | b |
| » | [pppoe povezava] Couldn't increase MRU/MTU to 1500Oddelek: Operacijski sistemi | 2104 (1958) | NeOman |
| » | ADSL modem hangupOddelek: Pomoč in nasveti | 1588 (1452) | 3LeR. |
