Forum » Omrežja in internet » Cisco Soho 851 router in msn messenger ne dela
bacho ::
Router dela, samo msn messneger se noče konektat, prosim za pomoč.
Še eno stvar bi prosil, pptp microsoft vpn client ne dela na ven ( javi napako : protokol 47 GRE ) , prosim še tukaj za pomoč.
Častim pivo v Ljubljani, če mi kdo reši oba problema.
bacho ::
Building configuration...
Current configuration : 4689 bytes
! Last configuration change at 21:23:00 PCTime Sun Jun 4 2006 by administrator
! NVRAM config last updated at 21:07:28 PCTime Sun Jun 4 2006 by cisco
version 12.3
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname adsl
boot-start-marker
boot-end-marker
logging buffered 51200 debugging
logging console critical
enable secret 5 $1$JJAH$7Lxp4zfgHlTG.LWWwvlOs1
username administrator privilege 15 secret 5 $1$Osxa$KLJXklKQ6nY3QKHwUx0xz.
clock timezone PCTime 1
clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00
no aaa new-model
ip subnet-zero
no ip source-route
ip cef
ip inspect name DEFAULT100 cuseeme
ip inspect name DEFAULT100 ftp
ip inspect name DEFAULT100 h323
ip inspect name DEFAULT100 icmp
ip inspect name DEFAULT100 rcmd
ip inspect name DEFAULT100 realaudio
ip inspect name DEFAULT100 rtsp
ip inspect name DEFAULT100 esmtp
ip inspect name DEFAULT100 sqlnet
ip inspect name DEFAULT100 streamworks
ip inspect name DEFAULT100 tftp
ip inspect name DEFAULT100 tcp
ip inspect name DEFAULT100 udp
ip inspect name DEFAULT100 vdolive
ip tcp synwait-time 10
no ip bootp server
no ip domain lookup
ip domain name xxxxxxx.si
ip ssh time-out 60
ip ssh authentication-retries 2
no ftp-server write-enable
interface FastEthernet0
no ip address
no cdp enable
interface FastEthernet1
no ip address
no cdp enable
interface FastEthernet2
no ip address
no cdp enable
interface FastEthernet3
no ip address
no cdp enable
interface FastEthernet4
description $ES_WAN$$FW_OUTSIDE$
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dot11Radio0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no cdp enable
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 192.168.247.29 255.255.255.0
ip access-group 100 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip virtual-reassembly
ip route-cache flow
ip tcp adjust-mss 1452
interface Dialer0
description $FW_OUTSIDE$
ip address negotiated
ip access-group 101 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip inspect DEFAULT100 out
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname xxxxxxxx
ppp chap password 7 xxxxxxxxxxxxxx
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
logging trap debugging
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 192.168.247.0 0.0.0.255
access-list 100 remark auto-generated by Cisco SDM Express firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny ip host 255.255.255.255 any
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto-generated by Cisco SDM Express firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 deny ip 192.168.247.0 0.0.0.255 any
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 deny ip 10.0.0.0 0.255.255.255 any
access-list 101 deny ip 172.16.0.0 0.15.255.255 any
access-list 101 deny ip 192.168.0.0 0.0.255.255 any
access-list 101 deny ip 127.0.0.0 0.255.255.255 any
access-list 101 deny ip host 255.255.255.255 any
access-list 101 deny ip host 0.0.0.0 any
access-list 101 deny ip any any
dialer-list 1 protocol ip permit
no cdp run
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
transport preferred all
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet ssh
transport output all
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
version 12.3
no service pad
hostname adsl
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
no ip source-route
ip cef
no ip bootp server
no ip domain lookup
ip ssh time-out 60
no ip address
no cdp enable
no ip address
no cdp enable
no ip address
no cdp enable
no ip address
no cdp enable
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
duplex auto
speed auto
pppoe enable
no cdp enable
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
shutdown
station-role root
no cdp enable
interface Vlan1
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
interface Dialer0
no ip redirects
no ip unreachables
no ip proxy-arp
ip mtu 1452
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ip classless
ip http server
no cdp run
control-plane
line con 0
login local
no modem enable
line aux 0
login local
line vty 0 4
privilege level 15
login local
end
BlazP ::
Najbrz bos moral dodati v ACL pravilo, da spusti skozi GRE.
Nekaj v smislu access-list 101 permit GRE any any.
bacho ::
ok za vpn sem razvozlal
access-list 101 permit tcp 1723 any any
Sam še zmeri noben zaboga ne ve zakaj se mi msn noče konektat, tud če mam firewall off ne dela. 100% default konfiguracija pa ne dela, pa to bi lahko kdo kej vedu.
- spremenil: bacho ()
BlazP ::
Kaj pa MSN pravi kje se zatakne? Imas moznost troubleshootinga, ko ti tocno pove, kaj ne gre skozi.
Si poizkusil z access-list 101 permit tcp 1863 any any ?
bacho ::
msn troubleshooting ne javi napak!. Msn celo dela na mašinah , kjer je nameščen novejši vpn cisco client, msn celo dela na trillianu, vendar jaz ne morem vpn klienta namestit na 50 mašin, to bi blo amatersko, al pa triliana.
aja pa še neki, preko telneta sem se povezal, vnesel ukaz configure:
ta ukaz prime :access-list 101 permit GRE any any
ta ukaz ne prime: access-list 101 permit tcp 1863 any any
napiše: % invalid input detected at '^' marker.
Kje sem ga polomil?
Hvala vam!
Kje sem ga polomil?
Hvala vam!
BlazP ::
Ce se prav spomnim, pol se stavki v ACL-je dodajajo na koncu. Zadnji stavek pri tebi je deny ip any any Se pravi karkoli za njim sploh ne bo prijelo. Skopiraj cel ACL v en text editor, vpisi stavek pred ta deny, zbrisi cel ACL 101 in ga skopiraj nazaj iz tekst editorja.
Pa v sintaksi sem se zmotil.
"access-list 101 permit tcp any any eq 1863" bi moralo biti pravilno.
bacho ::
Hvala za odgovor! Ker nisem Cisco administrator ne znam pobrisati cele ACL liste in jo ponovno vnesti, če bi bil prijazen pa povedal katero orodje oz. client oz. kako se to naredi, bi bil izredno vesel.
BlazP ::
"no access-list 101" - s tem celo 101 zbrises. Zatem lahko kar copy/paste-as popravljeno access listo nazaj. Pa na koncu ti ni treba pisat tistega "access-list 101 deny ip any any", ker je tak stavek implicitno zapisan na koncu vsake access liste(ceprav se ne vidi).
bacho ::
Hvala za pomoč blazp in tomazkl, odkril sem še,da ne dela pošiljanje web maila preko gmaila. Končno sem našel na webu nekoga, ki ima iste probleme.
http://groups.google.com/group/comp.dco...
Ima kdo kako idejo?
Ima kdo kako idejo?
bacho ::
blah
MTU od siola je 1492 in ne default od ciscota 1452, ful podobnost pa nisem opazu, pa noben ni opazu v configu
Vseen sm se nauču neki. Zdej se morem sam še naučit kako port na noter forwardirat.
, upam da mi bo uspel.
Hvala vsem!
Hvala vsem!
| » | VPN povezava dveh PIX 501Oddelek: Omrežja in internet | 1786 (1607) | jl |
| » | Problem z VLAN-i.Oddelek: Omrežja in internet | 1478 (1342) | levaky |
| » | Cisco in omejitev prometa na portu 25Oddelek: Omrežja in internet | 1687 (1687) | tomazkl |
| » | Cisco 2621 routerOddelek: Strojna oprema | 2352 (2215) | Djuro |
