[ASP.NET] MySqlDataProvider
greentech ::
Ali mogoče kdo ve kako lahko v web.config dodam MySqlDataProvider, da ga bom lahko potem uporabil v SqlDataSourc-u pri povezavi do baze
[asp:SqlDataSource ID="SqlDataSource1" runat="server" ConnectionString="[%$ ConnectionStrings:conn %]"
ProviderName="[%$ ConnectionStrings:conn.ProviderName %]
Connection String v web config zgleda takole
[add name="conn" connectionString="Server=localhost;Database=baza;Uid=razvoj;Pwd=geslo;" providerName="MySql.Data.MySqlClient" /]
Ko hočem zagnat aplikacijo mi javi
Unable to find the requested .Net Framework Data Provider. It may not be installed.
Torej kako naredit, da bo to delovalo. MySqlConnector imam inštaliran.
Hvala in LP
Grega
CWIZO ::
Imas MySQLov provider med referencami projekta?
hancic.info
I can't uninstall it, there seems to be some kind of "Uninstall Shield"...
C# težava
Oddelek: Programiranje
234896 (3742) mladec
[c#] Vprasanje glede povezave na bazo
163502 (3412) KernelPanic
Internetna stran in domač server
Oddelek: Omrežja in internet
174604 (4440) Seljak
[ASP.NET] problem
Oddelek: Izdelava spletišč
382642 (2292) Microsoft
[ASP.NET] label povezava z bazo
51372 (1288) darkolord
