Forum » Strojna oprema » Kateri _RAM- i so pravi za moj PC?
donstojko ::
Prosim če mi lahko nekdo svetuje katere rame kupiti, rad bi dogradil rame pa ne vem katere kupiti.
Pc:
--------[ Memory ]------------------------------------------------------------------------------------------------------
Physical Memory:
Total [ TRIAL VERSION ]
Used [ TRIAL VERSION ]
Free 38 MB
Utilization [ TRIAL VERSION ]
Swap Space:
Total 427 MB
Used 151 MB
Free 276 MB
Utilization 35 %
Virtual Memory:
Total 555 MB
Used 240 MB
Free 314 MB
Utilization 43 %
Physical Address Extension (PAE):
Supported by Operating System Yes
Supported by CPU Yes
Active No
Problems & Suggestions:
Suggestion Install more system memory to improve applications performance.
--------[ Chipset ]-----------------------------------------------------------------------------------------------------
[ North Bridge: VIA VT8366A Apollo KT266A ]
North Bridge Properties:
North Bridge VIA VT8366A Apollo KT266A
Supported FSB Speeds FSB200, FSB266
Supported Memory Types PC100 SDRAM, PC133 SDRAM, DDR-200 SDRAM, DDR-266 SDRAM
Revision 00
Package Type 552 Pin BGA
Package Size 3.5 cm x 3.5 cm
Process Technology 0.22 um
Core Voltage 2.5 V
In-Order Queue Depth 4
Memory Controller:
Bank Interleave 4-way
Memory Timings:
CAS Latency (CL) 2.5T
RAS To CAS Delay (tRCD) 3T
RAS Precharge (tRP) 3T
RAS Active Time (tRAS) 6T
Command Rate (CR) 2T
Write Recovery Time (tWR) 2T
Memory Slots:
DRAM Slot #1 128 MB (DDR SDRAM)
AGP Controller:
AGP Version 2.00
AGP Status Enabled
AGP Device Gainward GeForce4 MX 440
AGP Aperture Size 32 MB
Supported AGP Speeds 1x, 2x, 4x
Current AGP Speed 4x
Fast-Write Not Supported
Side Band Addressing Supported, Disabled
Chipset Manufacturer:
Company Name VIA Technologies, Inc.
Product Information http://www.via.com.tw/en/products/chips...
Driver Download http://www.viaarena.com/?PageID=2
Driver Update http://driveragent.com?ref=59
[ South Bridge: [ TRIAL VERSION ] ]
South Bridge Properties:
South Bridge [ TRIAL VERSION ]
Revision 00
Package Type 376 Pin BGA
Pc:
Physical Memory:
Free 38 MB
Swap Space:
Total 427 MB
Used 151 MB
Free 276 MB
Utilization 35 %
Virtual Memory:
Total 555 MB
Used 240 MB
Free 314 MB
Utilization 43 %
Active No
Revision 00
Core Voltage 2.5 V
Memory Controller:
Memory Timings:
Memory Slots:
AGP Controller:
AGP Version 2.00
AGP Status Enabled
Revision 00
kixs ::
Dejansko ti bodo delovali tudi novejsi npr. PC3200... seveda moras tudi vedet koliko ti podpira skupnega spomina in kako ima organizacijo rama. (Npr. 3 sloti , skupna velikost 2GB, potem pa je odvisno ali so eno ali dvo-stranski. Na starih platah sta navadno 1. in 2. slot eno ali dvo-stranska, 3. je pa samo enostranski).
Tako, ce bos vgradil npr. 512MB , ki je obojestranski, ga moras obvezno dat v 1. ali 2. slot (so oznaceni na plati - lahko se zacne z 0, 1 in 2).
| » | ugašanje in restartanje računalnikaOddelek: Pomoč in nasveti | 6707 (6360) | Cold1 |
| » | Sapphire 2600 XT 512 AGP nažicat za sodelovanje z Asus A7N8X-LA!! Noče pa noče :(Oddelek: Strojna oprema | 3951 (2960) | ncc2000 |
| » | Kako velik disk v stari PC?Oddelek: Strojna oprema | 2373 (2070) | kixs |
| » | kompatibilnost rama ddr ddr2?Oddelek: Strojna oprema | 3384 (3192) | Klemzz |
| » | Duron 1600 in Abit kr7a "kompatibilna"???Oddelek: Navijanje | 1522 (1375) | Container |
