Forum » Operacijski sistemi » windows picture and fax viewer
bozjak ::
Upam da tole spada sem...
Torej pred časom se je na slo-tech pojavila novica o novem zlobnozlobnemu skupku kode, ki izkorišča luknjo, ki je povezana z windows picture and fax viewer, zato je najbolj varna rešitev disablanje nekega dllja _(po spominu), kar pa efektivno onemogoči tudi windows picture and fax viewer...
Kakorkoli, sedaj si zgoraj omenjeni nujnik želim nazaj, a novice ne najdem... Upam da mi lahko kdo pomaga?
Hvala, Lp
Hvala, Lp
slatibar ::
Na Slo-Tech forumu ne vem, kje je to bilo, vem pa za tole:
Un-register the Windows Picture and Fax Viewer (Shimgvw.dll)
1. Click Start, click Run, type "regsvr32 -u %windir%\system32\shimgvw.dll"
(without the quotation marks), and then click OK.
2. A dialog box appears to confirm that the un-registration process has succeeded.
Click OK to close the dialog box.
Impact of Workaround: The Windows Picture and Fax Viewer will no longer be started
when users click on a link to an image type that is associated with the Windows Picture and Fax Viewer.
To undo this change, re-register Shimgvw.dll by following the above steps.
Replace the text in Step 1 with “regsvr32 %windir%\system32\shimgvw.dll” (without the quotation marks).
stran na www.f-secure.coml
| » | Kako naredit prosojno ozadje ikon!Oddelek: Operacijski sistemi | 3650 (3136) | krho |
| » | Nova luknja v Windowsih povzroči Infocon Yellow (strani: 1 2 )Oddelek: Novice / Varnost | 12956 (10358) | denial |
| » | Noče odpirat slikOddelek: Pomoč in nasveti | 1328 (1288) | Evil mind |
| » | Kako izkljucit preview media datotek v explorerju?Oddelek: Operacijski sistemi | 1347 (1258) | bf4ed |
