[JAVA] netbeans
[JAVA] netbeans
bijonda ::
Hallo!
Evo mene nazaj. Sem mislila da mi bo sama ratlo pa se nicesar vec ne spomnim.
Glavni program je
package org.me.primer;
import HLIWrapper.*;
import java.io.*;
import java.util.*;
public class DMS implements DMSMsgCodes {
    // spremenljivke oz atributi
    static String koda;
    static String izdaja;
    static String opis_dokumenta;
    public Vector MyDocs()  {
        Vector polje =  new Vector();
        Db db = null;
        BindV bindv = null;
        Hli hli = new Hli();
        String DbName = new String("pro_base");
        String UserName = new String("wilson");
        String HostName = new String("ntdms");
        String PCSrvrName = new String("sherpasv");
        String Password = new String("welcome");
        try {
            db = hli.ConnectDb(HostName,PCSrvrName,DbName, UserName, Password);
            db.Bind("group1");
            db.dms_execute("LIST RECORD DOCUMENT\\*\\*  /WHERE=\" owner =" +
              "\"\"zfur\"\" and reclevel=\"\"CREATED\"\"\" name4,recalt,desc");
            for (;;) {
                // Get the next set of results.
                bindv = db.dms_fetch("group1");
                if (db.dms_msgcode() == DMS_EOF)      // End of results
                    break;
                if (db.dms_msgcode() != DMS_OK){      // Error
                    System.out.println(db.dms_msgtext());
                    continue;
                // dobimo vrednosti spremenljivk
                koda = bindv.record_name4(0);
                izdaja = bindv.record_recalt(0);
                opis_dokumenta = bindv.record_desc(0);
               Dok dokument = new Dok(koda, izdaja, opis_dokumenta);
               polje.add(dokument);
        catch (DMSException e) {
            System.out.println(e);
            if(db.dms_msgcode() == DMS_NOSUCHDB)
                System.out.println("Please modify the DbName in this" +
                 "  program and try this again.");
        // vrne vektor
        return polje;
    // zacetek izvajanja
    public static void main(String[] args){
        DMS l = new DMS();
        Vector w = new Vector();
        w = l.MyDocs();
        for(int ii = 0; ii < w.size(); ii++) {
            System.out.println(((Dok)w.elementAt(ii)).podatki());
       HLIWrapperUtils.cleanup();
Drugi razred je :
 * @author student11
public class Dok {
    private String koda;
    private String izdaja;
    private String opis_dokumenta;
    public Dok(String koda, String izdaja, String opis_dokumenta) {
        this.koda = koda;
        this.izdaja = izdaja;
        this.opis_dokumenta = opis_dokumenta;
    public String podatki(){
        return koda + " " + izdaja + " " + opis_dokumenta;
V netbeansu pa probam napisati WS, ki mi pa javlja napako pri progarmu:
package org.me.doc;
 * This is the implementation bean class for the DocWS web service.
 * Created 2005.10.6 16:10:19
 * @author student11
public class DocWSImpl implements DocWSSEI {
    org.me.primer.DMS dMS;
    org.me.primer.Dok dok;
    // Enter web service operations here.
    // (Popup menu: Web Service->Add Operation)
     * Web service operation
    public String Vrni(java.lang.String v) {
        // TODO implement operation
        return podatki;
Javlja mi napako:
C:\Documents and Settings\student11\Desktop\DocWS\DocWS\src\java\org\me\doc\DocWSImpl.java:2: 'class' or 'interface' expected
1 error
Kako bi jo lahko odpravila.
ALi mogoce pozna kako slo. stran kjer je opisano delo z netbeansom, ker meni tuki nobeden ne more pomagati, ker s tem se neobeden ni delu!
Please help me! :'(
Lap dan!
Ciao ciao Bijonda
  • spremenil: kopernik ()
kopernik ::
Zadnji razred spremeni v :
package org.me.doc;
import org.me.primer.*;
 * @author student11
    DMS dMS;
    Dok dok;
    public String Vrni(String v) {
        return v;
kopernik ::
Informacij o razvojnih okoljih (tudi o netbeansih) je ogromno, resda večinoma v angleščini. Če ti angleščina povzroča težave, potem pa slovar v roke :-) Mislim, da slovenskih informacij ni prav veliko ...
Davčne blagajne (strani: 1 2 3 4 … 24 25 26 27 )
Oddelek: Programiranje
1344392114 (132117) Macketina
Web services - Neveljavni karakterji v XML
316320 (5432) boolsheat
[JAVA] branje iz datoteke
242826 (2461) Bela01
[JAVA] zaustavitev niti (threadov)
223696 (3696) morbo
[Java] Shranjevanje podatkov in datotek
71593 (1546) Vesoljc
