Pomoč, prosim...
Pomoč, prosim...
SLOWWWeb.net ::
Sem si postavil en WEB server, pa ne vem al mi dela samo lokalno al sem tudi nvzven odprt?
TEST 1 TEST 2 TEST 3
Prosim, pomagajte. :'(
Napišite, al se naloži vsa vsebina, dela vse tako kot mora,...
__________________________________________________
WEBhosting / WEBdesign / WEBdomain / Security solutions
BREZPLAČNI marketinški nasveti za podjetja in www strani
CaqKa ::
meni so se vse tri strani nalozle... samo so dolgo rable
msmiha ::
Dela vse lepoin prav:D
ChiefThunder ::
same here...
... po liniji najmanjšega odpora. ;)
bigk ::
Tudi meni se vse prikaže, se pa dolgo nalaga...;)
l.p.
//bigk K
SLOWWWeb.net ::
Kolk dolg...
Mi lahko se poveste iz katerga ISPja prihajate in če naredite en ping na IP: 193.189.174.191 :8) .
SLOWWWeb.net ::
P.S.: Prosim se za cas nalaganja :D
CaqKa ::
arnes.. newem zakaj se je dolgo nalagalo ker imam sicer kabl
ping:
Pinging 193.189.174.191 with 32 bytes of data:
Reply from 193.189.174.191: bytes=32 time=245ms TTL=124
Reply from 193.189.174.191: bytes=32 time=189ms TTL=124
Reply from 193.189.174.191: bytes=32 time=98ms TTL=124
Ping statistics for 193.189.174.191:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 98ms, Maximum = 245ms, Average = 194ms
bigk ::
Sem na kablu in imam takle ping:
Reply from 193.189.174.191: bytes=32 time=209ms TTL=124
Reply from 193.189.174.191: bytes=32 time=128ms TTL=124
Reply from 193.189.174.191: bytes=32 time=124ms TTL=124
Minimum = 124ms, Maximum = 245ms, Average = 176ms
l.p.
//bigk K
  • spremenil: bigk ()
Visoki pingi Siol ADSL 1024/256 (strani: 1 2 3 )
Oddelek: Omrežja in internet
10220726 (17305) Alexius Heristalski
Visok ping pri adslu
325406 (4767) MOJNET.net
Preveliki pingi (strani: 1 2 )
5212248 (11655) [L4M3RZ] - TinLaDeN
ADSL ping?
443774 (2788) zile
Pingi in ADSL
294645 (4007) matter
