Forum » Pomoč in nasveti » Fedora Core 4 in mrežna Marvell Yukon problem
NEO_ ::
Pred kratkim sem si namestil FC4.
Dela vse lepo in prav vendar mi ne zazna mrežne kartice Marvell Yukon 88E8053 PCI-E Gigabit Ethernet.
Mrežna je integrirana na matično ASUS P5GD1 PRO.
Poskusil sem sem naložiti nove gonilnike z njihove strani in mi program noče kompajlati jedra.
Javi mi naslednjo napako:
Mi lahko kateri Linux expert razloži kako naj usposobim mrežno???
Create tmp dir (/tmp/Sk98ICYBnVBMqXNQKfnSPoXLn) [ OK ] Check user id (0) [ OK ] Check kernel version (2.6.11-1.1369_FC4smp) [ OK ] Check kernel symbol file (/proc/kallsyms) [ OK ] Check kernel type (SMP) [ OK ] Check number of CPUs (2) [ OK ] Check architecture (found) [ OK ] Set architecture (i386) [ OK ] Check compiler (/usr/bin/gcc) [ OK ] Check mcmodel flags (none) [ OK ] Check module support (/sbin/insmod) [ OK ] Check make (/usr/bin/make) [ OK ] Check archive file (sk98lin) [ OK ] Check kernel gcc version (4.0.0) (Kernel:4.0.0 == gcc:4.0.0) [ OK ] Check sk98lin driver availability (loaded) [ OK ] Disconnect devices: (done) [ OK ] Remove driver (done) [ OK ] Check kernel header files (/usr/src/linux) [ OK ] Unpack the sources (done) [ OK ] Check sources for .config file (/usr/src/linux/.config) [ OK ] Copy and check .config file (done) [ OK ] Check the mem address space (highmem64) [ OK ] Change IOMMU (disabled) [ OK ] Create new .config file (done) [ OK ] Execute: make oldconfig (done) [ OK ] Check kernel header version (Kernel:2.6.11-1.1369_FC4smp == Header:2.6.11-1.1369_FC4smp) [ OK ] Check kernel functions (Changed: nothing) [ OK ] Compile the kernel (error) [ failed ] An error has occurred during the compile proces which prevented the installation from completing. Take a look at the log file install.log for more informations. Installation of sk98lin driver module failed.
hitcher ::
Po mojem bi že imel zadevo delujočo.
Daj naredi še naslednje:
dmesg > datoteka.txt
potem pa to datoteko pripopaj semkaj.
Pa še kernel?????.srpms si instaliraj na sistem (ga najdeš na cd-ju)
drugače imaš pa gonilnike za linux kernel 2.4 in 2.6 tukaj
http://www.marvell.com/drivers/driverDi...
v datoteki imaš pa tudi readme, kjer lepo piše kaj je potrebno narediti da jih implementiraš v sistem.
| » | Clarkconnect: kako preprečiti DDoS napade iz lokalne mreže?Oddelek: Omrežja in internet | 2744 (2110) | pecorin |
| » | Gentoo Xorg.conf LCD - sistem se obesiOddelek: Operacijski sistemi | 2109 (1902) | Mr.B |
| » | Gentoo install (strani: 1 2 )Oddelek: Operacijski sistemi | 6442 (5862) | HerrBaron |
| » | NVIDIA gonilnik za LinixOddelek: Operacijski sistemi | 1728 (1599) | borchi |
| » | 2 linux vprašanji (strani: 1 2 )Oddelek: Operacijski sistemi | 4973 (4535) | ShowDown |
