Forum » Pomoč in nasveti » Ne da se zbrisat filma
exdrumer ::
Zdravo.
Ko hočem zbrisat film mi windowsi (xp) javijo da naj zaprem programe ki ga mogoče uporabljajo, ko potem pogledam v task manager imam pa explorer 99% zaseden in mi čisto zablokira PC. Skeniral sem ga že z nod32 pa ni nič.
Myth ::
Ponovni zagon računalnika in zatem zbriši datoteko.
¤ Space is Mystery. And Myth is on Earth. ¤
Caligula ::
Najlazja zadeva je, da zapres kak P2P program, ce ga uporabljas in potem odpres Nerota in v Nerotovem explorerju izbrises.
Brilko ::
Mislim da to nebo rešilo problema, ker mam jst tud tako zadevo, ko se mi en film neda zbrisat.
Myth ::
Jaz sem na "moj" način vedno izbrisal takšne zadeve.
Goldee ::
poskusi v varnem nacinu zagnat racunalnik in potem zbrisat al pa poskusi v total comanderju...
Yossarian ::
Meni je res vedno uspelo nazadnje v varnem načinu. Če ni šlo drugače, sem dal ukaz "Izreže", nato pa sem ga prilepil v Koš in tam zbrisal.
BogyX ::
Da ne bote preveč debatirali:
DELETE CORRUPTED AVI FILES
Files with the file extension of .AVI are Windows Video files. The letters AVI stand for Audio Video Interleave. These "movie" files can be played with Windows Media Player (as well as other programs of the same type) and can be downloaded from the internet in many different places. Sometimes when you download one, it may be corrupted and will not play correctly. If you try to delete it in Windows Explorer, often you find that you cannot! You will get an error message such as this:
Error deleting file or folder
Cannot delete (name of file): It's being used by another person or program. Close any program that might be using the file and try again.
Usually, there will be no other program trying to use the file. You find you cannot rename or copy or move it to another location also.
The problem lies in a known fault with XP's Windows Explorer:
When you click on an AVI file in Windows Explorer, the operating system will attempt to read the entire file in order to determine the dimensions, duration, bitrate, etc. of the file. During this process you might experience 100% CPU usage. If the file is broken or not fully downloaded, you will have problems trying to copy, move, rename, or delete it.
In order to solve this problem, you will have to use the Registry Editor. Click the Start button, click Run on the Start Menu, type in REGEDIT. Navigate on the left pane of the Regedit window to the following key:
HKEY_CLASSES_ROOT\SystemFileAssociations\.avi\shellex\PropertyHandler
Verjetno to reši vaše težave.
Bogdan
Bogdan
Goldee ::
Po mojih izkusnjah ga lahko vedno izbrises v varnem nacinu, ce se motim nisem zanalasc
no exdrumer porocaj, si ga izbrisal (v varnem nacinu)?
p.s. usak se lahk zmoti
exdrumer ::
Probal sem v varnem načinu in se je zbrisal, tako da nisem mogel probat še drugega načina, ampak sigurno tudi tisti deluje
HVALA
HVALA
vres.ales ::
alo ej moraš si program nabavit, ki bo to ob ponovnem zagonu naredo sam uporabljam: http://www.gibinsoft.net/gipoutils/bin/...
mmmato ::
zapreš proces explorer.exe in zbrišeš z progamom Total Commander (ex. Windows Commander) ali v dos promptu, nazaj vklopiš explorer.exe
| » | ne morem izbrisati datotekOddelek: Pomoč in nasveti | 10002 (9116) | Yossarian |
| » | Ne morem izbrisati ikone z namizjaOddelek: Pomoč in nasveti | 2738 (2579) | kovk |
| » | Ikone v win XP izginile po uporabi programa Spybot Search & Destroy. Kako dobiti ikonOddelek: Pomoč in nasveti | 2703 (2659) | riba43 |
| » | Kako izbrisati datoteko ?!??!Oddelek: Pomoč in nasveti | 3085 (2684) | ahriman |
| » | Problem z brisanjem pokvarjene AVI datoteke!!!Oddelek: Pomoč in nasveti | 3722 (3458) | smolep |
