T-2: Informacije
T-2: Informacije
NavadniNimda ::
C:\Documents and Settings\NavadniNimda>tracert www.oxedion.de
Tracing route to www.oxedion.de [84.246.120.70]
over a maximum of 30 hops:
1 1 ms <1 ms <1 ms 192.168.1.1
2 25 ms 20 ms 25 ms 84.255.208.134
3 1 ms 1 ms 1 ms 84.255.210.1
4 9 ms 9 ms 9 ms wat1-15-85.net.uta.at [62.218.15.85]
5 9 ms 11 ms 9 ms c76wmode1-tengigE4-1.net.uta.at [212.152.192.206
6 10 ms 9 ms 10 ms vie3-core.gigabiteth1-0.swip.net [130.244.205.57
7 23 ms 23 ms 23 ms fra2-core.pos9-0.swip.net [130.244.205.41]
8 23 ms 23 ms 23 ms weis-core-1.pos0-0.swip.net [130.244.194.181]
9 24 ms * 24 ms some.frankfurt.router.Level3.net [130.244.200.86
10 24 ms 31 ms 36 ms ae-31-51.ebr1.Frankfurt1.Level3.net [4.68.118.30
11 24 ms 35 ms 36 ms ae-1-100.ebr2.Frankfurt1.Level3.net [4.69.132.12
6]
12 31 ms 36 ms 36 ms ae-2.ebr1.Dusseldorf1.Level3.net [4.69.132.137]
13 29 ms 27 ms 27 ms ae-12-55.car2.Dusseldorf1.Level3.net [4.68.119.1
44]
14 30 ms 27 ms 27 ms tge-2-1.bbr1.dus1.de.inetbone.net [62.67.36.188]
15 28 ms 28 ms 27 ms de.gw1.dus.247gmbh.de [213.131.232.38]
16 28 ms 27 ms 27 ms oxedion.de [84.246.120.70]
Trace complete.
DNS lepo rezolvira, tracert se do tja privleče. Problem je na strežniku samem.;)
rfmw ::
Imam, izgleda podobno kot NN, 84.255.xx.xx.
@ar4743 ... sklepam da si ti na T-2 omrežju.
Ping dela, HTTP pa ne. Zanimivo, da tebi ar4743 dela, prav tako kolegom iz tujine (zato sem tudi napisal prvi post, ker je medtem drugim lepo delalo)...
Legendary 8RDA+ (reCAPed ;), XP1700+ 2108 @ 1.84 V, SLK900A AS3 @ 2500 rpm
1,5GB Samsung DDR333+Geil DDR400+SuperTalent DDR400 @ DC 200 MHz @ 6-3-3-2.5
amigo_no1 ::
Stran dela:
iz www.oxedion.de sem prišel na
http://www1.oxedion.com
(nisem pri t-2)
  • spremenilo: amigo_no1 ()
Ugibam, da ima T-2 oprema spet probleme sama s sabo (84.255.x.x).
rfmw, mas kaki ruter doma ?
rfmw ::
Ja, imam Asus wireless WL-500GP, vendar to naj ne bi bil problem, ali pač? Router ima nastavljen statični T-2 IP (84.255.x.x), PC pa ima DHCP dodeljen 192.168.1.2.
Hočete reči, da je problem nedostopanja WEB strani pri meni?
ender ::
rfmw: meni dela brez problemov (84.255 IP).
Ravno eni Asusi imajo take tezave. Vsaj eni so tak porocali.
Mas zadnji FW gor ?
Najboljse prilozeno sranje dol vrzt in OpenWRT gor dat. (ali kako drugo alternativo).
Brez veze igrati beta testerja, da ti MOGOCE po treh mesecih izdajo popravek.
(pod pogojem, da je res ruter kriv. Kar preveris cist preprosto : vzames ruter iz enacbe, beri : PC direkt brez ruterja priklopit na internet)
  • spremenil: MrStein ()
klemenSLO ::
Meni recimo tudi stran www.fov.si ne deluje, pri kolegu PA. Oba pa imava T2 statični ip in wrt54g...
MTm2H37rqt7B ::
www.fov.si: deluje, statika + wrt54gl
klemenSLO ::
meni ne --- zdej pa bodimo pametni :'(
rfmw ::
Meni deluje www.fov.si brez problemov. T-2, statika, Asus WL-500gp.
Sem pa probal uno nemško od zgoraj še iz službe, pa tudi ne dela...weird... a je možno kaj z IE?
  • spremenil: rfmw ()
rfmw ::
ekola, rešeno:
www.oxedion.de sedaj dela tudi meni in to iz Firefoxa! Iz IE ni dostopna, go figure...
www.fov.si dela OK v IE in tudi v FF.
nekdo123 ::
NavadniNimda: Ti je mogoče kaj jasno, zakaj ima A Kanal zvok samo na levem zvočniku?
Hvala za odgovor!
NavadniNimda ::
Klicalo se je na Kanal A in so rekli, da so "nekaj prestavljali" in povedali, da bodo jutri popravili.
nekdo123 ::
Aja, a jih ne lovite preko anten?
Cokolesnik ::
Se komu dogaja, da mu VDSL modem na 2,3,7 dni dol vrže le toliko da prekine in se ponovno postavi nazaj ter nemoteno deluje naprej, enkrat zjutraj, drugič ponoči, tretjič zvečer? Sprašujem zato, da morda T-2ju pomagam sam najti vzroke za takšne prigode.
Človek lahko znori, zlasti če v spornem trenutku aktivno uporablja storitve T-2. Naj se sprijaznim, če na HD odgovarjajo, da je lahko kriv tudi sosedov elektromotor? Včeraj sem tudi ponovno prijavil napako (ne prvič ampak n-tič) in danes zjutraj sem še enkrat preveril, kje je zadeva. Pravijo, da še niso natisnili naloga.
Storitve potrebujem za poklicno delo, mesečno plačujem 50 EUR naročnin kar je več kot marsikateri fizični ali poslovni uporabnik, pa me nihče še ni poklical. Mislim, da bom boljši uptime iskal pri drugem ponudniku, kjer sem na izpade lahko pozabil (Triera). Nek posel ti lahko rata takoj, ali pa ti sploh ne.
Uporabniki naj pred pisanjem sporočil uporabljajo iskalnik www.google.com.
Čokolešnik ne vsebuje nobenih aditivov, konzervansov ali umetnih barvil.
Brane2 ::
Pa saj imajo v bistvu prav. A/VDSL ti lahko dol pade že če kdo v bližii prdne.
Potem se modem ponovno sinhronizira in piči dalje.
Cokolesnik ::
@Brane2: iz tvojih prispevkov je videti, da tudi ti ženeš biznis, poleg tega si tehnično pravšnji za svetovalca VDSL. Bi se sprijaznil na mojem mestu ali se spravil nazaj na (zanesljiv) kabel ? Cene so praktično enake (le telefoniranje je dobrih 4 sit v telekom).
SasoS ::
Pri meni pade dol ko ugasnem eno luč (ne vedno ;))...pač za 30s zmrzne in potem šiba dalje. Če te to toliko moti pojdi na kabel ali optiko...
Brane2 ::
Uporabljaj pač tisto, kar ti je bolje.
Če se sekiraš za ta trenutek prekinitve in če ta odziv ponudnika ne zadovoljuje in imaš boljšo alternativo, hja potem pejdi drugam.
Zakaj se toliko sekiraš ? Saj te T-2 ne veže. Lahko greš, ko ti paše in prideš nazaj, če si premisliš.
Cokolesnik ::
@Brane2: mi boš prišel po bajti pomagat demontirat lan in montirat nazaj coax kablovje? :) Ker sem ravno pri coax: kater delilnik bi mi priporočil, če kej poznaš, da bi coax signal kar nabolj optimalno razdelil na 3 teveje - priporočili so mi Tratec.
Z delujočega kabla si šel na nezanesljivi VDSL ? Zakaj ???
mitja_i ::
VDSL je čist zanesljiv. Nezanesljivo je omrežje TS na večjih razdaljah, ki bi po teoriji morale podpirati VDSL.
Cokolesnik ::
@MrStein: kakovost tv slike me je premamila - na catv sicer ni bila 100% slabša, bila pa je toliko boljša, da si to lahko opazil s prostim očesom.:) Zato je dilema še večja - adijo T-2, adijo boljša slika, a hkrati tudi adijo nezanesljiva povezava. In ti, kako bi se odločil? :)
@mitja_i: če bi bilo (ne)delovanje odvisno od t-2 in ne od telekoma in same narave vdslja, potem bi izpadanje res bilo omejeno na nadgradnje, ki jih opravlja t-2, tako pa... Pa pravzaprav bode v oči brezhibna inštalacija, še ugodna oddaljenost od centrale (500 m) z okoli 50/17mbit sinhronizacije, potem pa nekdo "luč ugasne" (navajam enega od uporabnikov) in PUF.
Medica ::
ma ja mitja, če kej pr T2 ne dela, je takoj Telekom kriv....:\ peezda ste naivneži če vrjamete da je za vse njihove napake TS kriv....:\
sznn ::
Cokolesnik, ce potrebujes zelo zelo stabilno linijo si pac omislis backup line.
Pri nas je v podjetju zahteva, da je izpad linje res minimalen in zato imamo dve liniji na dve ponudnikih. Ce ena linija pade, router avtomaticno preusmeri ves promet na backup linijo....
50 EUR ni ravno dosti, ce hoces 99,999% uptime.
Glavna linija je najet mednarodni vod, ki stane cca 2000EUR na mesec. Za ta denar je seveda linija delovala tudi, ko je zmanjkalo elektrike po Bežigradu, ker ima ponudnik generator na nafto in je lahko brez elektrike par tednov, pa bo vse delovalo.
Cokolesnik, pol pa vzemi TV pri T-2 , internet pa pri kablašu.
(in če te moti, da ti oba zraven "uturita" storitev, ki jo ne rabiš : TV pri kablu in internet pri T-2; ju toži. Ali pa naroči minimalen paket in "trpi svojo usodo"...)
Cokolesnik ::
peterp ::
Zanima me, če slučajno kdo ve vsaj približno, koliko bodo okvirne razdalje, do katerih bo T-2 še povezoval uporabnike na VDSL2. Sprašujem pa zato, ker je dilema ali se vezati za nadaljnih 24 mesecev pri xy operaterju ali počakati. Oddaljenost, za katero sprašujem pa je 2.7 km od centrale (1/256 internet + 2TV, oz. vsaj 1TV). Kakšna ideja o tem, ali se splača počakati še nekaj mesecev na VDSL2?
NavadniNimda ::
Ne se vezati, počakaj, da pride T-2 na trg. Sej bo kmalu.:|
Ne, ne vzemi pri T-2, ker bo kmalu zunaj T-3 !!!!!
Res kmalu. Obljubim ! Evo, prisezem na grobu svoje matere !!!
imamodovoljobljub.press
NavadniNimda ::
Datuma pa NE povem, da ne bo Medvedica nesla svojim državnim organom.;)
ne_kdo ::
zanimivo zanimivo tudi mene zanima kdaj bo ta tezko pricakovani vdsl2 zunaj:)
MrStein izvirno :)
Cokolesnik ::
Kaj ti pomaga VDSL 2, če ti že VDSL (1) pade dol, ko nekdo v bližini prdne. :\ Če bo tudi občutljivost podvojena, toliko slabše.
NavadniNimda ::
VDSL-LR dela na precej bolj švoh signalu, kot VDSL-2. To ve tudi Medvedica, zato tu ni potrebno nič o tem govoriti.
VDSL-LR pa pade ponekod tudi zaradi nekaterih drugih specifičnih lokalnih razlogov, ne samo zaradi namagnetenega prdenja. Tega pa Medvedica ne ve in zato tega ne mislim tu naznanjati. Naj malo švicajo...
Cokolesnik ::
No, magnetna polja, prdci, vesoljci, beli, črni, rdeči, oranžni in ostali gor ali dol, rezultat je še vedno: mizeren uptime.
NavadniNimda ::
Upam, da si naredil vse kar se da, da ojačaš signal - poštimana interna inštalacija, minimalno dolg kabel od štekarja do modema, modem pa čimbolj osamljen od ostalih naprav. Pri večjih razdaljah tudi to lahko pomaga (preverjeno tudi pri meni doma, dokler nisem šel na Gratelovo FTTH).
b ::
Misliš "Edino Pravo Optiko™"?
Cokolesnik ::
@NN: tvoji službeni kolegi, kar nekaj jih je pravzaprav, potrjujejo brezhibnost moje inštalacije (v nasprotnem primeru bi zagotovo pokalo na vseh koncih in krajih televizije, interneta in telefona), kabla med štekarjem in modemom sploh ni, ker je modem povezan direkt z omarico na 0,5 m dolgem FTPju. Pravzaprav je modemu kar dolgčas, ker je resnično osamljen. Kaj boš še našel, malce provokativno vprašanje ?
Jaz kar verjamem Branetu, da s "prdcem" resetiraš modem brez fizičnega kontakta, pri čemer si pravzaprav lahko obsojen na večni "smrad", saj "prdec" niti ni nujno tvoj.
O saj res, kmalu bo preteklo 24 ur od zadnje prijave iste napake, pa me nihče še ni poklical, kot je bilo obljubljeno, niti ni (domnevno) nihče vzel mojega problema pod drobnogled, saj sem izrecno zahteval kontak v času odpravljanja težave, da se skupaj posvetujemo.
Uptime na liniji bo nemara obratno sorazmerem z uptimom (poskusa) reševanja problema? Jutri je nov dan. Bom podpisoval pogodbo za Triero? :\
shock ::
Nimda: si pozabil napisat "Edino pravo optiko"
NavadniNimda ::
Nisem dajal politične izjave, ampak sem probal pomagati Čokolešniku. Vidim, da je poštimal, kar je lahko, na svojem koncu. Sedaj upam, da mu rešijo še ta težaven del.
Cokolesnik ::
Ura je 1:26 in jaz še vedno čakam, da me kdo pokliče iz tehnične podpore.
iverson3 ::
Ok, ker neuradni forum T2-ja ni dosegljiv, bom vprašal kar tukaj. Sedaj imam ADSL + ISDN.
Odločil sem se vzet polnorazvezan paket pri T2-ju. Zanima me pa, kaj je potrebno obkljukati tukaj: klik. Kot sem že omenil imamo ISDN in želimo ohraniti tel. številko.
Hvala za informacije.
Cokolesnik ::
Ko nihče ni nič kriv, narobe pa je vse...
Moj namen pisanja tega prispevka je, da bo marsikateri potencialni ali že obstoječi uporabnik storitev T-2 lahko bolj seznanjen z nekaterimi dejstvi o tehnologiji VDSL, ki še kako vplivajo na kakovost delovanja vseh naročenih storitev pri ponudniku VDSL dostopa do interneta (v tem času je poleg T-2 z VDSL, VDSL2 ponudil tudi Telekom oz. SiOL).
Gre namreč za to, da sem sam bil že od začetka zadovoljen s kakovostjo storitev T-2 televizije, telefona kot tudi interneta samega, a vendarle je prišlo do nenehnih prekinitev linije (izguba sinhronizacije modema) in skupaj s tehnično podporo, ki ji sicer (v tem trenutku) manjka kar nekaj spretnosti in organizacije, smo ugotovili oz. predvsem potrdili naslednji domnevi dveh poznavalcev tehnologije:
VDSL ti lahko pade dol, če nekdo v bližini prdne. Modem se postavi nazaj in piči dalje.
Če v bajti prižgem določeno luč, pa še to ne vedno, mi prekine VDSL.
Zaradi tovrstnih razlogov, zaradi katerih je uporabnik praktično nemočen, mora postaviti na tehnico zanesljivost in dobrobit (npr. cenovni prihranek) rabe sodobnih storitev, ko se odloča za ponudnika. Pravzaprav se je primoran pustiti presenetiti, sej se vse morebitne motnje in težave na strani ponudnika, uporabnika ali iz okolja pojavijo šele tekom rabe in jih ni mogoče napovedati za določeno linijo oz. parico. Za prihodnost lahko izpostavim le to, da optične povezave niso občutljive na motnje iz okolja in da pri optiki teh problemov ni.
Še enkrat poudarjam. Delovanje VDSL storitev (pa naj bo katerikoli ponudnik) je zaradi narave tehnologije odvisno tako od ponudnika, uporabnika (denimo kakovost notranje inštalacije) kot tudi okolja - torej prisotnosti oz. odsotnosti najrazličnejših elektromagnetnih polj in podobno, na katere ima uporabnik neznaten vpliv. Slednje so tudi botrovale moji odločitvi za prekinitev pogodbe s T-2.
bradek ::
Cokolesnik, nevem ce je pametno tako posploseno govoriti o tehnologiji, ki jo uporablja ze na milijone ljudi po celem svetu.
Jaz imam na primer ravno nasprotne izkusnje, VDSL povezava je pri meni popolnoma stabilna. Tvoj stavek "Če v bajti prižgem določeno luč, pa še to ne vedno, mi prekine VDSL." mislim da pove vse. Uredi hisno napeljavo, preveri spoje in ozemljitev, in stvari bodo cudezno zacele delovati normalno.
Mislim da je tvoje "objektivno osvescanje" drugih uporabnikov sirokopasovnih dostopov povsem neutemeljeno.
  • spremenil: bradek ()
Medica ::
preberte ta članek:
Anton Rotar iz Kranja je konec septembra lani sklenil pogodbo za priključitev treh TV sprejemnikov, interneta in telefona s ponudnikom telekomunikacijskih, informacijskih in medijskih storitev, mariborsko družbo T-2, katere direktor je Matevž Turk. A se je, kot pravi Rotar, zapletlo že v začetku. Po nekaj dneh je prenehal delovati internet, a so po več klicih na družbo napako le odpravili. Vendar nevšečnosti s tem še ni bilo konec. Pozneje več dni ni deloval telefonski priključek, onemogočen je bil tudi dostop do televizijskih programov. Rotar se je odločil poiskati pomoč na enoti omenjene družbe v Kranju, a ker tam nimajo nobene telefonske številke, kamor bi jih lahko poklical, se je pri njih oglasil osebno, včasih tudi večkrat na dan. Tamkajšnja uslužbenka mu je, kot pravi, nevljudno in vzvišeno povedala, da imajo težave z nadgradnjo sistema. Kar pa naj po njegovem mnenju ne bi bila njegova stvar. Najbolj ga je motilo, da ni mogel nikogar dobiti na telefon, kadar je potreboval pomoč. Po vztrajnem klicanju je Rotar le dobil operaterja, ki mu je rekel, naj po njegovih navodilih prek mobilnega telefona napake odpravi kar sam. Po večkratnih neuspelih poskusih, da bi mu omogočili nemoteno spremljanje TV programov, se je Rotar odločil z omenjeno družbo prekiniti pogodbo za televizijski sprejemnik. Vedenje zaposlenih v družbi ocenjuje kot nestrokovno in nekorektno, ker bi morali glede na to, da je bila garancija za omenjene storitve še veljavna, napake nemudoma odpraviti, kajti sam, kot pravi, za to ni usposobljen. Ob vsem tem se čuti oškodovanega, saj je moral stroške telefona in prevoza kriti sam. Zaradi vseh omenjenih zapletov je primer prijavil na Tržni inšpektorat RS. Odločen je, da bo ob morebitnih nadaljnjih težavah z internetom in telefonom dokončno prekinil pogodbo z omenjeno družbo. Tudi sami smo klicali na družbo T-2, vendar brez uspeha, trikrat smo jim poslali tudi vprašanja po elektronski pošti, na katera pa prav tako nismo dobili odgovorov.
kopirano iz direkta (njegove spletne strani sevede)
Cokolesnik ::
Bradek: popolnoma objektivno sem predstavil svoje stališče, saj sem nakazal na vse potencialne dejavnike, ki vplivajo na kakovost delovanja VDSL. Lahko se zgodi, da tebi deluje VDSL, meni ne, pa to sploh ni najin ali T-2 ali celo Telekomov problem. V svojem stališču tudi nisem VDSL obsodil na propad, ali pavšalno obsodil T-2 na slabo kakovost zagotavljanja storitev niti se ne nameravam odzvati na čustvene reakcije ("moj ponudnik je bog, ponuja božanske storitve"). Verjamem Branetu, ki je situacijo xDSL še kako dobro karikiral s prdcem, če že SasoS ni pravilno ozemljil nesrečne luči.
Morda naj prav Brane posreduje še kakšen link v zvezi s tehnično obrazložitvijo prdca.
SasoS ::
Mislim da ima Cokolesnik kar prav. Dejstvo pa je da večina ljudi teh padcev linije ne bo opazila ali pa jih bo pripisala nadgradnjam...saj zadeva sploh ni tolk kritična (kar se neta tiče, malce je neprijetna pri telefonu in TVju ko se linija prekine), pač greš na WC ko prideš nazaj je že gor. Žal, telefonsko omrežje ni namenjeno nekaj megabitnim prenosom in tisti, ki rabijo 100% obstanek linije brez izpadov bodo sigurno posegli po drugih tehnologijah. S povečevanjem frekvenčnega spektra se stvari drastično slabšajo, ni tudi rečeno da ne bi bilo možno izboljšati stabilnosti z boljšimi elementi oz. kakim oklopljenim ohišjem modema...
Kar se tiče moje napeljave, modem je na 10cm UTP kabla zraven vtičnice, štromar pa nisem tako da težko kaj o tem povem...te luči so v kuhinji tiste cevi, se pa včasih zgodi da tudi TV žmrkne ko jo ugasneš (pa je na čisto drugi vtičnici).
ne_kdo ::
@Medica to je blo v petek v direktu :)
alienalien ::
Ma takole je. Res je, da če furaš samo internet tega marsikdaj ne opaziš. Je pa pri TV to toliko bolj moteče in vedno se dogaja ravno takrat ko je kaj zanimivega. Moja že tako nori, da me prisiljuje v postavitev anologne antene in odjave IP TV, ker pač pri nas kabelske TV ni mogoče dobiti. Problemi so povsod enaki in Siol in T2 pri obeh se dogaja, da včasih slika obstane ali pa kocka ne normalno 3 minute potem dela 5 ur brez problema itd brez, da bi kaj resetiral. Očitno se te motnje prisotne pri vseh tudi pri kolegu, ki dobesedno živi v centrali 42m stran mu TV v večernih urah kocka po 5 minut skupaj. Ma meni je že smešno to, da nam TV dobavljajo po telefonskem kablu, ki verjetno primarno ni bil namenjen temu. Očitno bo res šele optika zagotovila kakovostno in ne moteno gledanje TV tako kot včasih na stari dobri anologni antenci.
Če imaš pa IP TV pa se moraš s tem sprijaznit, da greš na vsake dva dni resetirati modem oziroma počakaš, da se sam in pa da v mes kdaj med dobrim filmom preživiš 5 minutni kockarski napad, ki potem sam od sebe mine.
136 / 254
