Cisco 851W in konekcija na siol Adsl ( PPPoE )
bacho ::
Nikakor mi ne rata vspostaviti konekcije do interneta ( siol ADSL). Je kdo ta router konfiguriral ?
BlazP ::
Tukaj je Bakunin napisal prakticno celo konfiguracijo za vzpostavitev PPPoE povezave.
bacho ::
PROSIM vas povejte mi zakaj ne dela konekcija! Hvala vsakemu za odgovor!
Building configuration...
Current configuration : 3012 bytes
version 12.3
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Adsl
boot-start-marker
boot-end-marker
logging buffered 51200 debugging
logging console critical
enable secret 5 $1$WLt1$x7nDUhOp0SodcPMfIwrE2.
username administrator privilege 15 secret 5 $1$pvC3$3g4SEkhZMgyh0yI1Htm2k1
clock timezone PCTime 1
clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00
no aaa new-model
ip subnet-zero
no ip source-route
ip cef
ip tcp synwait-time 10
no ip bootp server
no ip domain lookup
ip domain name comland.si
ip ssh time-out 60
ip ssh authentication-retries 2
no ftp-server write-enable
interface FastEthernet0
no ip address
no cdp enable
interface FastEthernet1
no ip address
no cdp enable
interface FastEthernet2
no ip address
no cdp enable
interface FastEthernet3
no ip address
no cdp enable
interface FastEthernet4
description $FW_OUTSIDE$$ETH-WAN$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dot11Radio0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no cdp enable
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 10.10.10.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1452
interface Dialer0
ip address negotiated previous
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname xxxxxxx
ppp chap password 7 xxxxxxxxxxxx
ip classless
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport preferred all
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
transport output all
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
BlazP ::
A ti je slucajno ta povezava na routerju ze delala?
tomazkl ::
Pod dialer0 pobriši "ppp authentication chap callin". Nato vklopi "debug ppp authentication" - poglej kaj piše, če je "fail" ali pa naredi copy-paste sem, da pogledamo.
tretji router
81068 (959) boogie_xlr
Problem z VLAN-i.
Oddelek: Omrežja in internet
71471 (1335) levaky
Cisco Soho 851 router in msn messenger ne dela
112467 (2305) bacho
Cisco SOHO91-konfiguracija
222514 (2122) ponky
Cisco 2621 router
82342 (2205) Djuro
