Forum » Hlajenje in modifikacije » ASRock 939Dual-SATA2
dolfi ::
A je že kdo delal, cpu in vdim mod na tej plati?
Mam bh-5 rame, a bi mogoče delali na tej plati z vdim modom?
Hvala!
Hvala!
HT33L ::
Delajo ze po defaultu na 2.7 voltih
Za navijanje pa ne bi, ker z vdimm modom dosezes max 3 volte, rabs pa najmn 3.5v
tko da jst mam takisto plato in si bom v bliznji prihodnosti kupu OCZ DDR Booster... dobis ga pr www.cool-pc.org
- spremenilo: HT33L ()
dolfi ::
Ddr booster že imam doma, tk da dela ddr booster na tej plati brez problema
Vdimm moda se mi pol ne splača delat?
- spremenil: dolfi ()
HT33L ::
Ne ker bi mogl it z DDR Boosterjem na 3.6 voltov in to je pa use kar rabs za navijanje BH-5 ramov...
Vsaj kukr sm jst prebrau na forumih da itg po 3.6 voltih ni nobene razlike, lohk pa sam probas : )
Drgac pa mej aktivno hlajene rame (sj to ze itg ves sam zihr je zihr :P)
HT33L ::
V slot 2 se mi zdi caki ti dam link do enga foruma...
OCWorkbench
Kle mas sam za to plato topice... : )
Does OCZ DDR Booster work on this board?
Yes, DDR Booster works with 939Dual-SATA2. DDR Booster takes up 2 slots space, you will have to insert the DDR Booster into slot#2 and have your memory modules in slot#3 and slot#4.
Note: Inserting DDR Booster in slot#4 is highly not recommended because there is not enough space between the sockets and the components on the DDR Booster will have contact (highly hazardous) with the memory module in slot#2.
OCWorkbench
| » | BH-5 se vrača med nami v polnem zamahu... (strani: 1 2 )Oddelek: Navijanje | 7345 (5898) | mzidy |
| » | Booster + enermax kompatibilna?Oddelek: Navijanje | 1714 (1445) | JIM22 |
| » | NOVI OCZ RAMI !!!!!!Oddelek: Navijanje | 2236 (1424) | MEDENA |
| » | OCZ ddr booster ..Oddelek: Strojna oprema | 1973 (1391) | MEDENA |
| » | Kako ekstremno naviti pomnilnik brez voltmodaOddelek: Navijanje | 5166 (4635) | DjTonic |
