Dolžina IDE in napajalnih kablov
smilyxx ::
Torej Zanima me če je kakšna omejitev pri dolžini IDE in napajalnih kablov? Sam bi rabil razdaljo kakih 4ih metrov. Hvala.
Save water.
drink beer.
5er--> ::
Dan's Data
The maximum cable length you're meant to use for any ATA interface - any kind of modern "IDE" drive - is 457mm, according to the official specification. That's 18 inches.
This length limit applies to 40 and 80-wire cables alike. 80 wire cables also can't be any shorter than 254mm (ten inches), by the way.
In practice, 24 inch/600mm cables should be just fine for UDMA/33 mode with modern hardware. They may work OK for UDMA/66 as well, but I wouldn't count on it.
smilyxx ::
Humm, pol bo ocitno treba kar na USB dat. Hvala vseeno
Save water.
drink beer.
DimmniBurek ::
JEst sm kupu lani IDE kable ki imajo 90cm, gor sta 2 diska in CD RW in DVD RW, tko da...
There Is No Stronger Drug Than Reality
TEDY ::
klik
^^mal preberi kolk dolge kable si je naredu ;)
HDMI kabel (strani: 1 2 )
6314634 (9954) showsover
34" ultra-wide (3440x1440) na ThinkPad T440p - bo delovalo?
92065 (1810) pirx
Dolga UTP kabel med dvema switch-ema!
Oddelek: Omrežja in internet
92051 (1803) yapka
NV silencer 5 rev. 2 in 7800GT
51165 (1124) raynox
master/slave
97467 (7389) TheJack
