Forum » Strojna oprema » DFI lanparty ut nf4 sli-d - MRTVA?
bmandelj ::
lep pozdrav
posedujem omenjeno plosco in mi je delala 3 dni, sem testiral rame
zadeva je delovala lepo z mushkin rami, potem pa sem hotel probati se kingmax rame in zadeva se ne zbudi vec.
kinstoni so tudi ze prej delali v plati.
sedaj ne dela z nobenimi rami vec
probal sem mushkin, kingmax, geil
timingi so na auto, naredu sem bios reset (baterija ven cez noc, brez napajanja)
drug napajalnik in druga graficna ne pomaga
venti se zavrtijo in tiste 4 lucke vse gorijo to je pa vse. plata je na mizi tako da stika ni.
probaval sem vse mozne kombinacije slotov pa nula
a je sla plata po gobe?
Hvala za nasvete
LP Brane
Hvala za nasvete
LP Brane
There is no greater sorrow than to recall hapiness in times of misery....... Dante Aligheri
igor0203 ::
da ni slučajno proc šel? k jst sm meč podobne težave, še ko sem mel AMD XP 3200+, ko mi je crknil.
Legoless ::
Resetiraj še bios s jumperjem. To se je meni tudi zgodilo, a pomagalo je, da sem prestavil jumper za nekaj minut in potem nazaj.
bmandelj ::
bios reset sem ze probal
proc je pa problem ker nima drugega za probat
MEDENA ::
Hello out there,
Do you have 1 stick of ram that appears "Bad"...meaning it won't boot the board if you clear CMOS? If so, then please try the procedure outlined below. This will help us determine if the ram itself is bad.
This procedure should apply to Any bios that you might be using but I have only tested it on 310, 326, 414-2, and 510-2.
If this does not solve your problems, please create yourself a thread so that we can help you individually.
1) Clear the CMOS on the board.
2) Place your "good" stick in slot 2 (farthest orange from CPU)
3) Boot up the board and get into the bios.
4) On the Genie Bios page, set the DRAM Voltage to 3.0V.
5) Enable Memtest86+ on the Genie Bios page.
6) On the DRAM Config page, set the 4 main timings to 2-3-2-8 (CAS-tRCD-tRP-tRAS) (2-3-8-2 top to bottom in the bios).
7) Choose "Save and Exit" answer yes and let the board reboot.
8) Once you see memtest, power down the board.
9) Insert the "Bad" stick into slot 4 (closest orange to CPU)
10) Now power up the board, you should get to memtest.
If you get to memtest, then your memory is fine and does not need to be RMA'd.
You can read here at BE or over at DFI-Street for an explanation on why the board has this "cold boot" issue. DFI is working to resolve this issue and we hope that it will be as simple as a new bios to get things working properly.
Here is the post at BE explaining things a bit:
http://www.bleedinedge.com/forum/showth...
Hope that helps
Hope that helps
bmandelj ::
ni cold boot problem
rami definitivno delajo sem jih probal v drugi masini in delajo
@suli redline xp3500, xp4000 jih je zmanjkalo
ČIP 008 ::
Nič nisi napisal če ti kaj izspiše nas ekranu? Replace and press any key when ready? Po tvojem opisu sem 99% da je šla plata. In ravno rami ki se ne razumejo na določeni frekvenci so povzročili pred dobrim letom tudi smrt moje plate.
SepoX ::
Kolega je imel isti problem. Na koncu smo ugotovil, da je šel procesor. Kupu ga je v emisiji, kjer je kake tri zamenjal, saj so se kuril ko za stavo. Mogoče si enga od teh dobu
bmandelj ::
proc je dober.
sem nesu plato na servis in sedaj jo cakam kot budala ker serviser teži čaka na vrsto.
DJ MartiNi ::
Povprašaj PC H.AND. Oni so vsaj včasih bili zastopnik za tole.
Ryzen 7 7800X3D/MSI B850 Edge Ti Wifi/2x16GB G.Skill Ripjaws S5 6000/RX 7900 XT
Ryzen 7 5700X/ASRock B550 PG Velocita/2x16GB G.Skill Ripjaws V 3600/RX 5700 XT
AMD FX-8350/ASRock 970 Extreme4/2x4GB Kingston HyperX Beast 2400/R9 270X
| » | problem z hpj g72 sam se ugaša,pozneje se noče prižgatOddelek: Pomoč in nasveti | 963 (910) | Samson |
| » | Kje in kdaj DFI NF3 939Oddelek: Strojna oprema | 2409 (1551) | LittleDevil |
| » | Asus A7S333 -> voltažaOddelek: Hlajenje in modifikacije | 1512 (1433) | m.i.h.a. |
| » | Gigabyte - GEFORCE 4 = problem ??Oddelek: Strojna oprema | 1383 (1236) | kuglvinkl |
| » | Pazite na toOddelek: Kaj kupiti | 1888 (1489) | Dami |
