Forum » Operacijski sistemi » Gentoo težave z bootanjem
|Luka| ::
Skratka, Winsi mi grejo počasi na organ, ker si sesuvajo; v linuxu pa tudi nisem najbol frišen. In se odločim za Gentoo - by the book, vse ok. Zatkne pa se ko sem prvič rebootal sistem, grub dela bp, kernel se naloži itd., ko pa pride do mountanja pa mi vrže ven error:
extsfs_check_if_mount: No such file or directory while determining whether /dev/hda3 is mounted
fsck.ext2: No such file or directory while trying to open /dev/hda3:
The superblock could not be read or does not describe a correct ext2 filesystem. If the device is valid and it really contains an ext2 filesystem (and not swap or ufs or something else), then the superblock is corrupt, and you might try running e2fsck with an alternate superblock:
e2fsck -b 8193 (device)
* Filesystem couldn't be fixed :(
moj fstab zgleda takole:
/dev/hda3 / ext2 noatime 0 0
/dev/hda4 none swap sw 0 0
none /proc proc defaults 0 0
particije pa imam sledeče (acc. to cfdisk)
/dev/hda1 NTFS
/dev/hda2 NTFS
/dev/hda3 Linux (ext2)
/dev/hda4 Linux Swap
kaj je šlo po zlu?
/dev/hda1 NTFS
/dev/hda2 NTFS
kaj je šlo po zlu?
BigWhale ::
ext2fsprogs paket moras instalirat.
Se enkrat boot iz CDja, pa chroot in pozenes emerge ext2fsprogs.
Tako kot bi instaliral zadevo. Potem pa unmount in reboot...
|Luka| ::
Huh, hvala...sedaj dela bp...ampak v manualu tega nikjer ne omenjajao (samo za ext3, reiser in xfs)
LP Luka
LP Luka
| » | [Gentoo] Kernel upgrade (strani: 1 2 )Oddelek: Operacijski sistemi | 6423 (5949) | Trubadur |
| » | Cannot open root device; GentooOddelek: Operacijski sistemi | 2041 (1897) | CCfly |
| » | Gentoo problem (strani: 1 2 )Oddelek: Operacijski sistemi | 5683 (5208) | Senzacionale |
| » | Gentoo - Install from Stage1 (strani: 1 2 )Oddelek: Operacijski sistemi | 4461 (3973) | noraguta |
| » | Pomoč...LinuxOddelek: Programska oprema | 1954 (1730) | Gh0st |
