[ASP.net] Master/detail - pretvorba VB v C#
SloDave ::
Vbistvu dost preprosto vprašanje, po tem članku skušam zadevo izdelat v C#. VB mi povzroča težave in nekako mi ni jasno kako bi tole pretvoru:
Kako naj definiram te dve funkciji da bo zraven šel result ds.Tables("tblDetails"), nekako vedno dobim error: 'System.Data.DataSet.Tables' denotes a 'property' where a 'method' was expected
Function GetDetails(ByVal x As String)
Dim conn As New SqlConnection("server=std04;uid=sa;pwd=;database=northwind")
Dim strSQL As String
Dim ds As New DataSet()
strSQL = "SELECT TOP 5 Customers.CompanyName, Products.ProductName, "
strSQL &= "convert(varchar, Orders.Orderdate, 101) as CDATE "
strSQL &= "FROM Employees INNER JOIN "
strSQL &= "Orders ON Employees.EmployeeID = Orders.EmployeeID INNER JOIN "
strSQL &= "Customers ON Orders.CustomerID = Customers.CustomerID INNER JOIN "
strSQL &= "[Order Details] ON Orders.OrderID = [Order Details].OrderID INNER JOIN "
strSQL &= "Products ON [Order Details].ProductID = Products.ProductID "
strSQL &= "WHERE Employees.EmployeeID = " & x & " ORDER BY orderdate DESC"
Dim da As New SqlDataAdapter(strSQL, conn)
da.Fill(ds, "tblDetails")
Return ds.Tables("tblDetails")
End Function
kot tudi funkcija
Function GetAuthors() As DataTable
strSQL = "SELECT lastname, EmployeeID FROM Employees ORDER BY lastname"
da.Fill(ds, "tblAuthors")
Return ds.Tables("tblAuthors")
End Function
Hvala
frudi ::
problem je v uporabi [] namesto () :)
poskusi tako:
private static DataTable GetDetails(string avstEmployeeId)
SqlConnection lConn;
String lstSql;
DataSet lDts;
SqlDataAdapter lAdapter;
lConn = new SqlConnection("server=.;uid=sa;pwd=banana;database=northwind");
lstSql = "SELECT TOP 5 Customers.CompanyName, Products.ProductName, ";
lstSql += "convert(varchar, Orders.Orderdate, 101) as CDATE ";
lstSql += "FROM Employees INNER JOIN ";
lstSql += "Orders ON Employees.EmployeeID = Orders.EmployeeID INNER JOIN ";
lstSql += "Customers ON Orders.CustomerID = Customers.CustomerID INNER JOIN ";
lstSql += "[Order Details] ON Orders.OrderID = [Order Details].OrderID INNER JOIN ";
lstSql += "Products ON [Order Details].ProductID = Products.ProductID ";
lstSql += "WHERE Employees.EmployeeID = " + avstEmployeeId + " ORDER BY orderdate DESC";
lAdapter = new SqlDataAdapter(lstSql, lConn);
lDts = new DataSet();
lAdapter.Fill(lDts, "tblDetails");
return lDts.Tables["tblDetails"];
private static DataTable GetAuthors()
String lstSql;
DataSet lDts;
lstSql = "SELECT lastname, EmployeeID FROM Employees ORDER BY lastname";
C# težava
Oddelek: Programiranje
234913 (3759) mladec
[C#,SQL]
51731 (1644) JanOlMajti
Baza & c#
214749 (3807) xardas
[C#] Dostop do objekta iz različnih form
182536 (2249) Kekec
[C#] DATA GRID VIEW
132321 (2201) Kekec
