Avtomatski zagon XPjev
Zorroo ::
A mi lahko kdo pove kako se naredi, da ni treba vedno vpisati vstopnega gesla ko se prijaviš v sistem. PC je v domeni.
Damjan Jagar ::
Naloži si TweakUI (iz microsoftove uradne strani). Tam imaš možnost vpisa gesla in izbire avtomatskega logiranja.
http://jagar.si
veteran ::
klik
Moraš pa imeti ustrezne privilegije. Če je administrator domene opravil svoj posel, boš lepo tipkal geslo še naprej. >:D
http://www.updatexp.com/tip14.html
1) Go to the Start Menu and the Run box.
2) Type in the following:
control userpasswords2
now click OK
3) In the new Windows that appears select the account you wish to make the primary logon.
Now uncheck the "Users must enter a username and password..." box.
4) Hit Apply and a dialog box will appear asking you to confirm the selected users password.
Click OK when you are done!
That's it! You are now finished.....
Izginili mail iz inboxa
Oddelek: Programska oprema
101805 (1507) Rok Nemec
windows media player 10 mi ne dela !?!?
81937 (1885) bunnyrabit
Rsetiranje računalnika
122044 (1875) Javon
velik problem...
61353 (1228) Shinobi
messenger in zivcni zlom!!!!
202192 (1710) KTr1sk
