Forum » Programska oprema » Neznan format *.daa
Neznan format *.daa
madviper ::
Imam en sliko cd-ja dol potegno prek torrenta, pa ne znam odpret. Predvidevam da je slika, lahk da se motim in je samo kak arhivski format.
Torej če se komu sanje kako se bi dala ta stvar odpret, kr z besedo na dan!
Lp, madviper
Lp, madviper
I'd like to do something crazy!
Gwanaroth ::
http://www.filext.com/detaillist.php?extdetail=daa&Search=Search
Extension: DAA
Program and/or Extension Function [What's This?] Company [What's This?]
PowerISO Direct-Access-Archive PowerISO Computing, Inc.
Specific Notes [What's This?]
PowerISO is a CD/DVD image file processing tool, which allows you to open, extract, create, edit, compress, encrypt, split and convert ISO files, and mount these files with internal virtual drive. It can process almost all CD-ROM image files including ISO and BIN. DAA is a format for an image file, which supports some advanced features, such as compression, password protection, and splitting to multiple volumes (similar to .RAR and other compression formats).
Extension: DAA
| » | .wtfOddelek: Pomoč in nasveti | 1833 (1585) | StratOS |
| » | Končnica swa?Oddelek: Programska oprema | 1525 (1450) | ank |
| » | datoteka .uha???Oddelek: Programska oprema | 1296 (1241) | R33D3M33R |
| » | Daemon toolsOddelek: Programska oprema | 1996 (1622) | Tr0n |
| » | Kako odpreti datoteko z končnico .mdf ?Oddelek: Pomoč in nasveti | 2732 (2676) | Mirč |
