Forum » Operacijski sistemi » Instalacija windows95
e-jay* ::
prosil bi za pomoc pri naslednji tezavi.
Imam starejsi laptop(486 75mhz), ki ima nalozene OS DOS6.2 in win3.1.
1.zanima me ali je tistih 8mb integriranega rama dovolj za win95? v nasprotnem primeru bom dal not se ploscico 32mb ce jo bom kje dobil (ce kdo ma-kupim!)
2.laptop nima cdroma->potrebna je namestitev iz disket (tistih 26)
ali je mozno kar iz win3.1 nadgradit ali kako pac spravt gor win95?
kako sploh poteka zadeva.. jaz samo vem kaj dat na prvo disketo, kaj pognat, pol pa na vsako disketo oznako Disk1, Disk2 itd na vsakem wn .cab file. o ostalih zadevah se mi ne sanja.
ali mi kdo lahko napise step-by-step navodila?
najlepsa hvala.
najlepsa hvala.
Bog se je zmotil, ko je ustvaril elektron!
Slowenc ::
Windows 95 How-To Guide
System requirements for installing Windows 95:
• Personal computer with a 386DX or higher processor (486 recommended)
• 4 megabytes (MB) of memory (8 MB recommended)
• Typical hard disk space required to upgrade to Windows 95: 35-40 MB The actual requirement varies depending on the features you choose to install.
• Typical hard disk space required to install Windows 95 on a clean system: 50-55 MB The actual requirement varies depending on the features you choose to install.
• One 3.5-inch high-density floppy disk drive
• VGA or higher resolution (256-color SVGA recommended)
Drugače pa http://www.microsoft.com
Skiny gate.
e-jay* ::
Upgrading an Existing Installation of Windows 95
After you have upgraded an installation of Windows version 3.0 or later or Windows for Workgroups version 3.1 or later to Windows 95, the Windows 95 Upgrade can be installed over an existing installation of Windows 95. This process is frequently performed as a troubleshooting step to ensure that no Windows 95 files are missing or damaged.
1.stavek me zanima. pise "po tem ko ste nadgradili win3.1 itd na win95..."
kje pa to pise kak se naredi?
| » | Windows 95 dve desetletji pozneje (strani: 1 2 3 )Oddelek: Novice / Operacijski sistemi | 43241 (36712) | Spajky |
| » | Windows star 25 let! (strani: 1 2 )Oddelek: Novice / Operacijski sistemi | 34756 (31936) | pegasus |
| » | Windows XP repairOddelek: Pomoč in nasveti | 1475 (1317) | kmetek |
| » | Kateri "windows" na eno Full staro kišto ?Oddelek: Operacijski sistemi | 2666 (2021) | __Devil__ |
| » | Kateri operacijski sistem ste že imeliOddelek: Operacijski sistemi | 3239 (2522) | nicjasno |
