Forum » Izdelava spletišč » Prikaz logotipa ali texta v sliki
woops ::
Zanima me kako bi s php-jem sprogramiral da v sliki prikaže logotip spletne strani ali pa textovni URL od spletne strani?
Tu je ena slika za primer [z dodanimj (:SMEJ.SE:)]:
Trenutno za prikaz slik uporabljam naslednjo skripto:
Hvala vnaprej!
[?php /* $Id$ */
ignore_user_abort();
set_time_limit( 0 );
error_reporting( FATAL | ERROR | WARNING );
ini_set( 'register_globals', '0' );
ob_start();
//while ( list( $key, $val ) = each( $HTTP_GET_VARS ) ) $_GET[ $key ] = $val;
if ( ! isset( $_GET['s'] ) ) die( 'Source image not specified' );
if ( isset( $_GET['w'] ) && ereg( "^[0-9]+$", $_GET['w'] ) ) $MAX_WIDTH = $_GET['w'];
else $MAX_WIDTH = 320;
if ( isset( $_GET['h'] ) && ereg( "^[0-9]+$", $_GET['h'] ) ) $MAX_HEIGHT = $_GET['h'];
else $MAX_HEIGHT = 200;
$src_size = getimagesize( $_GET['s'] );
if ( $src_size[0] > $MAX_WIDTH && $src_size[1] > $MAX_HEIGHT ) {
if ( $src_size[0] > $src_size[1] ) {
$dest_width = $MAX_WIDTH;
$dest_height = ( $src_size[1] * $MAX_WIDTH ) / $src_size[0];
else {
$dest_width = ( $src_size[0] * $MAX_HEIGHT ) / $src_size[1];
$dest_height = $MAX_HEIGHT;
else if ( $src_size[0] > $MAX_WIDTH ) {
else if ( $src_size[1] > $MAX_HEIGHT ) {
else {
$dest_width = $src_size[0];
$dest_height = $src_size[1];
if ( extension_loaded( 'gd' ) ) {
$ext = substr( $_GET['s'], strrpos( $_GET['s'], '.' ) + 1 );
if ( $ext == 'jpg' || $ext == 'jpeg' ) $src = imagecreatefromjpeg( $_GET['s'] ) or die( 'Cannot load input JPEG image' );
else if ( $ext == 'gif' ) $src = imagecreatefromgif( $_GET['s'] ) or die( 'Cannot load input GIF image' );
else if ( $ext == 'png' ) $src = imagecreatefrompng( $_GET['s'] ) or die( 'Cannot load input PNG image' );
else die( 'Unsupported source file format' );
$dest = imagecreatetruecolor( $dest_width, $dest_height ) or die( 'Cannot initialize new GD image stream' );
imagecopyresized( $dest, $src, 0, 0, 0, 0, $dest_width, $dest_height, $src_size[0], $src_size[1] );
if ( imagetypes() & IMG_PNG ) {
header ( 'Content-type: image/png' );
imagepng( $dest );
else if ( imagetypes() & IMG_JPG ) {
header ( 'Content-type: image/jpeg' );
imagejpeg( $dest );
else if ( imagetypes() & IMG_GIF ) {
header ( 'Content-type: image/gif' );
imagegif( $dest );
else print 'Cannot find a suitable output format';
else print 'GD-library support is not available';
ob_end_flush();
imagedestroy();
Hvala vnaprej!
http://www.pc-x.org/
veteran ::
Za logotip uporabi imagecopy, imagecopymerge; za pisanje po sliki pa so funkcije imagestring, imagefttext, imagettftext...
| » | Java skeniranje map in podmapOddelek: Programiranje | 1607 (1496) | nightrage |
| » | [PHP] branje slikeOddelek: Programiranje | 4490 (4303) | matijaz74 |
| » | button v image buttonOddelek: Izdelava spletišč | 1504 (1409) | R33D3M33R |
| » | Kako se tole naredi?Oddelek: Izdelava spletišč | 1880 (1580) | njok |
| » | Težava s spremembo davka v MySQL PHP skripti (skripta inside)Oddelek: Programiranje | 1556 (1358) | darh |
