Adsl on startup
Adsl on startup
Roadkill ::
A bi se dalo naštimat, da bi se adsl connectal na windows start in ne na login.
Torej da ni potrebno bit loginan, da si connectan.
Matri[X] ::
AFAIK se v XPjij ne da. V 2003 se to naredi z RRAS.
  • spremenil: Matri[X] ()
Spajky ::
Po moje povezavo bi se dalo s kako batch skripto startano iz registra /RunServices/ ... 8-)
mirkuma ::
ADSLautoConnect (http://www.adslautoconnect.net/)
http://wteam.uw.hu/support/no-free/ADSL...
The 1st program automatically creates a connection once the OS is booted &
recreates the connection if it would ever happen to get closed
Adslautoconnect is by default in French. Once installed, go to the installed
folder in which you'll find a lang sub-folder. Go in there & rename res.dll
to something like res.backup.dll & rename res_eng.dll to res.dll. Restart
the application.
...all those moments will be lost in time, like tears in the rain...
mirkuma ::
problem z odpiranjem strani v IE
Oddelek: Omrežja in internet
252471 (2286) bbf
Vsakih 5 minut - Internetna reklama ?!
363434 (2423) SanAndreas
A je to virus?
92819 (2472) fulgur
Optimizacija Win XP
Oddelek: Operacijski sistemi
73557 (3296) jan01
OASP slovar na Linuxu
112739 (2388) Simulacrum
