Forum » Omrežja in internet » PPP: Input/output error
LuGi ::
Hm need some linux guru help
Torej konekšn se dropa na vsake X ur/minut.. kokr se mu sprdne.. takrat pa dropne
delcek loga connect/drop
23:13:17 pppd pppd 2.4.2 started by nobody, uid 99
23:13:17 pppd Using interface ppp0
23:13:17 pppd Connect: ppp0 -> /dev/pts/0
23:13:17 pppoe PPP session is 1085
23:13:18 pppd CHAP authentication succeeded
23:13:19 pppd local IP address
23:13:19 pppd remote IP address 213.250.19.90
23:13:19 pppd primary DNS address 193.189.160.11
23:13:19 pppd secondary DNS address 193.189.160.12
23:37:59 pppd No response to 3 echo-requests
23:37:59 pppd Serial link appears to be disconnected.
23:37:59 pppd Connection terminated.
23:37:59 pppd Connect time 24.7 minutes.
23:37:59 pppd Sent 9847319 bytes, received 129083437 bytes.
23:37:59 pppoe read (asyncReadFromPPP): Session 1085: Input/output error
23:37:59 pppoe Sent PADT
23:38:00 pppd Connect time 24.7 minutes.
23:38:00 pppd Sent 9847319 bytes, received 129083437 bytes.
23:38:00 pppd Exit.
Ifconfig..
[root@lugi root]# ifconfig
eth0 Link encap:Ethernet HWaddr 00:30:4F:45:BE:87
inet addr:192.168.0.1 Bcast:192.168.0.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:267434 errors:0 dropped:0 overruns:0 frame:0
TX packets:351952 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:33819455 (32.2 Mb) TX bytes:335214749 (319.6 Mb)
Interrupt:10 Base address:0xe400
eth1 Link encap:Ethernet HWaddr 00:C0:26:F4:48:18
inet addr:1.1.1.1 Bcast:1.1.1.255 Mask:255.255.255.0
RX packets:351850 errors:15 dropped:0 overruns:0 frame:0
TX packets:264259 errors:0 dropped:0 overruns:0 carrier:0
collisions:3150 txqueuelen:1000
RX bytes:337668467 (322.0 Mb) TX bytes:34420172 (32.8 Mb)
Interrupt:12 Base address:0xe800
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:16436 Metric:1
RX packets:10 errors:0 dropped:0 overruns:0 frame:0
TX packets:10 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:1096 (1.0 Kb) TX bytes:1096 (1.0 Kb)
ppp0 Link encap:Point-to-Point Protocol
inet addr:
P-t-P:213.250.19.90 Mask:255.255.255.255
UP POINTOPOINT RUNNING NOARP MULTICAST MTU:1492 Metric:1
RX packets:28945 errors:0 dropped:0 overruns:0 frame:0
TX packets:19525 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:3
RX bytes:22882065 (21.8 Mb) TX bytes:2110049 (2.0 Mb)
Help
23:38:00 pppd Exit.
Ifconfig..
inet addr:
Help
LuGi ::
Ne a res?
Iz tega sledi kaj pomeni "23:37:59 pppoe read (asyncReadFromPPP): Session 1085: Input/output error" ta error.. pi*** si GL** ..
BlazP ::
korenje_ver2: In kaj je razlog za prekinjanje? Js bi se rad kej novga naucil za bodoce primere, ko bom to sreceval, pa mi ne bo jasn, zaka se prekinja. Na pamet bi rekel, da zgublja sinhronizacijo s centralo, kar bi moral njegov ISP popraviti.
korenje_ver2 ::
se zdej ne ves? prvo se ti prekine povezava, ker program ne dobi 3 ping odzive od gatewaya, ppp tunel dol pade, in potem dobis read write error od programa pppoe.
- spremenilo: korenje_ver2 ()
js ::
Ni to Siol kriv. Preden sem ruter začel uporablat, ni nikol povezava padla.
Mam pa ipcop.
Še to - ko povezava pade, se v par sekundah poveže nazaj.
Mam pa ipcop.
- spremenil: js ()
b ::
Ali imas zelo zafilano linijo, ali pa je Siol borken (bolj verjetno to drugo).
V man pppd si poglej nastavitvi za lcp-echo-interval in lcp-echo-failure. Oboje pobrisi ven iz configa, pa bos resil simptome, ne pa vzroka.
Mimogrede, jaz imam na vse ADSL-ih nastavljen lcp-echo-interval 20 in failure 3. Pa nikjer ne crkuje.
| » | ubuntu + network sharingOddelek: Pomoč in nasveti | 1670 (1534) | NeMeTko |
| » | Ubuntu in povezava v internetOddelek: Operacijski sistemi | 1815 (1528) | Blinder |
| » | Ubuntu in adslOddelek: Operacijski sistemi | 2768 (2484) | gregs |
| » | Ubuntu problem z mrežno 3com 3c509Oddelek: Operacijski sistemi | 2768 (2518) | krofko |
| » | [pppoe povezava] Couldn't increase MRU/MTU to 1500Oddelek: Operacijski sistemi | 2109 (1963) | NeOman |
