windows picture and fax viewer
bozjak ::
Upam da tole spada sem...
Torej pred časom se je na slo-tech pojavila novica o novem zlobnozlobnemu skupku kode, ki izkorišča luknjo, ki je povezana z windows picture and fax viewer, zato je najbolj varna rešitev disablanje nekega dllja _(po spominu), kar pa efektivno onemogoči tudi windows picture and fax viewer...
Kakorkoli, sedaj si zgoraj omenjeni nujnik želim nazaj, a novice ne najdem... Upam da mi lahko kdo pomaga?
Hvala, Lp
slatibar ::
Na Slo-Tech forumu ne vem, kje je to bilo, vem pa za tole:
Un-register the Windows Picture and Fax Viewer (Shimgvw.dll)
1. Click Start, click Run, type "regsvr32 -u %windir%\system32\shimgvw.dll"
(without the quotation marks), and then click OK.
2. A dialog box appears to confirm that the un-registration process has succeeded.
Click OK to close the dialog box.
Impact of Workaround: The Windows Picture and Fax Viewer will no longer be started
when users click on a link to an image type that is associated with the Windows Picture and Fax Viewer.
To undo this change, re-register Shimgvw.dll by following the above steps.
Replace the text in Step 1 with “regsvr32 %windir%\system32\shimgvw.dll” (without the quotation marks).
stran na www.f-secure.coml
bozjak ::
hvala!
Kako naredit prosojno ozadje ikon!
Oddelek: Operacijski sistemi
153651 (3137) krho
Nova luknja v Windowsih povzroči Infocon Yellow (strani: 1 2 )
Oddelek: Novice / Varnost
6712960 (10362) denial
Noče odpirat slik
81328 (1288) Evil mind
Kako izkljucit preview media datotek v explorerju?
61347 (1258) bf4ed
