Fedora Core 4 in mrežna Marvell Yukon problem
NEO_ ::
Pred kratkim sem si namestil FC4.
Dela vse lepo in prav vendar mi ne zazna mrežne kartice Marvell Yukon 88E8053 PCI-E Gigabit Ethernet.
Mrežna je integrirana na matično ASUS P5GD1 PRO.
Poskusil sem sem naložiti nove gonilnike z njihove strani in mi program noče kompajlati jedra.
Javi mi naslednjo napako:
Create tmp dir (/tmp/Sk98ICYBnVBMqXNQKfnSPoXLn)                      [   OK   ]
Check user id (0)                                                    [   OK   ]
Check kernel version (2.6.11-1.1369_FC4smp)                          [   OK   ]
Check kernel symbol file (/proc/kallsyms)                            [   OK   ]
Check kernel type (SMP)                                              [   OK   ]
Check number of CPUs (2)                                             [   OK   ]
Check architecture (found)                                           [   OK   ]
Set architecture (i386)                                              [   OK   ]
Check compiler (/usr/bin/gcc)                                        [   OK   ]
Check mcmodel flags (none)                                           [   OK   ]
Check module support (/sbin/insmod)                                  [   OK   ]
Check make (/usr/bin/make)                                           [   OK   ]
Check archive file (sk98lin)                                         [   OK   ]
Check kernel gcc version (4.0.0) (Kernel:4.0.0 == gcc:4.0.0)         [   OK   ]
Check sk98lin driver availability (loaded)                           [   OK   ]
Disconnect devices:  (done)                                          [   OK   ]
Remove driver (done)                                                 [   OK   ]
Check kernel header files (/usr/src/linux)                           [   OK   ]
Unpack the sources (done)                                            [   OK   ]
Check sources for .config file (/usr/src/linux/.config)              [   OK   ]
Copy and check .config file (done)                                   [   OK   ]
Check the mem address space (highmem64)                              [   OK   ]
Change IOMMU (disabled)                                              [   OK   ]
Create new .config file (done)                                       [   OK   ]
Execute: make oldconfig (done)                                       [   OK   ]
Check kernel header version (Kernel:2.6.11-1.1369_FC4smp == Header:2.6.11-1.1369_FC4smp)                                                             [   OK   ]
Check kernel functions (Changed: nothing)                            [   OK   ]
Compile the kernel (error)                                           [ failed ]
An error has occurred during the compile proces which prevented
the installation from completing.
Take a look at the log file install.log for more informations.
Installation of sk98lin driver module failed.
Mi lahko kateri Linux expert razloži kako naj usposobim mrežno??? 8-)
hitcher ::
Po mojem bi že imel zadevo delujočo.
Daj naredi še naslednje:
dmesg > datoteka.txt
potem pa to datoteko pripopaj semkaj.
Pa še kernel?????.srpms si instaliraj na sistem (ga najdeš na cd-ju)
drugače imaš pa gonilnike za linux kernel 2.4 in 2.6 tukaj
http://www.marvell.com/drivers/driverDi...
v datoteki imaš pa tudi readme, kjer lepo piše kaj je potrebno narediti da jih implementiraš v sistem.
Clarkconnect: kako preprečiti DDoS napade iz lokalne mreže?
Oddelek: Omrežja in internet
262744 (2110) pecorin
Gentoo Xorg.conf LCD - sistem se obesi
Oddelek: Operacijski sistemi
362109 (1902) Mr.B
Gentoo install (strani: 1 2 )
526442 (5862) HerrBaron
NVIDIA gonilnik za Linix
161728 (1599) borchi
2 linux vprašanji (strani: 1 2 )
524973 (4535) ShowDown
