Forum » Kaj kupiti » Nakup namiznega PC-ja
https://www.intel.com/content/www/us/en...
Environment:
The Intel(R) 400 Series Chipset is a scalable chipset designed for motherboards that support the 10th Gen and upcoming 11th Gen Intel(R) Core™ desktop processors. The motherboard BIOS is a key component to maintaining this broad compatibility while enabling processor innovations on the platform.
How to fix it:
Intel(R) Z490 and H470 chipset-based motherboards may require a BIOS update to boot the upcoming 11th Gen Intel(R) Core™ desktop processors. Intel recommends that you update the BIOS on your Intel 400 Series Chipset-based systems for compatibility with the upcoming 11th Gen Intel(R) Core™ desktop processors.
Note
Motherboards based on Intel(R) B460 or H410 chipsets are not compatible with upcoming 11th Gen Intel(R) Core™ processors.
Environment:
How to fix it:
Note
- spremenil: mtosev ()
Hvala za povezavo in informacije!
AaBoy ::
Trenutni rač ima probleme in treba kupiti novega.
Gledal sem te komponente (GPU in PSU se lahko obdržim od starega sistema):
Procesor: AMD Ryzen 5 3600
Matična: MSI MAG B550M Mortar WIFI (mATX, M.2 in WLAN so zahteva)
RAM: Crucial Ballistix black DIMM kit 16GB, DDR4-3600, CL16-18-18-38
Grafična je 1660Ti.
Grafična je 1660Ti.
Belcebub ::
Ali naj se še počaka na izid Ryzen 5700G, oziroma 5300G ali se nabavi Ryzen 7 PRO 4750G?
Ne vem, koliko je ta članek zanesljiv, ampak po njem naj bi bil 5700G okoli 20% hitrejši: http://wccftech.com/amd-ryzen-7-5700g-8...
Če si srečen, in če srečo rad bi še delil z nekom, če si srečen, brž z dlanjo udari v dlan!
juvank ::
Zdravo,
Je tole vredno 350€
Intel(R) Core™ i7-4790 CPU @ 3.60GHz
Grafična kartica
NVIDIA GeForce GTX 970 (Vse novejse igre 60+ pfs)
RAM
16 GB
SSD KINGSTON 250 GB
HARD DISK Toshiba DT01ACA200 2TB 7200 RPM 3.5
Je tole vredno 350€
Grafična kartica
RAM
16 GB
SSD KINGSTON 250 GB
Če je zraven še matična, ohišje in napajalnik, potem je vredno 350.
@Belcebub, iz tvojega vprašanja gre razbrati, da ti je vseeno, ali ima proc 4 ali 8 jeder, tako da tudi tistih 10-20% razlike hitrosti ne sme igrat nobene vloge pri tebi. Poleg tega iGPU ne bo nič boljši pri 5000 seriji.
Belcebub ::
@Darwin: Mogoče nisem pravilno postavil vprašanja.
Ker bom moral nabaviti nekaj novega in se nebi rad ''zaletel'', me zanima koliko je sedaj smiselno nabaviti 4750G Pro (ki je zdaj po dobrih 300 EUR), če bi naj kmalu prišel 5700G?
5300G je tu omenjen zgolj kot alternativa. Uporaba bo na 1080p monitorju. Občasno kakšna starejša igra, kar pa ni prioriteta.
Če rabiš danes, ne čakaj.
4750G je zelo dober procesor.
matobeli ::
Če ne delaš nič zelo zahtevnega vzameš 4650G za cca 200eur
orbika ::
Za sorodnika sestavljam eno mašino.
Recimo, če bi v tem trenutku kupovali procesor (in grafično) do ajd, reci-piši maks. 200 evrov. Kaj bi kupili? Po možnosti z integrirano grafično ... dobro bi bilo, če vsebuje tudi hladilnik. Ne bi škodilo, da ima čimveč fizičnih jeder. Pa tudi, če ima HT, torej virtualna jedra, bi bilo kul.
Torej, kaj predlagate? Ryzen 3200G? 3400G je skoraj nemogoče dobiti ... Ryzena Pro 4350G? Intel i5-10400?
V Nemčiji sem videl, da se dobi F varianta, torej 10400 za cca. 130 evrov. Imam znanca, ki mi ga lahko in potem pošlje po pošti.
Ali pa je smiselno pogledati za kakšno i3-ko iz F serije ter Geforce 1030GT? Slednjo sem našel novo za 82 evrov.
Matične še ni.
Na voljo so sledeče komponente:
- RAMi (Kingston, 2 x 8 GB, DDR4 3000 MHz, RAMa sta kupljena lani)
- starejše ohišje formata ITX (tu je novejši model tega) s skoraj novim 300 W-nim LC Power napajalnikom
- v ohišje gre gre samo 1-slot grafična ali pa integrirana
- 256 GB SATA SSD je na voljo, po potrebi se bo zamenjalo.
Želi ostati na tem formatu, torej ITX.
Uporaba: pisanje v MS Office 365 Word, zelo osnovna uporaba Excela, občasno Powerpoint, izdelava enostavnejših vektorskih slik v Inkscape in LibreOffice Draw, sodelovanje na Zoom-konferencah, Skype, enostavnejša obdelava slik (Adobe Photoshop Elements 2021), obdelava notnih zapisov, rezanje zvoka v Audacity, rezanje videa v Premiere Elements 2021 in Shotcut (ločljivost do 1440p), brskanje po spletu, gledanje filmov ...
Igre: občasno kakšna strateška igra tipa Age of Wonders 3, Warhammer Gladius, Civilization 6 in morda še kakšne starejše strateške ali pa kakšen Serious Sam HD.
Trenutno je v uporabi i3-6100, Radeon R7 250 nizki profil ... saj deluje, samo te novejše strateške lahko igra samo na nizkih nastavitvah, kodiranje posnetkov je tudi bolj kilavo. Pri grafični tudi izgleda, da se bo počasi poslovila, ker so občasno vidne bele pikice in pink vzorci.
Matične še ni.
- spremenil: orbika ()
Jaz bi reko, da ti je v tvojem primeru najboljši kombo 10400F + GT 1030. Za igpu kombo pa vzameš 4350G predvsem zaradi dosti boljšega gpuja.
matobeli ::
Točno to se vzame, pa je mir za nekaj časa, starejši špili bodo laufal kar ok. Proc še nekaj časa ne bo švoh, gpu se pa lahko v prihodnosti nadgradi.
Kot CPU je 4650G močnejši. Cena je tudi nižja glede na i5+1030
4650G! Ne ga srat z ekstra grafično v tem času.
Če denarnica omogoča celo 4750G (s tem sem se imel priložnost igrati in sem bil zelo pozitivno presenečen kam je to šlo).
Že na 4650G bo vse tisto, kar si opisal, letelo.
Vzemi box verzijo (tray verzija nima hladilnika).
- spremenilo: FireSnake ()
Je kje pregledna primerjava integrated GPU-jev?
orbika ::
Hvala. Problem je predvsem budžet, ki ga je na voljo maksimalno 300 evrov, to je za matično, CPU + eventualno grafično.
Intelova varianta:
Najcenejšo ITX matično za LGA 1200 sem našel na nemškem Amazonu in sicer H410:
https://www.amazon.de/s?k=H410+itx&__mk... + cca. 7 evrov poštnine.
Škoda, da smo zamudili, prejšnji teden je Amazon Warehouse imel na voljo Asrocokovo H410 za 82 evrov
Oziroma Funtech ima še kaj v ponudbi:
https://funtech.si/si/vsi-oddelki/komp/...
Iz Intelove petstotke pa še sploh nimajo ...
https://funtech.si/si/nekategorizirani-...
Ostali prodajalci,ki sem jih gledal pa spet nimajo nič pametnega na zalogi (imajo edino Z490 matične, ki pa so že skoraj celoten budžet):
https://www.mimovrste.com/iskanje?s=itx...
https://www.techtradecenter.si/osnovne-...
https://anni.si/racunalnistvo/racunalni...!filter:price%5Bmin%5D=&price%5Bmax%5D=&f_182%5B%5D=4529
https://www.sestavi.si/index.php/items/...
AMD varianta:
Baje B450 čipset ni primeren za te novejše APU-je, rabiš 500-ko serijo čipov. Edino, kar dela na B450 so procesorji serije Ryzen 5xxx, ki pa so kar dragi v primerjavi z Ryzeni 3xxx-kami.
Toliko sem bral zdaj o vsem tem, da sem že totalno zmeden.
Aja, glede APU-jev 4xxxG serije ... Tukaj en piše, da na njegovi matični z B450 deluje:
https://linustechtips.com/topic/1288702...
Intelova varianta:
AMD varianta:
Jaz sem zgoogal in nekatere b450 plate podpirajo npr 4650G. Zdaj pa rabiš najti b450 itx plato, ki podpira ta cpu.
orbika ::
Ja, samo kako to ugotoviti?
Pri nas se dobi samo in izključno ASROCK-ova serija Fatal1ty B450 Gaming-ITX/a (če sploh, ker trenutno nikjer nisem našel na zalogi). Saj ima solidno ceno, samo uradno nima podpore z Ryzen 4xxxG:
https://www.asrock.com/mb/AMD/Fatal1ty%...
Vzameš A520 ITX.
Ja, izgleda, da bom moral prečekirat spletne trgovine v Nemčiji. Problem je tudi, da sorodnik vedno dela težave (tam kjer jih ni), ko se gre za nakup iz tujine ...
Hvala vsem!
Samo ena ideja: Pošlji vprašanje asrocku, če slučajno podpirajo 4xxxG serijo cpujev. Pa boš vedo na čem si.
Takšni pacienti so najboljši ja, ko postavijo ultra nizek budget, potem pa cel kup pogojev, kot so ITX, nakup v Slo, ipd... :)
ASROCK A520M-ITX/ac (107€ z dostavo) + 4650G (216€ z dostavo) = skupaj 323€.
orbika ::
DarwiN: Hvala za predlog!
Gre se za mojega brata. Ni mu težko skeširat (zakreditirat) 30k evrov za avto, a pri računaliku in nekaterih drugih (po mojem mnenju bolj uporabnih in potrebnih) zadevah pa škrtari.
Kaj morem. Kot so že drugi rekli, družinske člane ne moreš izbrati ... jih dobiš na pladnju.
Ampak pustimo zdaj to. Pošljem mu link, pa si naj naroči.
Mtosev: zanimiva ideja, na to nisem niti pomislil. Bom videl, mogoče pa en mail res ne škodi. Hvala vsem za predloge!
Meiniken ::
Vprašaj ga če z avtom za kej kompenzira
Napol v šali - proda naj tisto kar ima in kupi nek barebone PC (npr deskmini x300), notr vtakne primerne komponente pa čao miki. Cenovno bo prišlo v rangu od 400 do 500, bo pa majhen. Grafične sicer noter ne moraš vtaknit, ampak če je tak škrtuh kot praviš potem ni za skrbet, da bo sploh kdaj grafično še v pc dajal (glede na situacijo)
Big_Al ::
Ta podpira 4xxx APU
https://www.gigabyte.com/Motherboard/B4...
https://www.mimovrste.com/plosce-amd-pr...
Big_Al ::
link sem dal pomotoma za V1, ki ni dobavljiva - nova V2:
orbika ::
Napol v šali - proda naj tisto kar ima in kupi nek barebone PC (npr deskmini x300), notr vtakne primerne komponente pa čao miki. Cenovno bo prišlo v rangu od 400 do 500, bo pa majhen. Grafične sicer noter ne moraš vtaknit, ampak če je tak škrtuh kot praviš potem ni za skrbet, da bo sploh kdaj grafično še v pc dajal (glede na situacijo)![]()
Ja, tudi to bi bila opcija, samo se noče rešit starega Chieftec ohišja.
Glede avta ga raje ne sprašujem, ker mu bo še zrasel pritisk.
Big_Al: hvala za predlog, žal matična ni pravega formata. V zgoraj omenjeno ohišje (na linku je novejši model) gredo samo mini ITX plošče.
Verjetno bo obveljal Darwinov predlog, ker sem dobil mail, da bo verjetno naslednji teden po praznikih naročil napisano matično in procesor.
globoko grlo ::
Eh, Orbika, nekje nej dobi eno boljšo grafo, magar 1050ti za 200 ojrov, če ne gre drgač, pa bo vse lepo laufal.
6100 je čist ok za opisane naloge!
orbika ::
Problem je 300 W-ni SFX napajalnik, ki verjetno ne bi zdržal 1050Ti. Pa 1-slot variante so zelo redke, in bi spet bila opcija samo tujina ...
Zdaj se je ogrel, da bo menjal. Jaz pa ga ne bom odvrnil od tega, hehe.
matobeli ::
https://www.funtech.si/si/vsi-oddelki/k...
Vse skup lih nek 320eur s poštnino, nej ti pisti tastaro mobo in cpu, pa mu ti to zrihtaš za 300. Pol pa mobo in cpu prodaš za 80 ;)
Ta psu je 250watt, peak load je pa 300watt.
globoko grlo ::
Pol pa napajalc za 50 ojrov, pa grafa za 250 ojrov, pa je. No ja, sej novo stvar je vedno lustn met :)
gddr85 ::
za uporabo, katero je napisal en ryzen apu in je to to, druzga imo ne nuca, sploh pa ne "novih" low/mid gpujev po 200+ bucks, če pa že mora bit, pa bolje en rabljen gpu za cca 50 bucks..
Tudi meni ne gre v račun: človek pove, da ima 300€ na razpolago.
Tu mu pa ponujajo napajalnik za 50€ in grafo za 250.
Kako gre to skup? Ne gre.
Edini pravi odgovor: 4650G in pika!
matobeli ::
Bi šlo če obdrži star MB in CPU, kar je seveda možno, ampak pol si hitro na tem da imaš še vedno kup stare šare performance katere bo sicer boljši od 4650g, razen če pač crkne čez dva dni.
Pa še polno jebanja da sploh dobiš ugodno tak PSU in nek GPU ki ni čist zanič.
Po domače: ne profitira popolnoma nič, le 300€ vrže stran.
Zato je predlog s 4650G edini smiseln.
Motion ::
Na ponudbi dneva na mimovrste lahko dobiste R7 5800X za samo....
https://www.mimovrste.com/procesorji/am...
Horas ::
3.5k€???????
a se delajo norce? majo podalšan 1.april?
8700k+z390, 32gb 3600mhz, 1080ti, 700w gold, 512gb+2x250gb m.2 nvme + 2tb hdd
8500+b360, 32gb 2666mhz, rx 6600, 600w bronze, 512gb+250gb ssd m.2 + 2tb hdd
- spremenil: Horas ()
Bwaze6 ::
Lahko vprašaš kriptozanesenjake tule, zakaj je to popolnoma pravilna cena:
Nije žvaka za seljaka, ni grafična kartica za nekoga, ki ne misli rudariti.
Mariiato12 ::
Pozdravljeni, potrebujem pomoč pri sestavi računalnika tam nekje do 700€ brez grafične, bom vzel nekaj rabljenega. Računalnik se bo uporabljal za kakšen light video edit, pohotoshop, občasno kak špil csgo, wow.. Lepo prosim za nasvet!
Daliborg ::
Nisem kritpo zanesnjak ampak ti povem da 3.5k za to serijo procesorja tak nateg da se piramidnim shemam samo kolca. Ta proc je max 500 eur, 5950x pa okoli jurja kateri ima dvojno število jeder od 5800x. Tako da se najprej prepričaj od koga ti žvake kupuješ ker so ti verjetno kaj podtaknili :D
EDIT:
On TOPIC : Mariiato12 rabljenega ti ne moremo priporočati če ne vemo katerega si si ogledal . Da pa mi nabijamo neke komponente tukaj za katere boš zapravil čas z iskanjem je brezupno...podaj link "rabljenega" pa ti povemo ali je OK ali ne. Išči v segmentu AMD od serije 3xxx naprej oz. Intel od 10.gen.
Lp.
Format life:
Warning all life will be erased!
Do you want to continue?(y/n) Y_
- spremenil: Daliborg ()
