Forum » Kaj kupiti » Nakup namiznega PC-ja
PredatorX ::
hojnikb ::
pride že, ampak nevemo performanca in dobavljivosti. Pubec pa hoče komp _sedaj_ ;)
#brezpodpisa
PredatorX ::
Za custom kartice se omenja "julij", med drugim.. In under 300$, torej 299$ MSRP = nanese koliko evrčkov? Odvisno od performenca. Lahko tudi 400€.
PredatorX ::
Za custom kartice se omenja "julij", med drugim.. In under 300$, torej 299$ MSRP = nanese koliko evrčkov? Odvisno od performenca. Lahko tudi 400EUR.
Ne, omenja se 13 junij.
In poleg tega mu ni treba kupiti nove kartice..., ki bo mela velik več podpore (bonbončkov etc) in se 50EUR več "kao" nesplača dat.
GTX 980 je kr okey deal za 320EUR. Ampak, bodo velik boljši deali.. več bo ponudb starejših GPUjev.
- spremenilo: PredatorX ()
Launch in July
While Polaris 10 sounds interesting for the mainstream market, it doesn't seem like AMD plans to launch their cards any time soon. We are expecting a announcement of these cards at Computex which was confirmed by AMD recently but the cards themselves will appear on store shelves later in July. Most of AMD's partners have yet to receive a full supply of Polaris 10 chips so it is possible that we may see the reference boards launch in June followed by non-reference parts in July
Povedano drugače, nobody knows.
BorutK-73 ::
Zdravo!
Zanima me če je tale build uredu: Budget je pa 950 €.
-ASUS H81-Gamer, Intel H81 Mainboard-S1150
-Ohišje Zalman Z3-Plus Midi-Tower-belo
-SAPPHIRE Radeon R9 380 Nitro Dual-X OC, 4GB, GDDR5
-Intel Core i7 7490 BOX procesor Haswell
-Pomnilnik Kingston HyperX Fury 16GB ( 2x8GB ) 1600 MHz DDR3
-Intel SSD 540s series 240GB
-Napajalnik XILENCE 600W Performance
-Hladilnik Akasa AK-CC7129BP01 Low Profile-74mm
Kupil pa bi iz strani Funtech.
Če še ni blo omenjeno, menjaj napajalnik, Xilence je isti šrot kot LC power.
AC_DC ::
Če bo sistem za igre, potem imaš totalno sfaljeno sestavo, edino ohišje je ok.
http://www.mindfactory.de/product_info....
~702 eur s poštnino.
Ohišje v Slo http://www.edigital.si/racunalnije-za-r... ali kje drugje funtech http://www.funtech.si/si/vsi-oddelki/ko... .
- spremenilo: AC_DC ()
AC_DC ::
ali če bi rad bil glavni frajer na vasi:
cpu+mb
skopiral od
https://slo-tech.com/forum/t200222/p516...
ali
cpu i7 6700
cpu+mb
skopiral od
ali
cpu i7 6700
jero_no1 ::
Pozdrav vsem.
Imam 2 vprašanji:
- osnovna plošča je GIGABYTE GA-H170-HD3 DDR4 - se splača dat nanjo M2 SSD namesto SATA SSD? Bo opazna razlika v hitrosti delovanja (če ne gledamo na faktor cene)
- rabim HDD, namenjen bo samo shranjevanju arhiva (poleg zunanjega diska) - WD Green ali Blue? ALi morda kaj 3.?
Hvala za pomoč.
Imam 2 vprašanji:
Hvala za pomoč.
hojnikb ::
razlika bo opazna, če boš delu i/o intensive zadeve.
Btw, kupit morš pcie m.2 ssd, sicer ni fore :)
#brezpodpisa
snowzoor ::
Pozdravljeni,
zanima me, kakšne komponente bi mi priporočali za nakup računalnika, doma imam že nekatere komponente, ki bi jih lahko uporabil, in sicer:
- 2x Pomnilnik DDR3 4GB
-kingston SSD disk 480Gb
Cena komponent bi se gibala okoli 500€.
Hvala.
Hvala.
snowzoor ::
Programiranje, grafično oblikovanje (photoshop, sony vegas, adobe, maya 3d...). Z oktobrom bom postal študent prvega letnika FRI, kar je tudi eden od razlogov nakupa. Ter pa vse običajne stvari, word, surfanje...
- spremenilo: snowzoor ()
Nande ::
Dober dan! Upam, da zadnjič sprašujem za mnenje... :)
ASRock H170M Pro4 Intel H170 So.1151 Dual
Intel Core i5 6600 4x 3.30GHz So.1151 TRAY
Arctic Freezer 11 LP Topblow Kühler
650 Watt EVGA SuperNOVA Modular 80+ Gold
16GB HyperX FURY schwarz DDR4-2133 DIMM
500GB Samsung 850 Evo 2.5" (6.4cm) SATA
8192MB Asus Radeon R9 390 Strix Gaming Direct CU III OC Aktiv PCIe 3.0 x16
Skupaj 904 € + PTT (Mindfactory.de)
Lp!
Lp!
hojnikb ::
počakaj na nove grafične. 390 je zdaj že res staro železo, ki ni vredno 300e
#brezpodpisa
youPlonker je izjavil:
Kake zakasnitve imajo ti dražji DDR4 3200MHz rami, če laufajo na 2133MHz?
10-15 nanosekund, enako kot vsi RAM-i za časa naših življenj.
(in teh 5 ns razlike ne boš opazil)
jero_no1 ::
Jasno je, da bo enkrat na vrsti pci-e (nekaj tazga gledam), do takrat bi pa mogoče mel m2 :)
hojnikb ::
ne štekaš. M.2 je samo fizičn priklop, nič druga.
M.2 ssdjo so lahko tudi z sata protokolom, kar pomeni da so enako hitri kot obični 2.5" ssdji.
#brezpodpisa
Pozdravljeni,
Hvala.
H110 matična z DDR3 podporo
procesor i5 6500
grafično po želji (ti bodo že drugi svetovali)
Wazzock ::
Ja sam skylake podpira sam low voltage ddr3 ram, sj dela z običnim sam vprašanje kok cajta ti bo memory controller zdržal.
Jaz bi prodal te rame in kupil DDR4 ploščo in 16Gb... 2800Mhz 16Gb za 54€. Kam smo prišli. :)
Mora delat. Znancu že od začetka januarja laufa i3 6100 z 1600 MHz-nimi DDR3 RAMi brez težav in dnevno nabija igre in še marsikaj.
- spremenil: opeter ()
Han ::
Na šihtu imamo od novembra lani 12 mašin z B150M platami in 1,5V 1600 MHz DDR3 CL9 RAM moduli. Nobenih težav.
Folk goni tudi 1,65V DDR3 na npr. gaming ASRock platah...
klinker ::
Na M2 imas lahko SSD preko SATA in PCI-E protokola.
Samsung ima najitrejse m2 pci-e ssdje so pa nekje x2 drazji od navadnih 2,5" sata
snowzoor ::
Pozdravljeni,
Hvala.
procesor i5 6500
Kaj pa trdi disk? Verjetno katerikoli z 7200rpm?
Wazzock ::
nejodagreat ::
Zdravo, počasi se spravljam v nakup računalnika....
Edina bolj zahtevna stvar za katero bi uporabljal je igranje War Thunder-ja. Tu bom zadovoljen z mid-high nastavitvami, igram v FullHD.
Na hitro sem sestavil tale seznam:
MSI Bazooka,
8GB HyperX Impact DDR4-2133,
GeForce GTX 750 Ti,
Core i3 6098P 2x 3.60GHz
SSD in HDD že imam.
Kakšen napajalnik bi rabil za to?
Sem fejst zgrešil s tem buildom?
MSI Bazooka,
GeForce GTX 750 Ti,
SSD in HDD že imam.
IcyFox ::
nejodagreat je izjavil:
MSI Bazooka,
GeForce GTX 750 Ti,
SSD in HDD že imam.
Čist solidno, manjka ti ohišje pa en 450 - 550W napajalnik pa bo
Pa saj sem napisal da deluje, samo memory controller je bolj obremenjen. Dolgoročno gledano so lahko zapleti, ker ima potencial da crkne an.
Vse ti dolgoročno crkne.
Berni_01 ::
ibrokemyGF je izjavil:
Zdravo mene pa zanima če bi tole kar sem si izbral pasalo skupaj al bi bilo treba kaj spremenit
1. Zakaj boš računalnik potreboval?
2. Ne kupuj v sloveniji, poglej na mindfactory...
Intel i5-6600K, OC 4,4GHz; Fractal Design Celsius S36; EVGA GTX 1070;
Kingston HyperX Savage, 2x8GB, DDR4-2400MHz; Asus Z170-A;
Samsung 840 EVO, 250GB; Seagate SV35 1 TB ST1000VX000; Chieftec ATX 1000W
ibrokemyGF ::
Gaming + streaming
Aje full razlike v ceni ker za 100-200EUR se mi neda cakat 1 teden da dobim
- spremenilo: ibrokemyGF ()
Berni_01 ::
dobiš v 3-4 dnevih če je na zalogi :D
mislim da 32gb rama je pretirano... kakšen budget imas?
ibrokemyGF ::
32gb rama je res mogoc velik, budget je pa 3k€ z tem monitorjem https://www.mimovrste.com/led-monitorji...
6151 ::
16 GB RAM je več kot dovolj za vse. Počakaj na nove grafične (GTX 1070 ali 1080). Disk ni najbolj primeren za takšno uporabo, raje kakšen WD Blue.
Ne potrebuješ tako drage matične, ravno tako ne potrebuješ vodnega hlajenja. Procesorja ne gre navijati, priloženi hladilnik je tih in dovolj dober. Matično kar kakšno H110 Z DDR4 podporo in priključki ki jih potrebuješ(na najcenejši matični bo procesor enako hiter kot na najdražji). SSD kupi vsaj 512GB, saj tu budget to omogoča, mogoče celo 256GB NVME+512GB SATA SSD. Ostanek daš v dober monitor (dobra izbira)
3600 | 32GB | 6800 | 1+3TB
Berni_01 ::
Mogoče nekaj takega + 170EUR ti ostane za ohišje
https://www.mindfactory.de/shopping_car...
Edit: ekran pa kupi pri nas ker mislim da ne dobavljajo v slo večjih od 27".
- spremenil: Berni_01 ()
